<!– Class –> This is the base class for TileCache system.
TileCahce system is very efficient in improving the performance of application, especially when large data or remote server images are included.
*System.Object ThinkGeo.MapSuite.Core.TileCache *ThinkGeo.MapSuite.Core.BitmapTileCache *ThinkGeo.MapSuite.Core.EncryptedFileBitmapTileCache *ThinkGeo.MapSuite.Core.FileBitmapTileCache *ThinkGeo.MapSuite.Core.FileNativeImageTileCache *ThinkGeo.MapSuite.Core.InMemoryBitmapTileCache ***ThinkGeo.MapSuite.Core.NativeImageTileCache
TileCache | String, TileImageFormat, TileMatrix | This is the constructor of the class. |
ClearCache | This method will clear all the tiles in the tileCache. | ||
DeleteTile | Tile | This method will delete the target tile passed in. | |
DeleteTiles | RectangleShape | This method will delete the tiles within the passed in worldExtent. | |
SaveTile | Tile | This method will save the target tile passed in. | |
SaveTiles | Bitmap, RectangleShape, Boolean | ||
SaveTiles | Bitmap, RectangleShape | This method will save the bitmap with its extent attached into tiles. | |
ClearCacheCore | This abstract method will clear all the tiles in the tileCache, for each sub TileCache class must implement this method. | ||
DeleteTileCore | Tile | This abstract method will delete the target tile passed in, for each sub TileCache class must implement this method. | |
MemberwiseClone | Object | ||
SaveTileCore | Tile | This abstract method will save the target tile passed in, for each sub TileCache class must implement this method. |
CacheId | String | Gets or sets the id of the TileCache. | |
ImageFormat | TileImageFormat | Gets or sets the tile image format. | |
JpegQuality | Int16 | Gets or sets the Jpeg quality , this property only take effects when setting the ImageFormat to Jpeg. | |
LoadingTileImage | Bitmap | This property returns back a preset image showing the Tile is loading. | |
NoDataTileImage | Bitmap | This property returns back a preset image showing the tile data is missing. | |
TileAccessMode | TileAccessMode | Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete | |
TileMatrix | TileMatrix | Gets or sets the TileMatrix which is used in caculation for tiles. |
| cacheId | String<!– System.String –> | This is the cache identifier which marks its difference with other TileCache. |
| imageFormat | TileImageFormat<!– ThinkGeo.MapSuite.Core.TileImageFormat –> | This is the imageFormate showing what kind of image we are trying to save. |
| tileMatrix | TileMatrix<!– ThinkGeo.MapSuite.Core.TileMatrix –> | This is the tile matrix system which is used for caculating tiles. |
This method will not take effect when the ReadOnly is set to true.
<!– ThinkGeo.MapSuite.Core.TileCache –> Go Back
| tile | Tile<!– ThinkGeo.MapSuite.Core.Tile –> | The target tile to be deleted. |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target extent to delete all tiles within it. |
| tile | Tile<!– ThinkGeo.MapSuite.Core.Tile –> | The target tile to be saved. |
| bitmap | Bitmap<!– System.Drawing.Bitmap –> | |
| bitmapExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
| saveContainedCellsOnly | Boolean<!– System.Boolean –> |
| bitmap | Bitmap<!– System.Drawing.Bitmap –> | The target bitmap to be saved into tiles. |
| bitmapExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target extent for the bitmap. |
| Int16<!– System.Int16 –> |
If you want it to take effect, you need set the ReadOnly property false.
| TileAccessMode<!– ThinkGeo.MapSuite.Core.TileAccessMode –> |
