map_suite_services_edition_faq_all_questions
Table of Contents
Map Suite Services Edition FAQ All Questions
What type of applications are best suited for Map Suite Services Edition?
Any back-end applications that don't require a user interface are best suited for the Services Edition. Examples of these would include web services, Windows services, console applications, or batch applications. If your mapping application requires a user interface element, the Map Suite Desktop, Web, or Silverlight Editions may be a better fit.
How does Map Suite Services Edition work with my application?
Map Suite Services Edition is a DLL component that can be easily referenced in your VB.NET or C# project. Once you have added the reference to the Map Suite Services Edition DLL, you have complete access to the APIs needed to build the custom functionality for your application.
What other software is required to work with Map Suite Services Edition?
To work with Map Suite Services Edition, you will need a copy of Microsoft Visual Studio or Visual Studio Express to build the code for your custom application.
What type of map data does Map Suite Services Edition Support?
Map Suite Services Edition lets you use virtually any map dataset of your choosing. If you have your own map data you can use it, or you can utilize our Map Suite World Map Kit extension or other base maps like Google Maps, just to name a few options.
Map Suite Services Edition comes with native support for the most popular vector and raster file formats, and includes a free extension that enables support for more than a dozen more vector formats and more than 80 raster formats. If you have spatial data or imagery, chances are you can use it with Map Suite. Check our Developer Blog for the master list of data formats that Map Suite currently supports.
How big of a learning curve is there to using Map Suite Services Edition?
Map Suite Services Edition was designed to be easy to understand and easy to use. While mapping/GIS controls typically have a larger learning curve than other simpler controls like grids or charts, we feel Map Suite has taken the complexity out of mapping and allows you to develop your application in days or weeks instead of months or years.
Where do I go if I need help with Map Suite Services Edition?
We have a very active Developer Community discussion forum, a large number of "How Do I?" sample applications with source code in VB.NET and C#, and we also offer professional services if you need to talk with a developer one-on-one.
What is the difference between Map Suite Services Edition and the Web and Desktop Editions?
Map Suite Services Edition is a lower-level component that is built for back-end applications like web services, Windows services and console applications. The Services Edition doesn't have any built-in functionality for user interface interactivity, where the Desktop and Web Editions do.
Yes. We offer a number of Map Suite add-ons that extend the functionality and map coverage of your application, including the World Map Kit dataset plugin, and the Routing Extension that generates routes, turn-by-turn directions and more. Additionally, check out the Map Suite Code Community for an ever-expanding number of add-on projects that bring new features and ideas to your Map Suite projects - there's something new each week.
How do I reprojected a decimal degrees shape file to display on Google Maps?
Sample:Shapefile to Google Map
How do I show GPS data in decimal degrees on Google Maps?
Sample:GPS to Google Map(Desktop)
Today we have the Desktop version of the Web project “GPS to Google”. In this project, we show how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
How do I show a great circle line on Google Maps?
Sample:Great Circle with Google Map
How do I show a mini map on Google Maps?
Sample:Mini map with Google Map
How can I display decimal degrees as degrees, minutes and seconds?
How do I control how labels are displayed based on fields in the data?
Sample:Labeling Based On Columns
How do I adjust the size of the labels based on feature column data?
Sample:Labeling based on size
How do I use multiple columns in one label?
Sample:Multi Column Labeling
How do I display multi labels for a given feature?
Sample:Multiple Labels
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “[ColumnName1][ColumnName2]” and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
How do I display multi line labeling?
Sample:MultiLine Labeling
For more information you can see the discussion forum post below: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6955/afv/topic/Default.aspx
How do I save or serialize my objects once I have created them?
Sample: Serialize To Xml
This sample shows you how to serialize objects in Map Suite to XML and then deserialze them back to objects. This is usefully in many GIS mapping application to save the state of styles, layers, projections or just about anything. The XML is readable and well formatted, great for working with in you GIS application.
How do I generate source code from objects once I have created them?
Sample: Code Generator
This sample shows you how to generate source code calls from Map Suite objects. Imagine that you have a Layer that has been styled a particular way and uses a certain projection. Once the object is created you can pass it to the code generator and it will create source code to re-create the model passed in. This is very helpful especially in GIS applications where users define things through a custom UI but then want to leverage that in code.
