thinkgeo.mapsuite.core.rectangleshape
ThinkGeo.MapSuite.Core.RectangleShape
    • ThinkGeo.MapSuite.Core.BaseShape
      • ThinkGeo.MapSuite.Core.AreaBaseShape
        • ThinkGeo.MapSuite.Core.RectangleShape
RectangleShape()
This constructor creates a RectangleShape.
RectangleShape(PointShape,PointShape)
  • upperLeftPoint
    • Description:This parameter specifies the upper left point of the rectangle.
  • lowerRightPoint
    • Description:This parameter specifies the lower right point of the rectangle.
RectangleShape(Double,Double,Double,Double)
  • minX
    • Description:This property specifies the minimum X value. This is also the upper left X.
  • maxY
    • Description:This property specifies the maximum Y value. This is also the upper left Y.
  • maxX
    • Description:This property specifies the maximum X value. This is also the lower right X.
  • minY
    • Description:This property specifies the minimum Y value. This is also the lower right Y.
RectangleShape(String)
  • wellKnownText
RectangleShape(Byte[])
  • wellKnownBinary
    • Type:Byte[]
GetIntersection(RectangleShape)
This method returns the intersection of the current RectangleShape and the target shape, defined as the set of all points which lie in both the current shape and the target shape.
  • Description:The return type is a RectangleShape that contains the set of all points which lie in both the current shape and the target shape.
  • targetShape
    • Description:The shape you are trying to find the intersection with.
ToPolygon()
This method returns the current shape as a PolygonShape.
This method is mainly used to convert this GIS non-standard shape to a GIS standard shape.
  • Description:This method returns the current shape as a PolygonShape.
ExpandToInclude(BaseShape)
This method will expand the current RectangleShape to include the targetShape parameter.
There is also an overload that can expand the RectangleShape using a list of multiple shapes.
  • targetShape
    • Type:BaseShape
    • Description:This parameter is used to expand the current rectangle.
ExpandToInclude(Feature)
This method will expand the current RectangleShape to include the target feature parameter.
There is also an overload that can expand the RectangleShape using a collection of features.
  • targetFeature
    • Type:Feature
    • Description:This parameter is used to expand the current feature.
ExpandToInclude(IEnumerable<BaseShape>)
This method will expand the current RectangleShape to include the shapes in the targetShapes parameter.
There is also an overload that can expand the RectangleShape using a single shape.
  • targetShapes
    • Type:IEnumerable<BaseShape>
ExpandToInclude(IEnumerable<Feature>)
This method will expand the current RectangleShape to include the features in the targetFeatures parameter.
There also is an overload that can expand the RectangleShape using a single feature.
  • targetFeatures
    • Type:IEnumerable<Feature>
    • Description:This parameter is a group of features used to expand the current rectangle.
This method returns a formatted representation of the UpperLeftPoint.X, UpperLeftPoint.Y, LowerRightPoint.X and LowerRightPoint.Y value.
The value will be formatted in the standard string format: -180,90,180,-90“
  • Description:This method returns a formatted representation of the UpperLeftPoint.X, UpperLeftPoint.Y, LowerRightPoint.X and LowerRightPoint.Y value.
GetAccuratePerimeter(Int32,DistanceUnit,DistanceCalculationMode)
  • shapeSrid
GetAccuratePerimeter(String,DistanceUnit,DistanceCalculationMode)
  • shapeProj4ProjectionParameters
GetAccurateArea(Int32,AreaUnit,DistanceCalculationMode)
  • shapeSrid
  • returningUnit
GetAccurateArea(String,AreaUnit,DistanceCalculationMode)
  • returningUnit
  • returningUnit
ScaleUp(Double)
  • percentage
ScaleDown(Double)
  • percentage
GetConvexHull()
GetIntersection(Feature)
  • targetFeature
Union(AreaBaseShape)
Union(Feature)
  • targetFeature
GetDifference(AreaBaseShape)
GetDifference(Feature)
  • targetFeature
GetSymmetricalDifference(AreaBaseShape)
GetSymmetricalDifference(Feature)
  • targetFeature
  • tolerance
  • tolerance
LoadFromWellKnownData(String)
  • wellKnownText
GetWellKnownText()
GetGeoJson()
GetWellKnownText(RingOrder)
  • outerRingOrder
LoadFromWellKnownData(Byte[])
  • wellKnownBinary
    • Type:Byte[]
GetWellKnownBinary()
  • Type:Byte[]
  • Type:Byte[]
GetWellKnownBinary(RingOrder)
  • Type:Byte[]
  • outerRingOrder
GetWellKnownBinary(RingOrder,WkbByteOrder)
  • Type:Byte[]
  • outerRingOrder
GetBoundingBox()
GetWellKnownType()
CloneDeep()
  • xOffsetDistance
  • yOffsetDistance
  • xOffsetDistance
  • yOffsetDistance
  • distance
  • angleInDegrees
  • distance
