thinkgeo.mapsuite.core.rasterlayer
Table of Contents
ThinkGeo.MapSuite.Core.RasterLayer
<!– Class –> This abstract class is the basis for all image-based layers in the system.
This abstract class is the basis for all image-based layers in the system. Its methods and properties deal with image manipulation. Currently, some classes that inherit from this are EcwRasterLayer, MrSidRasterLayer, GridRasterLayer and so on.
When creating your own RasterLayer, you need only to set a RasterSource and create a useful constructor; the class will take care of the rest. There are no required abstract members. It may be helpful for you to add additional properties specific to your ImageSource.
Protected MethodRasterLayer This is a constructor for the class. If you use this constructor, you should set the properties you need manually.
Public MethodCloneDeep Layer Create a copy of Layer using the deep clone process.
Public MethodClose Layer This method closes the Layer and releases any resources it was using.
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer This method draws the Layer.
Public MethodGetBoundingBox Layer This method returns the bounding box of the Layer.
Public MethodGetHorizontalResolution This method returns the horizontal resolution of the image.
Public MethodGetProjectionText This method returns the projection parameters of the current layer.
Public MethodGetType Object
Public MethodGetVerticalResolution This method returns the vertical resolution of the image.
Public MethodStatic MemberLoadLayer Stream Layer
Public MethodStatic MemberLoadLayer Uri Layer
Public MethodOpen Layer This method opens the Layer so that it is initialized and ready to use.
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing RectangleShape, TimeSpan Layer
Public MethodRequestDrawing IEnumerable<RectangleShape> Layer
Public MethodRequestDrawing TimeSpan Layer
Public MethodRequestDrawing TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing RectangleShape, TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing Layer
Public MethodRequestDrawing RectangleShape Layer
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan Layer
Public MethodToString Object
Protected MethodCloneDeepCore Layer Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
Protected MethodCloseCore Layer(overriden) This method opens the RasterLayer so that it is initialized and ready to use.
Protected MethodDrawAttributionCore GeoCanvas, String Layer
Protected MethodDrawCore GeoCanvas, Collection<SimpleCandidate> Layer(overriden) This method will draw the image from the GeoImage source based on the parameters provided.
Protected MethodDrawException GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodGetBoundingBoxCore Layer(overriden) This method returns the bounding box of the RasterLayer.
Protected MethodStatic MemberIsExtentWithinThreshold RectangleShape, Double, Double, Int32, GeographyUnit This method returns whether the current extent is within the upper and lower threshold properties.
Protected MethodStatic MemberIsExtentWithinThreshold RectangleShape, Double, Double, Int32, GeographyUnit, Single This method returns whether the current extent is within the upper and lower threshold properties.
Protected MethodOnDrawingAttribution DrawingAttributionLayerEventArgs Layer
Protected MethodOnDrawingException DrawingExceptionLayerEventArgs Layer
Protected MethodOnDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Protected MethodOnDrawnAttribution DrawnAttributionLayerEventArgs Layer
Protected MethodOnDrawnException DrawnExceptionLayerEventArgs Layer
Protected MethodOnRequestedDrawing RequestedDrawingLayerEventArgs Layer
Protected MethodOnRequestingDrawing RequestingDrawingLayerEventArgs Layer
Protected MethodOpenCore Layer(overriden) This method opens the RasterLayer so that it is initialized and ready to use.
Public PropertyAttribution String Layer
Public PropertyBlueTranslation Single Layer This property gets and sets the amount of blue to apply to the image.
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer Gets or sets the DrawExcpetionMode when exception happens.
Public PropertyDrawingTime TimeSpan Layer This property gets the last drawing time for the layer.
Public PropertyGreenTranslation Single Layer This property gets and sets the amount of green to apply to the image.
Public PropertyHasBoundingBox Boolean Layer This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
Public PropertyHasProjectionText Boolean This property returns true if the RasterLayer contains projection parameters and false if it does not contain any projection parameters.
Public PropertyImageSource RasterSource This property gets and sets the ImageSource used by the RasterLayer.
Public PropertyIsGrayscale Boolean Layer This property gets and sets if the image should be converted to grayscale.
Public PropertyIsNegative Boolean Layer This property gets and sets whether the image should be converted to negative (inverse colors).
Public PropertyIsOpen Boolean Layer This property returns true if the Layer is open and false if it is not.
Public PropertyIsVisible Boolean Layer This property gets and set the visible state of the layer.
Public PropertyKeyColors Collection<GeoColor> Layer Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors.
Public PropertyLowerThreshold Double This property gets and sets the lower threshold in the scale at which to display the image.
Public PropertyName String Layer This property gets and sets the name for the layer.
Public PropertyRedTranslation Single Layer This property gets and sets the amount of red to apply to the image.
Public PropertyRequestDrawingInterval TimeSpan Layer
Public PropertyTransparency Single Layer This property gets and sets the amount of transparency to apply to the image.
Public PropertyUpperThreshold Double This property gets and sets the upper threshold in the scale at which to display the image.
Protected PropertyIsOpenCore Boolean Layer(overriden) This property returns true if the RasterLayer is open and false if it is not.