How do I export the current extent to a geo-referenced bitmap?
Sample:Current Extent to Bitmap
How do I create a custom scale bar that is accurate in another projection?
Sample:Custom Scale Bar
How do I use the map with the MVC framework?
Sample:Use Map with MVC Framework
How can I draw an exception instead of being thrown during drawing?
Sample:Draw Custom Exception
How do I convert the current extent of a raster layer to a bitmap?
Sample:Raster Layer to Bitmap
How do I have a map in an MDI form?
Sample:MDI Form
How do I display world coordinate on a map?
Sample:World Coordinates
The purpose of this project is to complete the section “Screen & World Coordinates” of the “How Do I?” sample apps. You will learn how to display world coordinates at the mouse event. Notice that the Layer is in Mercator projection and we use a projection conversion to display Longitude and Latitude in addition to the world coordinates values in meters from the Mercator projection. Also, we are reusing the DecimalDegrees static class we used in a previous project for formatting decimal degrees.
How do I display proper world coordinates when a map is being rotated?
Sample:World Coordinate with Rotation
How can I change the datum while keeping the projection the same?
Sample:Datum Transformation
How do I get the intersecting point of two streets?
Sample:Street Intersection
How do I know which state plane projection to use based on a decimal degree point?
Sample:Geodetic to State Plane
How do I automatically project my decimal degree data to UTM?
Sample:Geodetic to UTM on the fly
The appropriate EPSG number for our example can be found at: http://spatialreference.org/
How do I convert shape file data from one projection to another?
Sample:Save To Projection
How do I route in one projection and display the route information in another projection?
Sample:Routing with Projections
How do I show a great circle line across the pacific rim?
Sample:Great Circle on Pacific Rim
How can I visualize the distortion of a projection will cause on my data?
Sample:Projection Distortion
How do I display a polygon across the Meridian?
Sample:Polygon across Meridian
Following a request from the Discussion Forum on how to handle cases where the shape straddles the 180 degree meridian on a Decimal Degree map, we created this project. The solution is to split the shape into two main parts to be displayed on the two ends of the map. In this case, we use the case of a Polygon but this could easily be adapted for any other shapes such as lines.
How can I get an accurate measurement between two points in decimal degrees?
Sample:Measurements Decimal Degrees
This project is in response to a Discussion Forum post that has generated plenty of debate on the meaning of measuring area for shapes in decimal degrees. In this project, you will see how to get area and length measurements according to the projection used from a shape in decimal degrees. For more information on why different measurements can be obtained from the same shapes, please read the Discussion Forum “GetArea on Buffered shape not working as expected” http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6565/afv/topic/Default.aspx
How do you display the Pacific Rim area?
Sample:Pacific Rim
This project shows how to display the Pacific Rim and Asia if you pan to the west, so that the world “wraps around,” as it does with Google Maps. Many of our Map Suite sample applications include an example of the world being displayed using a world ShapeFile. The ShapeFile is in Decimal Degrees and it displays the world according to longitude and latitude value ranges. These ranges are from -180 to 180 for longitude and 90 to -90 for latitude. In our various examples that use this ShapeFile, you see the Western Hemisphere on the left and the Eastern Hemisphere on the right. Now, a common request that we receive is to display the Pacific Rim and Asia if you pan to the west, so that the world “wraps around,” as it does with Google Maps. This can be accomplished in Map Suite 3.x by using a custom projection that offsets all of the points by 360 for the x (longitude) values. (180 + 180 = 360). You will see how to create OffsetProjection class inheriting from Projection. Notice the code in the overrided method GetexternalProjection. It simply loops thru all the points making each feature and offset the X value by 360.
How to use custom parameters projection?
Sample:Custom Parameters Projection
How to use custom rotation projection?
Sample:Custom Rotation Projection
How to use local datum UTM?
