<!– Class –> This class represents the Overlay used to display a Google Map.
*System.Object ThinkGeo.MapSuite.iOSEdition.Overlay *ThinkGeo.MapSuite.iOSEdition.TileOverlay ThinkGeo.MapSuite.iOSEdition.GoogleMapsTileOverlay
![]() | This is the constructor of the class. | ||
![]() | String, String, String | This is the constructor the for the class. | |
![]() | String, String, String, GeoWebProxy | This is the constructor the for the class. |
![]() | String, TimeSpan, Double | ||
![]() | Overlay | Closes this instance. | |
![]() | Overlay | Releases the unmanaged resources. | |
![]() | Releases the unmanaged resources. | ||
![]() | MapArguments, OverlayRefreshType | Overlay | This method draws the overlay by the specified arguments. |
![]() | Object | Object | |
![]() | Overlay | Gets the bounding box. | |
![]() | Object | ||
![]() | This method gets a string that represents the picture format from Google Maps. | ||
![]() | Object | ||
![]() | MapArguments | Overlay | Initializes the specified map arguments. |
![]() | TransformArguments, MapArguments | Overlay | Posts the transform for the overlay. |
![]() | Overlay | Refreshes this instance. | |
![]() | Object |
![]() | String | Overlay | Gets or sets the attribution. |
![]() | String | This property gets or sets the tile cache directory. | |
![]() | String | Gets or sets a value to access the special features of Google Maps API Premier, you must provide a client ID when accessing any of the Premier API libraries or services. When registering for Google Maps API Premier, you will receive this client ID from Google Enterprise Support. All client IDs begin with a gme- prefix. | |
![]() | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
![]() | DrawingQuality | Overlay | Gets or sets the drawing quality. |
![]() | Boolean | TileOverlay | Gets or sets a value indicating whether this instance is cache only. |
![]() | Boolean | Overlay | Gets a value indicating whether this instance is empty. |
![]() | Boolean | Overlay(overriden) | |
![]() | MapArguments | Overlay | Gets or sets the map arguments. |
![]() | GoogleMapsMapType | This property gets or sets the map types available from Google Maps. | |
![]() | Double | ||
![]() | String | Overlay | Gets or sets the name. |
![]() | Double | Overlay | Gets or sets the opacity. |
![]() | UIView | Overlay | Gets or sets the overlay view. |
![]() | GoogleMapsPictureFormat | This property gets or sets the picture format that is returned from the Google service. | |
![]() | String | Gets or sets a value that is unique to your client ID, please keep your key secure. | |
![]() | BitmapTileCache | TileOverlay(overriden) | |
![]() | TimeSpan | ||
![]() | Int32 | TileOverlay | Gets or sets the height of the tile. |
![]() | TileSnappingMode | TileOverlay | Gets or sets the tile snapping mode. |
![]() | TileType | TileOverlay | Gets and sets the overlay is formed by multiple tiles or single tile. |
![]() | Int32 | TileOverlay | Gets or sets the width of the tile. |
![]() | Int32 | Gets or sets a value represents the request timeout from the GoogleMaps server. | |
![]() | TransitionEffect | TileOverlay | Gets or sets the transition effect. |
![]() | GeoWebProxy | This property gets or sets the proxy used for requesting a Web Response. |
![]() | UIView | TileOverlay | Gets or sets the drawing view. |
![]() | UIView | TileOverlay | Gets or sets the stretch view. |
![]() | DrawingExceptionOverlayEventArgs | Overlay | This event raises when exception. |
![]() | DrawnExceptionOverlayEventArgs | Overlay | This event raises when exception. |
![]() | SendingWebRequestEventArgs | ||
![]() | SentWebRequestEventArgs |
If you use this constructor, you have to set the properties manually before use, otherwise it will use their default values.
