<!– Class –>
*System.Object GalaSoft.MvvmLight.ObservableObject *GalaSoft.MvvmLight.ViewModelBase ThinkGeo.MapSuite.GisEditor.DataRepositoryContentViewModel
DataRepositoryContentViewModel |
Cleanup | ViewModelBase | ||
FromXml | XElement | ||
![]() RestoreChildrenExpandStatus | ObservableCollection<DataRepositoryItem>, Collection<String> | ||
![]() RestoreExpandStatus | DataRepositoryItem | ||
SearchChildren | IEnumerable<String> | ||
ToString | Object | ||
ToXml | |||
VerifyPropertyName | String | ObservableObject |
Broadcast | T, T, String | ViewModelBase | |
MemberwiseClone | Object | ||
RaisePropertyChanged | String, T, T, Boolean | ViewModelBase | |
RaisePropertyChanged | Expression<Func<T», T, T, Boolean | ViewModelBase | |
RaisePropertyChanged | String | ObservableObject | |
RaisePropertyChanged | Expression<Func<T» | ObservableObject | |
Set | String, ref T, T, Boolean | ViewModelBase | |
Set | Expression<Func<T», ref T, T | ObservableObject | |
Set | Expression<Func<T», ref T, T, Boolean | ViewModelBase | |
Set | String, ref T, T | ObservableObject |
AddDataCommand | ICommand | ||
Children | ObservableCollection<DataRepositoryItem> | ||
ContentVisibility | Visibility | ||
ContextMenuStackPanel | StackPanel | ||
![]() Current | DataRepositoryContentViewModel | ||
CurrentPluginItemViewModel | DataRepositoryItem | ||
IsInDesignMode | Boolean | ViewModelBase | |
PlaceOnMapCommand | ICommand | ||
RefreshCommand | RelayCommand | ||
RemoveCommand | ObservedCommand | ||
SearchCommand | RelayCommand | ||
SearchContent | ListBox | ||
SearchResult | DataRepositoryItem | ||
SearchResultVisibility | Visibility | ||
SearchText | String | ||
![]() SelectedDataRepositoryItem | DataRepositoryItem |
MessengerInstance | IMessenger | ViewModelBase | |
PropertyChangedHandler | PropertyChangedEventHandler | ObservableObject |
PropertyChanged | PropertyChangedEventArgs | ObservableObject |
<!– GalaSoft.MvvmLight.ViewModelBase –> Go Back
| state | XElement<!– System.Xml.Linq.XElement –> |
<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryContentViewModel –> Go Back
<!– static –>
| treeViewChildren | ObservableCollection<DataRepositoryItem><!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.GisEditor.DataRepositoryItem} –> | |
| expandStatus | Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> |
<!– static –>
| viewModel | DataRepositoryItem<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryItem –> |
| keywords | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> |
| propertyName | String<!– System.String –> |
<!– GalaSoft.MvvmLight.ObservableObject –> Go Back
| oldValue | T<!– T –> | |
| newValue | T<!– T –> | |
| propertyName | String<!– System.String –> | |
| broadcast | Boolean<!– System.Boolean –> |
| propertyExpression | Expression<Func<T»<!– Expression{Func{T}} –> | |
| field | ref T<!– T –> | |
| ICommand<!– System.Windows.Input.ICommand –> |
| Visibility<!– System.Windows.Visibility –> |
| StackPanel<!– System.Windows.Controls.StackPanel –> |
<!– static –>
| DataRepositoryContentViewModel<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryContentViewModel –> |
| RelayCommand<!– GalaSoft.MvvmLight.Command.RelayCommand –> |
| ObservedCommand<!– ThinkGeo.MapSuite.GisEditor.ObservedCommand –> |
| ListBox<!– System.Windows.Controls.ListBox –> |
<!– static –>
| IMessenger<!– GalaSoft.MvvmLight.Messaging.IMessenger –> |
| PropertyChangedEventHandler<!– System.ComponentModel.PropertyChangedEventHandler –> |
| Event Arguments |
| PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