Sample:Local Datum UTM
The purpose of this Wpf sample is to get familiar with the concept of datum and datum shift in UTM and Geographic coordinates. Using local data, you might be required to apply datum transformation to your data to go from an old datum to a more recent datum. Here we are taking the example of Australia which went to change its datum (from AGD84 to GDA94) for its mapping purposes. We show how to apply the datum transformation in both the longitude/latitude coordinate system and in the local UTM systems (AMG based on AGD84 and MGA based on GD94). See the code and read with attention the comments in the MouseMove event where all the projection logic is taken place. Notice that the correction is about 200 meters. Once you understand for the case of Australia, you will be able to apply the same principles for your own datums in UTM. For further reading: http://www.cage.curtin.edu.au/~will/datum.html http://www.usq.edu.au/course/material/SVY3107/lectures/Breeze/SVY2106amgmgafund/index.html
How to google Map to Geodetic?
Sample:Google Map to Geodetic
In today’s Wpf project, we are showing a trick for getting the current extent of the map with Google Map as an image and displaying it on a map in decimal degrees unit. You may be in a situation where you want the details and accuracy of Google Map, especially the satellite view but want to have it displayed on your map in decimal degrees. In this sample, you will see how to get the Google Map image and create the accompanying world file for decimal degrees. Notice that we are realizing an affine transformation on the image to go to Geodetic as illustrated in the case 3 http://en.wikipedia.org/wiki/World_file#Definition. You can also use this technique for any other background maps such as Bing Map, Open Street Map using Spherical Mercator. Warning: It is possible to use a world file with parameters for a Geodetic system from an image originally in Spherical Mercator due to some similar projection characteristics. Applying the same operation for other projections such as Lambert or UTM will not work.
How to wrap dateline with projection?
Sample:Wrap Dateline Mode With Projection
How to use Spherical Mercator Projection Adjustment?
Sample:Spherical Mercator Projection Adjustment
The purpose of this sample is to address a projection issue that you may encounter when converting your data from your local projection to Google Map. It has been reported by Map Suite users that in some cases reprojecting their data to Google Map or other base maps using Spherical Mercator (Bing Map, Open Street Map etc) is inaccurate with the data being shifted a few hundreds of meters. This problem has been identified as being caused by an unnecessary grid shift when going from ellipsoid datum to spherical datum. Among other projections, the British National Grid (BNG) and the German Gauss-Kruger system have that problem when going to Spherical Mercator. This sample uses the example of BNG to demonstrate the problem and how to fix it. The Map Suite development team will offer a permanent solution to this projection issue but in the meantime, as a rule of thumb, if your data shows some inaccuracies when going to Spherical Mercator, use the method you find this sample. This is a Desktop app but the concept shown applies to all editions of Map Suite.
How do I clip one point layer based on a polygon?
Sample:Clipping On Point Layer
How do I clip one polygon layer based on a polygon?
Sample:Clipping
How do I create a convex hull around a feature?
Sample:Convex Hull
ConvexHull is a geometric function that returns the smallest ring containing all the points of a shape. Another way to think about it is to imagine a set of points on a plane as nails pounded into a board. If you wrap the entire set with a rubber band snapping it into place, it will form a convex hull, which is the minimum-energy wrapper that encloses all the points. This is the theory, now you may be wondering what the practical use of this is in GIS. In today’s project, we show how to contruct a convex hull polygon from a set of point in a concrete situation of oil rigs offshore. Creating a convex hull could be used to determine the perimeter for constructing a barrier around the oil rigs to help protect from hurricanes. It could also be used for a barrier to keep spilled oil contained within.
How do I snap line based nodes together based on a tolerance?
Sample:Correcting Nodes
As for the projects “Spatial Join” and “Dissolve”, in this project we see how to edit FeatureLayers. In this case, we show some techniques to clean up a line based layer. You may be in a situation where you have to do that on a layer representing a network. Due to a poor digitizing, the end nodes of the lines don’t touch each other showing disconnected when in fact they should be connected. In this project, we show the technique to correct the location of the end vertices (nodes) so that they connect to each other. Keep in mind that the logic for correcting nodes shown here, is very simple and does not take into account various parameters such as tolerance, line order, multi line intersection etc. This logic works in the case of having an ordered sequential network as it is often digitized. The full logic taking into account all the different scenarios is vastly more complicated. We plan to offer this full logic in the future as an API within our core product. Also, notice that we create a custom LineStyle, NodeLineStyle for the purpose of showing the start and end nodes of each line as different color than the body of the line.