Name | Type | Description |
This constructor initializes a new layer and assgin a license key.
cacheDirectory | String<!– System.String –> | The cacheDirectory for the GoogleMapsOverlay. |
clientId | String<!– System.String –> | The clientId for the GoogleMapsOverlay. |
privateKey | String<!– System.String –> | The privateKey for the GoogleMapsOverlay. |
webProxy | GeoWebProxy<!– ThinkGeo.MapSuite.Core.GeoWebProxy –> |
Return Type | Description |
Void<!– System.Void –> |
cacheFolder | String<!– System.String –> | |
tileExpiration | TimeSpan<!– System.TimeSpan –> | |
maxSizeInMegabytes | Double<!– System.Double –> |
<!– ThinkGeo.MapSuite.iOSEdition.GoogleMapsTileOverlay –> Go Back
<!– ThinkGeo.MapSuite.iOSEdition.Overlay –> Go Back
mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | This parameter indicates an mapArguments to draw the overlay. |
refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.iOSEdition.OverlayRefreshType –> | This parameter indicates whether this overlay needs to be refresh or not. |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape value for the overlay. |
Int32<!– System.Int32 –> |
String<!– System.String –> | Returns a string representing the picture format from GoogleMaps. |
Type<!– System.Type –> |
mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | The map arguments. |
transformInfo | TransformArguments<!– ThinkGeo.MapSuite.iOSEdition.TransformArguments –> | The transform information. |
Closes the core.
isDisposing | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.iOSEdition.Overlay(overriden) –> Go Back
mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | |
Draws the exception.
geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | The geo canvas. |
exception | Exception<!– System.Exception –> | The exception. |
Draws the exception core.
ex | Exception<!– System.Exception –> | The ex. |
Redraws a specified tile with the provided world extent.
tile | TileView<!– ThinkGeo.MapSuite.iOSEdition.TileView –> | A Tile object that is created by the GetTile() method to draw. |
mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | A mapArguments for drawing the passed tile. |
<!– ThinkGeo.MapSuite.iOSEdition.TileOverlay –> Go Back
geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | |
<!– ThinkGeo.MapSuite.iOSEdition.TileOverlay(overriden) –> Go Back
Gets the bounding box core.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
Chooses a tile object to form the TileOverlay. When overriding this method, consider the initialize parameters setting on the tile.
Gets the tile matrix for TileOverlay.
TileMatrix<!– ThinkGeo.MapSuite.Core.TileMatrix –> | TileMatrix. |
scale | Double<!– System.Double –> | The scale. |
tileWidth | Int32<!– System.Int32 –> | Width of the tile. |
tileHeight | Int32<!– System.Int32 –> | Height of the tile. |
boundingBoxUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | The bounding box unit. |
Gets the tile matrix cells for TileOverlay.
Collection<TileMatrixCell><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.TileMatrixCell} –> | Collection<TileMatrixCell>. |
mapUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | The map unit. |
targetExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target extent. |
targetScale | Double<!– System.Double –> | The target scale. |
Initializes the core.
mapArgument | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | The map argument. |
Handles the event.
args | DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawingExceptionOverlayEventArgs –> | The instance containing the event data. |
Handles the event.
args | DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawnExceptionOverlayEventArgs –> | The instance containing the event data. |
e | SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SendingWebRequestEventArgs –> |
e | SentWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SentWebRequestEventArgs –> |
transformInfo | TransformArguments<!– ThinkGeo.MapSuite.iOSEdition.TransformArguments –> | |
Refreshes the core.
Return Type |
Return Type |
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –> |
Return Type |
DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
GoogleMapsMapType<!– ThinkGeo.MapSuite.Core.GoogleMapsMapType –> |
Return Type |
Return Type |
Return Type |
Return Type |
UIView<!– MonoTouch.UIKit.UIView –> |
Return Type |
GoogleMapsPictureFormat<!– ThinkGeo.MapSuite.Core.GoogleMapsPictureFormat –> |
Return Type |
Return Type |
BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> |
Return Type |
Return Type |
Return Type |
TileSnappingMode<!– ThinkGeo.MapSuite.iOSEdition.TileSnappingMode –> |
Return Type |
TileType<!– ThinkGeo.MapSuite.iOSEdition.TileType –> |
Return Type |
Return Type |
Return Type |
TransitionEffect<!– ThinkGeo.MapSuite.iOSEdition.TransitionEffect –> |
Return Type |
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
NOTOC iOSEdition ThinkGeo.MapSuite.iOSEdition UpdateDocumentation
