<!– Class –> This class represents an overlay that requesting images from OpenStreet Map Service.
*System.Object ThinkGeo.MapSuite.iOSEdition.Overlay *ThinkGeo.MapSuite.iOSEdition.TileOverlay ThinkGeo.MapSuite.iOSEdition.OpenStreetMapOverlay
![]() | This is constructor of OpenStreetMapOverlay. | ||
![]() | GeoWebProxy | This is constructor of OpenStreetMapOverlay. |
![]() | Overlay | Closes this instance. | |
![]() | Overlay | Disposes this instance. | |
![]() | MapArguments, OverlayRefreshType | Overlay | This method draws the overlay by the specified arguments. |
![]() | Object | Object | |
![]() | Overlay | Gets the bounding box. | |
![]() | Object | ||
![]() | Object | ||
![]() | MapArguments | Overlay | Initializes the specified map arguments. |
![]() | TransformArguments, MapArguments | Overlay | Posts the transform for the overlay. |
![]() | Overlay | Refreshes this instance. | |
![]() | Object |
![]() | Overlay(overriden) | Closes the core. | |
![]() | Boolean | Overlay(overriden) | |
![]() | MapArguments, OverlayRefreshType | Overlay(overriden) | |
![]() | GeoCanvas, Exception | Overlay | Draws the exception. |
![]() | GeoCanvas, Exception | Overlay | Draws the exception core. |
![]() | TileView, MapArguments | TileOverlay | Redraws a specified tile with the provided world extent. |
![]() | GeoCanvas, TileView | TileOverlay(overriden) | This method overrides from its base class TileOverlay. It actually requests image for the passed tile with the passed world extent. |
![]() | Object(overriden) | ||
![]() | Overlay(overriden) | This method gets a world extent for holding the entire OpenStreet map. | |
![]() | TileOverlay | Chooses a tile object to form the TileOverlay. When overriding this method, consider the initialize parameters setting on the tile. | |
![]() | TileOverlay(overriden) | This method gets a concrete tile class to form this overlay. | |
![]() | Double, Int32, Int32, GeographyUnit | TileOverlay | Gets the tile matrix for TileOverlay. |
![]() | GeographyUnit, RectangleShape, Double | TileOverlay | Gets the tile matrix cells for TileOverlay. |
![]() | MapArguments | Overlay | Initializes the core. |
![]() | Object | ||
![]() | DrawingExceptionOverlayEventArgs | Overlay | Handles the event. |
![]() | DrawnExceptionOverlayEventArgs | Overlay | Handles the event. |
![]() | SendingWebRequestEventArgs | This method saves overlay state to a byte array. | |
![]() | SentWebRequestEventArgs | Handles the event. | |
![]() | TransformArguments, MapArguments | Overlay(overriden) | |
![]() | Overlay | Refreshes the core. |
![]() | String | Overlay | Gets or sets the attribution. |
![]() | Collection<Uri> | Gets the custom server uris. | |
![]() | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
![]() | DrawingQuality | Overlay | Gets or sets the drawing quality. |
![]() | Boolean | TileOverlay | Gets or sets a value indicating whether this instance is cache only. |
![]() | Boolean | Overlay | Gets a value indicating whether this instance is empty. |
![]() | MapArguments | Overlay | Gets or sets the map arguments. |
![]() | String | Overlay | Gets or sets the name. |
![]() | Double | Overlay | Gets or sets the opacity. |
![]() | UIView | Overlay | Gets or sets the overlay view. |
![]() | BitmapTileCache | Gets or sets the projected tile cache. | |
![]() | Projection | Gets or sets the projection from spherical mercator. | |
![]() | BitmapTileCache | TileOverlay(overriden) | Gets or sets the tile cache. |
![]() | Int32 | TileOverlay | Gets or sets the height of the tile. |
![]() | TileSnappingMode | TileOverlay | Gets or sets the tile snapping mode. |
![]() | TileType | TileOverlay | Gets and sets the overlay is formed by multiple tiles or single tile. |
![]() | Int32 | TileOverlay | Gets or sets the width of the tile. |
![]() | Int32 | Gets or sets the length of time, in seconds, before the request times out. | |
![]() | TransitionEffect | TileOverlay | Gets or sets the transition effect. |
![]() | GeoWebProxy | Gets or sets the WebProxy for using OpenStreet map service. |
![]() | UIView | TileOverlay | Gets or sets the drawing view. |
![]() | UIView | TileOverlay | Gets or sets the stretch view. |
![]() | DrawingExceptionOverlayEventArgs | Overlay | This event raises when exception. |
![]() | DrawnExceptionOverlayEventArgs | Overlay | This event raises when exception. |
![]() | SendingWebRequestEventArgs | Occurs when web request. | |
![]() | SentWebRequestEventArgs | Occurs when web request. |
Name | Type | Description |
webProxy | GeoWebProxy<!– ThinkGeo.MapSuite.Core.GeoWebProxy –> | This parameter indicates a WebProxy for requesting image from OpenStreet imagery service. |
Return Type | Description |
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.iOSEdition.Overlay –> Go Back
mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | This parameter indicates an mapArguments to draw the overlay. |
refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.iOSEdition.OverlayRefreshType –> | This parameter indicates whether this overlay needs to be refresh or not. |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape value for the overlay. |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | The map arguments. |
transformInfo | TransformArguments<!– ThinkGeo.MapSuite.iOSEdition.TransformArguments –> | The transform information. |
String<!– System.String –> |
Closes the core.