How do I create inner rings for track polygon?
Sample:Create Inner Ring
How do I create a polygon programatically?
Sample:Create Polygon Programatically
How do I draw a pie shape with a sweep angle as in radar applications?
Sample:Sweep Angle
Sample:Sweep Angle Desktop
How do I dissolve a shape file based on a common attribute? & 2 answers
Sample:Dissolve on Shapefile
In this small project, you will see the technique to dissolve a shapefile based on a common attribute using some key methods such as Union static method to efficiently union together a large number of shapes. You will also find useful the code for creating a shapefile from scratch. This project will soon be followed by another project on how to apply statistics when dissolving a shapefile. Also, there will be another related project on how to do Dissolve on a generic FeatureSource.
Sample:Dissolve with Statistics
How do I split polygon based on an intersecting line?
Sample:Split Polygon
How do I perform spatial join?
Sample:Spatial Join
This project shows how to perform a Spatial Join on a point Layer based on a Polygon layer. It adds the relevant info to the point layer based on the spatial characteristics of the features of the point layer in comparison to the polygon layer. For example, we have two layers. One is polygon layer of the countries; the other is point layer of the cities. We don’t have any attribute information about what country each city belongs to. We can perform a Spatial Join to add that info to the point layer. A Spatial Join looks at what country of the polygon layer, each city belongs to using a spatial query. Spatial Join requires handling various techniques such as creating, updating layer and spatial queries in one coherent function. In this project, you will also see the technique of displaying a label based on more then one columns. In this example, we show a Spatial Join based on containing rule. Other types of Spatial Joins can be performed based on proximity, or some other topological rules. Later, we will show other projects of Spatial Joins.
How can I draw a pie shape defined by an ellipse?
Sample:Draw a Pie shape
For more information, please see the discussion forum post below: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6963/afv/topic/Default.aspx
How can I perform dynamic segmentation?
Sample:Dynamic Segmentation
The key method used here is GetLineOnLine that offers many parameters to get a segment of an existing line. In our example, we get a line segment based on a distance from the start and the length. You can see how this could be applied for application such closing a segment of a highway after an accident for example. This project will be followed by other more advanced projects related to Dynamic Segmentation.
How do I suppress features from being drawn in a layer?
Sample:FeatureIdsToExclude
How do I remove a LineShape from a MultiLineShape?
Sample:Remove LineShape
How do I register a shape to the ground from a non-geographic coordinate system?
Sample:Register Shape
In this sample, we show a geometric function that allows tying to the ground or registering shapes from some non geographic coordinate to the map (in world coordinates). To better understand how useful this can be for your mapping needs, imagine the following scenario: You have some geometric shapes in a CAD for chemical plume. In a CAD or specialized program generating chemical models, you can do all your scientific manipulation, transformation etc. Once you are finished generating the chemical models with your specialized program, you are ready to put it on the map. Using anchor points, one of origin and one of destination, you can tie to the ground the shapes with the help of the Register function. This operation cannot be confused with Projection. Projecting a shape means going from one geographic projection to another one, for example from Geodetic to Spherical Mercator and some deformation of the shape can occur. Registering is simply placing a shape from a non geographic coordinate to a specific location on the map.
How do I identify a feature when clicking anywhere on its icon?
Sample:Identify Point with Icon
How do I determine if a point is inside an inner ring of a polygon?
Sample:Inner Ring Containment
How do I split a line based on an intersecting line?
Sample:Intersect Line
How do I handle self-intersecting polygons?
Sample:Intersecting Multi Polygon
How do I intersecting two layers?
Sample:Intersecting Two Layers
Let say you have a layer of stratigraphy and a layer of counties and you need to do some analysis based on info from the county layer and info from the stratigraphy layer. You can combine the two layers by intersecting them and get only the common data of the two layers while adding the attributes of both original layers. The resulting layer has geographical extent that is common to both layers (as for clipping) while adding the information from both original layers. As for other geoprocessing techniques, writing the code for Intersecting requires combining layer editing with geometric functions.
How do I merge two line layers?
