<!– Class –> This class inherits from Overlay abstract class. This specified overlay describe the interactive process with MapControl using Mouse or Keyboard.
*System.Object ThinkGeo.MapSuite.iOSEdition.Overlay *ThinkGeo.MapSuite.iOSEdition.InteractiveOverlay ThinkGeo.MapSuite.iOSEdition.EditInteractiveOverlay ThinkGeo.MapSuite.iOSEdition.ExtentInteractiveOverlay ThinkGeo.MapSuite.iOSEdition.TrackInteractiveOverlay
![]() | Initializes a new instance of the class. |
![]() | Overlay | Closes this instance. | |
![]() | Overlay | Disposes this instance. | |
![]() | InteractionArguments | Doubles the tap. | |
![]() | MapArguments, OverlayRefreshType | Overlay | This method draws the overlay by the specified arguments. |
![]() | Object | Object | |
![]() | Overlay | Gets the bounding box. | |
![]() | Object | ||
![]() | Object | ||
![]() | MapArguments | Overlay | Initializes the specified map arguments. |
![]() | InteractionArguments | Longs the press. | |
![]() | TransformArguments, MapArguments | Overlay | Posts the transform for the overlay. |
![]() | Overlay | Refreshes this instance. | |
![]() | InteractionArguments | Singles the tap. | |
![]() | Object | ||
![]() | InteractionArguments | Touches down. | |
![]() | InteractionArguments | Touches the move. | |
![]() | InteractionArguments | Touches the pointer down. | |
![]() | InteractionArguments | Touches up. |
![]() | String | Overlay | Gets or sets the attribution. |
![]() | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
![]() | DrawingQuality | Overlay | Gets or sets the drawing quality. |
![]() | TileView | Gets or sets the interactive view. | |
![]() | Boolean | Overlay | Gets a value indicating whether this instance is empty. |
![]() | Boolean | Overlay | Gets or sets a value indicating whether this instance is visible. |
![]() | MapArguments | Overlay | Gets or sets the map arguments. |
![]() | String | Overlay | Gets or sets the name. |
![]() | Double | Overlay | Gets or sets the opacity. |
![]() | UIView | Overlay | Gets or sets the overlay view. |
![]() | DrawingExceptionOverlayEventArgs | Overlay | This event raises when exception. |
![]() | DrawnExceptionOverlayEventArgs | Overlay | This event raises when exception. |
Name | Type | Description |
Return Type | Description |
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.iOSEdition.Overlay –> Go Back
Doubles the tap.
InteractiveResult<!– ThinkGeo.MapSuite.iOSEdition.InteractiveResult –> | InteractiveResult. |
e | InteractionArguments<!– ThinkGeo.MapSuite.iOSEdition.InteractionArguments –> | The e. |
<!– ThinkGeo.MapSuite.iOSEdition.InteractiveOverlay –> Go Back
mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | This parameter indicates an mapArguments to draw the overlay. |
refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.iOSEdition.OverlayRefreshType –> | This parameter indicates whether this overlay needs to be refresh or not. |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape value for the overlay. |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | The map arguments. |
Longs the press.
transformInfo | TransformArguments<!– ThinkGeo.MapSuite.iOSEdition.TransformArguments –> | The transform information. |
Singles the tap.
String<!– System.String –> |
Touches down.
Touches the move.
Touches up.
Closes the core.
Releases unmanaged and - optionally - managed resources.
isDisposing | Boolean<!– System.Boolean –> | true to release both managed and unmanaged resources; false to release only unmanaged resources. |
<!– ThinkGeo.MapSuite.iOSEdition.Overlay(overriden) –> Go Back
Doubles the tap core.
Draws the core.
refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.iOSEdition.OverlayRefreshType –> | Type of the refresh. |
Draws the exception.
geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | The geo canvas. |
exception | Exception<!– System.Exception –> | The exception. |
Draws the exception core.
ex | Exception<!– System.Exception –> | The ex. |
Gets the bounding box core.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
Initializes the core.
mapArgument | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | The map argument. |
Longs the press core.
Handles the event.
args | DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawingExceptionOverlayEventArgs –> | The instance containing the event data. |
Handles the event.
args | DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawnExceptionOverlayEventArgs –> | The instance containing the event data. |
Posts the transform core.
Refreshes the core.
Singles the tap core.
Touches down core.
Touches the move core.
Touches the pointer down core.
Touches up core.
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –> |
Return Type |
DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
Return Type |
TileView<!– ThinkGeo.MapSuite.iOSEdition.TileView –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Double<!– System.Double –> |
Return Type |
UIView<!– MonoTouch.UIKit.UIView –> |
Event Arguments |
Event Arguments |
NOTOC iOSEdition ThinkGeo.MapSuite.iOSEdition UpdateDocumentation