<!– ThinkGeo.MapSuite.iOSEdition.Overlay(overriden) –> Go Back
isDisposing | Boolean<!– System.Boolean –> |
mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | |
geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | The geo canvas. |
exception | Exception<!– System.Exception –> | The exception. |
ex | Exception<!– System.Exception –> | The ex. |
tile | TileView<!– ThinkGeo.MapSuite.iOSEdition.TileView –> | A Tile object that is created by the GetTile() method to draw. |
mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | A mapArguments for drawing the passed tile. |
<!– ThinkGeo.MapSuite.iOSEdition.TileOverlay –> Go Back
tile | TileView<!– ThinkGeo.MapSuite.iOSEdition.TileView –> | A tile object that creating by the GetTileCore method. It's the tile which needs to be draw in this mehtod. |
<!– ThinkGeo.MapSuite.iOSEdition.TileOverlay(overriden) –> Go Back
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
TileView<!– ThinkGeo.MapSuite.iOSEdition.TileView –> | A concrete Tile object that for requesting images from OpenStreet serverice. |
TileMatrix<!– ThinkGeo.MapSuite.Core.TileMatrix –> | TileMatrix. |
scale | Double<!– System.Double –> | The scale. |
tileWidth | Int32<!– System.Int32 –> | Width of the tile. |
tileHeight | Int32<!– System.Int32 –> | Height of the tile. |
boundingBoxUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | The bounding box unit. |
Collection<TileMatrixCell><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.TileMatrixCell} –> | Collection<TileMatrixCell>. |
mapUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | The map unit. |
targetExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target extent. |
targetScale | Double<!– System.Double –> | The target scale. |
mapArgument | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | The map argument. |
Handles the event.
args | DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawingExceptionOverlayEventArgs –> | The instance containing the event data. |
Handles the event.
args | DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawnExceptionOverlayEventArgs –> | The instance containing the event data. |
Void<!– System.Void –> | A byte array indicates current overlay state. |
e | SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SendingWebRequestEventArgs –> | The instance containing the event data. |
<!– ThinkGeo.MapSuite.iOSEdition.OpenStreetMapOverlay –> Go Back
Handles the event.
e | SentWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SentWebRequestEventArgs –> | The instance containing the event data. |
transformInfo | TransformArguments<!– ThinkGeo.MapSuite.iOSEdition.TransformArguments –> | |
Refreshes the core.
Return Type |
Return Type |
Collection<Uri><!– System.Collections.ObjectModel.Collection{System.Uri} –> |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –> |
Return Type |
DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
UIView<!– MonoTouch.UIKit.UIView –> |
Return Type |
BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> |
Return Type |
Projection<!– ThinkGeo.MapSuite.Core.Projection –> |
Return Type |
Return Type |
Return Type |
TileSnappingMode<!– ThinkGeo.MapSuite.iOSEdition.TileSnappingMode –> |
Return Type |
TileType<!– ThinkGeo.MapSuite.iOSEdition.TileType –> |
Return Type |
Return Type |
Return Type |
TransitionEffect<!– ThinkGeo.MapSuite.iOSEdition.TransitionEffect –> |
Return Type |
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
NOTOC iOSEdition ThinkGeo.MapSuite.iOSEdition UpdateDocumentation