Sample:Merge Line Layers
From the previous project, on the geoprocessing technique of merging point layers, here we show the same technique applied to line layers. Remember that an alternative approach to merging is to use a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx
How do I merge two point layers?
Sample:Merge Point Layers
An alternative approach to merging is to use a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx Next we will show how to do the same thing for line layers.
How do I treat multiple shape files as one shape file without physically merging them?
Sample:Merging Layers
If you have many files of the same type and representing the same type of features, Map Suite offers an API for building a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx
While this is very convenient, you may still want to combine all your files into one for maintenance purpose. This project shows the geoprocessing technique of accomplishing that task with merging. The logic for writing the merging algorithm is simpler than other geoprocessing tasks since no geometric functions are involved. Keep in mind that this project shows how to merge polygon based shapefiles into one. In the future, we will post a more generic project for layer of various format and type.
How do I move a point parallel to a line segment?
Sample:Offset Point at Right Angle
How do I buffer shapes based on multiple distances?
Sample:Multi Ring Buffering
How do I perform a negative buffer?
Sample:Negative Buffering
How to create a MultipolygonShape from various PolygonShapes?
Sample:Polygon Shapes To Multipolygon Shapes
How do I clip one line layer based on a polygon?
Sample:Clipping On Line Layer
How do I represent points using an animated GIF?
Sample: Animated Gif
In today’s project, we learn how to extend InMemoryFeatureLayer to have the ability to display animated gif for each layer in the Desktop edition. You will notice that for now, we are limited to have one animated gif per InMemoryFeatureLayer but in the future, we will show the technique to have a different animated gif for each feature of the InMemoryFeatureLayer.
Sample: Cached Value Style
How do I cluster multiple points into one point for display?
Sample:ClusterPointStyle
How do I display a label in real world dimensions?
Sample:World Sized Text Style
How do I display an icon in real world dimensions?
How do I word wrap my labels?
Sample:WordWrapped TextStyle
How do I draw features differently based on column values?
How do I display a point based on real time data such as the current time?
Sample:Time Based Point Style
How do I label each line in a MultiLineShape?
How can I show one-way streets arrows on my roads?
How do I draw a line with a different start and end style?
Sample:Start End LineStyle
How do I display the distance of a line as label?
Sample:Distance Line Style
How do I display a point as a doughnut shape?
Sample:Doughnut Point Style
How do I draw points where the size is proportional to a column value?
Sample:Sized Point Style
How do I rotate a side view icon based on its heading?
Sample:Side View Icon
Sample:EditOverlay Styles
How do I draw an icon that flashes?
Sample:Flashing Point Style
this project, we explore how to create a point style that flashes. Here we take the example of a vehicle moving around based on GPS location and flashes when entering prohibited zones. I think that this project will inspire people working on building a vehicle tracking application. This project is a general solution for a Servicess edition. Notice that we are using two MapEngines with one only for drawing the flashing vehicle to avoid redrawing the other layers at each flashing.
How do I make a text larger or smaller based on the current scale?
Sample:Scaling TextStyle
How do I make an icon larger or smaller based on the current scale?
Sample:Scaling Image Style
How do I create a custom style to display routes?
Sample:Routing Styles
Sample:Rotate Icon
Sample:Rotated Image Style
Sample:Vehicle Direction
How do I rotate a feature's text similar to word wrapping?
Sample:Hybrid TextStyle
This project is a follow up to the Discussion Forum post http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6652/afv/topic/Default.aspx Rotating the feature text (similar to wordwrap). In this project, we create a new Text Style combining word wrapping that we saw in the project http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
How do I set multiple dot density styles on the map?
How to create a cutomer valuestyle?
Sample:Default ValueStyle
How to create a line style with increment?
How to create a weather line style?
Sample:Weather Line Style
Sample:Isolines
How do I show a bread crumb trail behind a moving vehicle?
Sample: Bread Crumb Trail
Sample:Centering and Rotating
How can I display a chemical plume for spatial analysis?
Sample:Chemical Plume
In this project, we show how simple it is to display and do spatial analysis with chemical plumes. The US department of transportation sets standards for protection and isolation zones according to the type of chemical involved. You can find all that publicly available information at http://www.phmsa.dot.gov/
How can we update a moving vehicle when its position has changed?