  • angleInDegrees
Rotate(PointShape,Single)
  • degreeAngle
    • Type:Single
  • targetFeature
  • targetFeature
GetCenterPoint()
  • distance
  • distance
  • quadrantSegments
  • distance
  • quadrantSegments
  • targetFeature
  • fromPoint
  • toPoint
Validate(ShapeValidationMode)
IsDisjointed(BaseShape)
IsDisjointed(Feature)
  • targetFeature
Intersects(BaseShape)
Intersects(Feature)
  • targetFeature
Touches(BaseShape)
Touches(Feature)
  • targetFeature
Crosses(BaseShape)
Crosses(Feature)
  • targetFeature
IsWithin(BaseShape)
IsWithin(Feature)
  • targetFeature
Contains(BaseShape)
Contains(Feature)
  • targetFeature
Overlaps(BaseShape)
Overlaps(Feature)
  • targetFeature
IsTopologicallyEqual(Feature)
  • targetFeature
GetFeature()
  • columnValues
GetCrossing(BaseShape)
ScaleTo(Double)
  • scale
GetWellKnownTypeCore()
This method returns the well-known type for the shape.
CloneDeepCore()
This method returns a complete copy of the shape without any references in common.
When you override this method, you need to ensure that there are no references in common between the original and copy.
  • Type:BaseShape
GetCenterPointCore()
This method returns the center point of the current shape's bounding box.
This method returns the center point of the current shape's bounding box. It is important to note that this is the center point of the bounding box. There are numerous ways to calculate the “center” of a geometry such, as its weighted center, etc. You can find other centers by examining the various methods of the shape itself. Overriding: Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
  • Description:A PointShape representing the center point of the current shape's bounding box.
ExpandToIncludeCore(BaseShape)
This method will expand the current RectangleShape to include the shape in the targetShape parameter.
There is also an overload that can expand the RectangleShape using a list of shapes.
  • targetShape
    • Type:BaseShape
This method returns the perimeter of the shape (defined as the sum of the lengths of all its sides).
You would use this method to find the distance around the area shape.
  • Description:The return unit is based on the LengthUnit you specify in the returningUnit parameter, regardless of the shape's GeographyUnit.
  • shapeUnit
  • returningUnit
    • Description:This is the DistanceUnit you would like to use as the return value. For example, if you select miles as your returningUnit, then the distance will be returned in miles.
This method returns the area of the shape (defined as the size of the region enclosed by the figure).
You would use this method to find the area inside the shape.
  • Description:The return unit is based on the AreaUnit you specify in the returningUnit parameter, regardless of the shape's GeographyUnit.
  • shapeUnit
  • returningUnit
    • Type:AreaUnit
    • Description:This is the AreaUnit you would like to use as the return value. For example, if you select square miles as your returningUnit, then the distance will be returned in square miles.
ScaleUpCore(Double)
This method increases the size of the area shape by the percentage given in the percentage parameter.
This method is useful when you would like to increase the size of the shape. Note that a larger percentage will scale the shape up faster, as you are applying the operation multiple times. There is also a ScaleDown method that will shrink the shape.
  • percentage
ScaleDownCore(Double)
This method decreases the size of the area shape by the percentage given in the percentage parameter.
  • percentage
GetBoundingBoxCore()
The GetBoundingBox method calculates the smallest RectangleShape that can encompass the entire geometry by examining each point in the geometry. Depending on the number of PointShapes and complexity of the geometry, this operation can take longer for larger objects. If the shape is a PointShape, then the bounding box's upper left and lower right points will be equal. This will create a RectangleShape with no area.
This method returns a MultipointShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
The register method is useful, for example, when a group of points represented by a MultipointShape has been generated in a non-geographic coordinate in meters, and you want to plot the points on a map that is in decimal degrees.
  • Type:BaseShape
  • Description:This method returns a MultipointShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
  • fromPoint
  • toPoint
  • fromUnit
    • Description:This parameter is the GeographyUnit of the coordinate of origin.
  • toUnit
This method moves the base shape from one location to another, based on an X and Y offset distance.