RasterLayer()
Name Type Description
Go Back
CloneDeep()
Return Type Description
Layer<!– ThinkGeo.MapSuite.Core.Layer –> A cloned Layer.
Close()
Void<!– System.Void –>
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns the bounding box of the Layer.
Int32<!– System.Int32 –>
GetHorizontalResolution()
Single<!– System.Single –> This method returns the horizontal resolution of the image.
<!– ThinkGeo.MapSuite.Core.RasterLayer –> Go Back
GetProjectionText()
String<!– System.String –> This method returns the projection parameters of the current layer.
Type<!– System.Type –>
GetVerticalResolution()
Single<!– System.Single –> This method returns the vertical resolution of the image.
LoadLayer(Stream)
<!– static –>
layerStream Stream<!– System.IO.Stream –>
LoadLayer(Uri)
<!– static –>
layerUri Uri<!– System.Uri –>
Open()
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType)
extentsToRefresh IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –>
bufferTime TimeSpan<!– System.TimeSpan –>
bufferTimeType RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –>
RequestDrawing(RectangleShape, TimeSpan)
extentToRefresh RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
RequestDrawing(TimeSpan)
RequestDrawing(TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(RectangleShape, TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing()
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan)
CloneDeepCore()
CloseCore()
The close method plays an important role in the life cycle of the RasterLayer. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called.
If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed RasterLayer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
DrawAttributionCore(GeoCanvas, String)
attribution String<!– System.String –>
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
The DrawCore method will be called when the layer is being drawn. It will determine if the image is within the extent and the threshold defined. If these parameters are met, it will query the RasterSource for an image and then apply the other various properties (such as transparency, etc.) on the image. Lastly, it will draw the image on the GeoImage or native image passed into the method.
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the GeoCanvas used to Draw the RasterLayer.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> This parameter is not used for ImageLayers.
DrawException(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns the bounding box of the RasterLayer.
IsExtentWithinThreshold(RectangleShape, Double, Double, Int32, GeographyUnit)
<!– static –> This method returns whether the current extent is within the upper and lower threshold properties.
This method is used to determine whether the RasterLayer needs to draw based on the current extent and the the threshold parameters provided.
Boolean<!– System.Boolean –> This method returns whether the current extent is within the upper and lower threshold properties.
currentExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the current extent that you want determine is within the thresholds defined.
upperThreshold Double<!– System.Double –> This parameter is the upper threshold used to test the extent.
lowerThreshold Double<!– System.Double –> This parameter is the lower threshold used to test the extent.
canvasWidth Int32<!– System.Int32 –> This parameter is the width of the canvas.
mapUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This parameter is the unit of the map.
IsExtentWithinThreshold(RectangleShape, Double, Double, Int32, GeographyUnit, Single)
dpi Single<!– System.Single –> This parameter is the dpi of the current extent.
args DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingAttributionLayerEventArgs –>
e DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –>
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –>
args DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnAttributionLayerEventArgs –>
e DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –>
eventArgs RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestedDrawingLayerEventArgs –>
eventArgs RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestingDrawingLayerEventArgs –>
OpenCore()
The open method plays an important rol,e as it is responsible for initializing the RasterLayer. Most methods on the RasterLayer will throw an exception if the state of the RasterLayer is not opened. When the map draws each layer, it will open the RasterLayer as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the RasterLayer.
Attribution
Return Type
BlueTranslation
Return Type
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
DrawingTime
Return Type
GreenTranslation
Return Type
HasBoundingBox
The default value is false.
Return Type
HasProjectionText
Return Type
ImageSource
The set for this property is protected and only intended to be used by developers who are creating their own ImageSources. This is the main property to set for developers who are creating their own RasterLayer derivatives.
Return Type
RasterSource<!– ThinkGeo.MapSuite.Core.RasterSource –>
IsGrayscale
Return Type
IsNegative
Return Type
IsOpen
Return Type
IsVisible
Return Type
KeyColors
Return Type
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.GeoColor} –>
LowerThreshold
Below the lower threshold in scale, the image will not be displayed. This, in conjunction with the UpperThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
Return Type
Return Type
RedTranslation
Return Type
Return Type
Transparency
Return Type
UpperThreshold
Above the upper threshold in scale, the image will not be displayed. This, in conjunction with the LowerThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
Return Type
IsOpenCore
Various methods on the RasterLayer require that it be in an open state. If one of those methods is called when the state is not open, then the method will throw an exception. To enter the open state, you must call the RasterLayer's Open method. The method will raise an exception if the current RasterLayer is already open.
Return Type
DrawingAttribution
Event Arguments
Event Arguments
DrawingException
Event Arguments
Event Arguments
Event Arguments
Event Arguments
DrawnAttribution
Event Arguments
Event Arguments
DrawnException
Event Arguments
Event Arguments
RequestedDrawing
Event Arguments
Event Arguments
RequestingDrawing
Event Arguments
Event Arguments
thinkgeo.mapsuite.core.rasterlayer.1440040129.txt.gz · Last modified: 2015/09/17 10:38 (external edit)