Sample:Detect GPS
How do I snap a GPS coordinate to the closest street?
Sample:Snap GPS to Street
In this sample we are going to handle the common case of snapping a point to a set of features in a layer. The common case for this is snapping real-time GPS points to road layers. GPS has an error factor and it's nice to display vehicles on a map snapped to the roads they are on. It can also be used for a number of other different cases as well, such as finding not just the road position but the road name. You may display or store the road name for the trip in your database. In the sample we have set up a road layer; when you click on the map it will find the closest road segment within a tolerance and snap the point to that road. You can click repeatedly around a road and simulate GPS points coming in. Inside of the sample, we have encapsulated the functionality into a method that can easily support multiple layers, varying tolerances, and different data units.
How do you filter a radar image?
Sample:Filter Radar Image
NOAA (National Oceanic and Atmospheric Administration) makes available for the public Radar images http://radar.weather.gov/ridge/Conus/RadarImg/ Those images show the precipitation activities based on the whole range of dBz scale. (see http://en.wikipedia.org/wiki/DBZ_%28meteorology%29) You might want to keep only dBz scales superior to 20 which correspond to actual rain. You might also want to add some transparency to better show the layers below the radar image. This project shows how to filter the image for that purpose. You will see how to create a new filtered image better fit to be displayed on the map. You will find particularly interesting the power of using directly the GDI+ API which is very handy with dealing with a Map Suite GDIPlusRasterLayer.
Sample:Rotate Icon
How do I update the label for a moving vehicle?
Sample:Moving Vehicle with Label
How do I center my map using Decimal Degrees when I map is projected?
Sample:Center Map Based On Lat/Long
How do I zoom to the full extent based on a collection of layers?
Sample:Zoom to Full extent
Today we have the first project in the Map Suite WPF Desktop version. This is a simple project that shows how to set the current extent based on a collection of layers. You can use this technique for the common task of having the map set to the full extent. Instead of having to manually set the full extent, you can pass all the layers you want the full extent to be based on. This project will be followed by many other WPF projects due to the increasing popularity of that Map Suite version.
How do I add additional, more granular, ZoomLevels to the twenty predefined ZoomLevels?
Sample:Zoom Levels Partitioning
Map Suite API conveniently offers 20 predefined zoom levels to set the different styles. With those 20 predefined zoom levels, at any change of extent, the map will snap to the nearest zoom level. While this is appropriate in most cases, you may want a more granular control on the zoom levels. This project shows how to set intermediate zoom levels between the existing predefined ones for more granularity. Since the zoom levels are based on scales, you can still use the predefined zoom levels to set the styles and have the additional custom zoom levels for more refined control on zoom level snapping. In this project, we have the WorldMapKit WMS as a layer and a regular point based shapefile. You can see how the intermediate custom zoom levels have the effect of stretching the WMS image to better fit. This is a Desktop project and you will need the full or evaluation references to MapSuiteCore.dll, DesktopEdition.dll and WorldMapKitWms.dll.
How do I zoom in and center the map based on where the user clicked?
Sample:Zoom In To Point
This project is for DesktopEdition users. As for the project TrackZoomInWithoutShiftKey, we show how to create a new class from InteractiveOverlay. InteractiveOverlay is a powerful way to interact with the map but it currently lacks documentation. While this project does not substitute a good documentation, it shows some techniques for using that class. You can take a look at the overriding method MouseDownCore to see how in a few lines of code, you can allow the users to have the map zoomed in and centered to the location the map was clicked on. In the next major public release of Desktop Map Suite, we will present a more complete documentation on InteractiveOverlay.
How do I highlight and zoom in to a specific feature?
Sample:Zoom In To Feature
How can I create custom zoom levels?
Sample:Custom Zoom Levels
How do I get the current ZoomLevel when the scale changes?
Sample:GetZoomLevel
How do I load an image layer when I don't have a world file but know the extent?
Sample:Raster Layer with extent
How do I get and set the map scale?
Sample:Map Scales
How do I restrict extent for panning and restrict extent for zooming out?
Sample:Restricting Extent
map_suite_services_edition_faq_all_questions.txt · Last modified: 2015/09/16 06:22 by admin