This method moves the base shape from one location to another, based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape 1 unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles to on the X axis and 3 miles on the Y axis.
  • xOffsetDistance
    • Description:This is the number of horizontal units of movement in the DistanceUnit specified as the distanceUnit.
  • yOffsetDistance
  • shapeUnit
  • distanceUnit
This method moves the shape from one location to another, based on a direction in degrees and distance.
This method moves the base shape from one location to another, based on an angleInDegrees and distance parameter. With this overload, it is important to note that the distance units are the same GeographicUnit as the shape. For example, if your shape is in decimal degrees and you call this method with a distance of 1, you're going to move this shape 1 decimal degree in direction of the angleInDegrees. In many cases it is more useful to specify the DistanceUnit of movement, such as in miles or yards, so for these scenarios there is another overload you may want to use instead.If you pass a distance of 0, then the operation is ignored.
  • distance
  • angleInDegrees
  • shapeUnit
  • distanceUnit
  • targetShape
    • Type:BaseShape
  • shapeUnit
In this method, we compute the closest distance between the two shapes. The returned unit will be in the unit of distance specified.
  • Description:The return type is the distance between this shape and the targetShape in the GeographyUnit of the shape. Overriding: Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
  • targetShape
    • Type:BaseShape
  • shapeUnit
    • Description:The GeographyUnit of the targetShape.
  • distanceUnit
    • Description:The DistanceUnit of the returned value.
This method returns a string that represents the shape in well-known text. Well-known text allows you to describe a geometry as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometric shapes.POINT(5 17)LINESTRING(4 5,10 50,25 80)POLYGON1)MULTIPOINT(3.7 9.7,4.9 11.6)MULTILINESTRING2)MULTIPOLYGON3),4))
  • outerRingOrder
This method returns a byte array that represents the shape in well-known binary.
This method returns a byte array that represents the shape in well-known binary. Well-known binary allows you to describe a geometry as a binary array. Well-known binary is useful when you want to save a geometry in an efficient format using as little space as possible. An alternative to well-known binary is well-known text, which is a textual representation of a geometry object. We have methods that work with well-known text as well.
  • Type:Byte[]
  • outerRingOrder
  • byteOrder
    • Description:This parameter specifies whether the byte order is big- or little-endian.
  • Description:None
  • wellKnownText
This method hydrates the current shape with its data from well-known binary.
  • Description:None
  • wellKnownBinary
    • Type:Byte[]
IsDisjointedCore(BaseShape)
This method returns whether the current shape and the targetShape have no points in common.
  • Description:This method returns whether the current shape and the targetShape have no points in common.
  • targetShape
    • Type:BaseShape
    • Description:The shape you wish to compare the current one to.
  • validationMode
GetCrossingCore(BaseShape)
This method returns the crossing points between the current shape and the passed-in target shape.
  • targetShape
    • Type:BaseShape
ContainsCore(BaseShape)
This method returns if the targetShape lies within the interior of the current shape.
  • Description:This method returns if the targetShape lies within the interior of the current shape.
  • targetShape
    • Type:BaseShape
GetAccuratePerimeterCore(String,DistanceUnit,DistanceCalculationMode)
GetAccurateAreaCore(String,AreaUnit,DistanceCalculationMode)
  • returningUnit
GetConvexHullCore()
UnionCore(AreaBaseShape)
GetDifferenceCore(AreaBaseShape)
GetSymmetricalDifferenceCore(AreaBaseShape)
  • tolerance
GetGeoJsonCore()
RotateCore(PointShape,Single)
  • degreeAngle
    • Type:Single
  • distance
  • quadrantSegments
IntersectsCore(BaseShape)
TouchesCore(BaseShape)
CrossesCore(BaseShape)
IsWithinCore(BaseShape)
OverlapsCore(BaseShape)
ScaleToCore(Double)
  • scale
UpperLeftPoint
This property returns or sets the PointShape that represents the upper left point of the RectangleShape.
UpperRightPoint
This property returns the PointShape that represents the upper right point of the RectangleShape.
LowerRightPoint
This property returns or sets the PointShape that represents the lower right point of the RectangleShape.
LowerLeftPoint
This property returns the PointShape that represents the lower left point of the RectangleShape.
Height
This property returns the height of the RectangleShape in the unit of the shape.
Width
This property returns the width of the RectangleShape in the unit of the shape.
Id
Tag
CanRotate
4) 4 4,7 3,7 5,4 4
thinkgeo.mapsuite.core.rectangleshape.1442555413.txt.gz · Last modified: 2015/09/18 05:50 by admin
