<!– Class –> A setting for LayerOverlay that contains APIs to set properties of LayerOverlaySetting using in MVC view.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.LayerOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.LayerOverlay PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.LayerOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.OverlaySetting`2[[ThinkGeo.MapSuite.MvcEdition.LayerOverlay **ThinkGeo.MapSuite.MvcEdition.LayerOverlaySetting
LayerOverlaySetting | LayerOverlay | Initializes a new instance of the LayerOverlaySetting class. |
ActionTriggers | Action<Collection<ActionTrigger» | ||
AutoRefreshInterval | TimeSpan | OverlaySetting<LayerOverlay,LayerOverlaySetting> | |
ClientCache | ClientCache | Set clientCache for Element property and retun the LayerOverlaySetting | |
DataBindTo | String, String | ||
Id | String | OverlaySetting<LayerOverlay,LayerOverlaySetting> | |
IsBaseOverlay | Boolean | OverlaySetting<LayerOverlay,LayerOverlaySetting> | |
IsMultiThreadDisabled | Boolean | Set isMultiThreadDisabled for Element property and retun the LayerOverlaySetting | |
IsVisible | Boolean | OverlaySetting<LayerOverlay,LayerOverlaySetting> | |
IsVisibleInOverlaySwitcher | Boolean | OverlaySetting<LayerOverlay,LayerOverlaySetting> | |
JpegQuality | Int32 | Set jpegQuality for Element property and retun the LayerOverlaySetting | |
Layer | Layer | Set layer for Element property and retun the LayerOverlaySetting | |
Layer | String, Layer | Set layer with a specific key for Element property and retun the LayerOverlaySetting | |
Name | String | OverlaySetting<LayerOverlay,LayerOverlaySetting> | |
OnClientAutoRefreshTick | String | OverlaySetting<LayerOverlay,LayerOverlaySetting> | |
Opacity | Single | OverlaySetting<LayerOverlay,LayerOverlaySetting> | |
ServerCache | ServerCache | Set serverCache for Element property and retun the LayerOverlaySetting | |
SetBaseEpsgProjection | String | Set epsg for Element property and retun the LayerOverlaySetting | |
TileHeight | Int32 | Set tileHeight for Element property and retun the LayerOverlaySetting | |
TileMargin | Int32 | Set tileMargin for Element property and retun the LayerOverlaySetting | |
TileType | TileType | Set tileType for Element property and retun the LayerOverlaySetting | |
TileWidth | Int32 | Set tileWidth for Element property and retun the LayerOverlaySetting | |
ToString | Object | ||
TransitionEffect | TransitionEffect | Set transitionEffect for Element property and retun the LayerOverlaySetting | |
TransitionEffectDelayInMilliseconds | Int32 | ||
WebImageFormat | WebImageFormat | Set webImageFormat for Element property and retun the LayerOverlaySetting | |
WrapDateline | WrapDatelineMode | Set wrapDateline for Element property and retun the LayerOverlaySetting |
Element | LayerOverlay | MvcElementSettingBase<LayerOverlay,LayerOverlaySetting> |
| layerOverlay | LayerOverlay<!– ThinkGeo.MapSuite.MvcEdition.LayerOverlay –> |
| LayerOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.LayerOverlaySetting –> |
| triggerActions | Action<Collection<ActionTrigger»<!– System.Action{System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MvcEdition.ActionTrigger}} –> |
<!– ThinkGeo.MapSuite.MvcEdition.LayerOverlaySetting –> Go Back
| timeSpan | TimeSpan<!– System.TimeSpan –> |
<!– ThinkGeo.MapSuite.MvcEdition.OverlaySetting{ThinkGeo.MapSuite.MvcEdition.LayerOverlay,ThinkGeo.MapSuite.MvcEdition.LayerOverlaySetting} –> Go Back
| LayerOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.LayerOverlaySetting –> | The setting of LayerOverlaySetting itself |
| clientCache | ClientCache<!– ThinkGeo.MapSuite.MvcEdition.ClientCache –> | A clientCache for Element property |
| controllerName | String<!– System.String –> | |
| actionName | String<!– System.String –> |
| id | String<!– System.String –> |
| isBaseOverlay | Boolean<!– System.Boolean –> |
| isMultiThreadDisabled | Boolean<!– System.Boolean –> | A isMultiThreadDisabled for Element property |
| isVisible | Boolean<!– System.Boolean –> |
| isVisibleInOverlaySwitcher | Boolean<!– System.Boolean –> |
| jpegQuality | Int32<!– System.Int32 –> | A jpegQuality for Element property |
| layer | Layer<!– ThinkGeo.MapSuite.Core.Layer –> | A layer for Element property |
| key | String<!– System.String –> | A key uses for layer |
| name | String<!– System.String –> |
| clientTickFunctionName | String<!– System.String –> |
| opacity | Single<!– System.Single –> |
| serverCache | ServerCache<!– ThinkGeo.MapSuite.MvcEdition.ServerCache –> | A serverCache for Element property |
| epsg | String<!– System.String –> | A epsg for Element property |
| tileHeight | Int32<!– System.Int32 –> | A tileHeight for Element property |
| tileMargin | Int32<!– System.Int32 –> | A tileMargin for Element property |
| tileType | TileType<!– ThinkGeo.MapSuite.MvcEdition.TileType –> | A tileType for Element property |
| tileWidth | Int32<!– System.Int32 –> | A tileWidth for Element property |
| transitionEffect | TransitionEffect<!– ThinkGeo.MapSuite.MvcEdition.TransitionEffect –> | A transitionEffect for Element property |
| transitionEffectDelayInMilliseconds | Int32<!– System.Int32 –> |
| webImageFormat | WebImageFormat<!– ThinkGeo.MapSuite.MvcEdition.WebImageFormat –> | A webImageFormat for Element property |
| wrapDateline | WrapDatelineMode<!– ThinkGeo.MapSuite.MvcEdition.WrapDatelineMode –> | A wrapDateline for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.LayerOverlay,ThinkGeo.MapSuite.MvcEdition.LayerOverlaySetting} –> Go Back
