thinkgeo.mapsuite.mvcedition.overlay
ThinkGeo.MapSuite.MvcEdition.Overlay
Overlay()
  • Initialize an instance of the Overlay class.
Overlay(String)
  • id
Overlay(String,Boolean)
  • id
  • isBaseOverlay
ToJson()
  • Returns a JSON string which contains the information for creating an overlay at the client side.
  • Description:A JSON string which is used to create an overlay at the client side.
FromJson(String)
  • Load this object from a json string.
  • jsonString
    • Description:a json string
EhQ=(Page)
  • page
    • Type:Page
  • Registers a Javascript library URL string to the client HTML page.
  • The RegisterJavaScriptLibraryCore method allows derived classes to override and register their own Javascript library URL to the HTML page.
  • page
    • Type:Page
    • Description:The page object that is used for registering the javascript library.
IsVisible
Gets or sets a value that indicates whether the overlay is visible on the map.
Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
Opacity
Gets or sets the opacity level of the overlay.
The Opacity property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
  • Type:Single
IsVisibleInOverlaySwitcher
Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
IsBaseOverlay
Gets or sets a value that indicates whether the overlay is a base overlay.
Id
Gets the identifier for the overlay to be found.
OnClientAutoRefreshTick
Gets or sets a JavaScript function name which will be executed when the number of milliseconds specified in the AutoRefreshInterval property has elapsed.
AutoRefreshInterval
Gets or sets the time interval in which the MarkerOverlay refreshes itself.
  • Type:TimeSpan
Attribution
OverlayType
Gets a string that indicates which type the overlay is.
ERQ=
thinkgeo.mapsuite.mvcedition.overlay.1442910977.txt.gz · Last modified: 2015/09/22 08:36 by admin
