thinkgeo.mapsuite.core.mapengine
Table of Contents
ThinkGeo.MapSuite.Core.MapEngine
<!– Class –> This class is for generating maps.
The MapEngine class is similar to a Map Control in Map Suite Desktop Edition or Web Edition.
Public MethodMapEngine Create a new instance of the MapEngine.
Public MethodCenterAt Single, Single, Single, Single This is a function that allows you to pass a screen point to center on and a height and width in screen units. The function will update the current extent by centering on the point and adjusting its ratio based on the height and width in screen coordinates.
Public MethodCenterAt Feature, Single, Single This is a function that allows you to pass in a feature to center on, as well as a height and width in screen units. The function will center the CurrentExtent based on the specified feature and adjust its ratio based on the height and width in screen coordinates.
Public MethodStatic MemberCenterAt RectangleShape, Feature, Single, Single This is a static function that allows you to pass in a world rectangle, a world point to center on, and a height and width in screen units. The function will center the rectangle based on the point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
Public MethodCenterAt PointShape, Single, Single This is a function that allows you to pass a world point to center on and a height and width in screen units. The function will update the current extent by centering on the point and adjusting its ratio based on the height and width in screen coordinates.
Public MethodStatic MemberCenterAt RectangleShape, PointShape, Single, Single This is a static function that allows you to pass in a world rectangle, a world point to center on, and a height and width in screen units. The function will center the rectangle based on the point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
Public MethodStatic MemberCenterAt RectangleShape, Single, Single, Single, Single This is a static function that allows you to pass in a world rectangle, a point in screen coordinates to center on, and a height and width in screen units. The function will center the rectangle based on the screen point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
Public MethodCloseAllLayers This API allows you close all of the layers (either static or dynamic).
Public MethodDraw IEnumerable<Layer>, Bitmap, GeographyUnit Draw a group of layers on the specified “background” bitmap.
Public MethodDraw IEnumerable<Layer>, GeoImage, GeographyUnit Draw a group of layers on the specified “background” image.
Public MethodDraw IEnumerable<Layer>, Int32, Int32, GeographyUnit Draw a group of layers and return a new image with the specified width and height.
Public MethodDrawAdornmentLayers GeoImage, GeographyUnit Draw a group of AdornmentLayers on the specified “background” image.
Public MethodDrawAdornmentLayers Int32, Int32, GeographyUnit Draw a group of AdornmentLayers and return a new image with the specified width and height.
Public MethodDrawAdornmentLayers Bitmap, GeographyUnit Draw a group of AdornmentLayers on the specified “background” bitmap.
Public MethodDrawDynamicLayers GeoImage, GeographyUnit Draw a group of dynamic layers on the specified “background” image.
Public MethodDrawDynamicLayers Bitmap, GeographyUnit Draw a group of dynamic layers on the specified “background” bitmap.
Public MethodDrawDynamicLayers Int32, Int32, GeographyUnit Draw a group of dynamic layers and return a new image with the specified width and height.
Public MethodDrawStaticLayers Int32, Int32, GeographyUnit Draw a group of static layers and return a new image with the specified width and height.
Public MethodDrawStaticLayers GeoImage, GeographyUnit Draw a group of static layers on the specified “background” image.
Public MethodDrawStaticLayers Bitmap, GeographyUnit Draw a group of static layers on the specified “background” bitmap.
Public MethodFindDynamicFeatureLayer String Find the feature layer by key (specified in the “name” parameter) within the collection of DynamicLayers.
Public MethodFindDynamicRasterLayer String Find the raster layer by key (specified in the “name” parameter) within the collection of DynamicLayers.
Public MethodFindStaticFeatureLayer String Finds a feature layer by key (specified in the “name” parameter) within the collection of StaticLayers.
Public MethodFindStaticRasterLayer String Find the raster layer by key (specified in the “name” parameter) within the collection of StaticLayers.
Public MethodStatic MemberGetBoundingBoxOfItems IEnumerable<BaseShape> This API gets the BoundingBox of a group of BaseShapes.
Public MethodStatic MemberGetBoundingBoxOfItems IEnumerable<Feature> This API gets the BoundingBox of a group of Features.
Public MethodStatic MemberGetCurrentScale RectangleShape, Single, GeographyUnit This Static API is used to calculate the scale based on the specified worldExtent and its corresponding ScreenWidth and MapUnit.
Public MethodGetCurrentScale Single, GeographyUnit Get the current Scale responding to the CurrentExtent.
Public MethodStatic MemberGetDrawingExtent RectangleShape, Single, Single This method returns an adjusted extent based on the ratio of the screen width and height.
Public MethodGetDrawingExtent Single, Single This method returns an adjusted extent based on the ratio of the screen width and height.
Public MethodGetScreenDistanceBetweenTwoWorldPoints PointShape, PointShape, Single, Single This method returns the number of pixels between two world points using the CurrentExtent as reference.
Public MethodGetScreenDistanceBetweenTwoWorldPoints Feature, Feature, Single, Single This method returns the number of pixels between two world points using the CurrentExtent as reference.
Public MethodStatic MemberGetScreenDistanceBetweenTwoWorldPoints RectangleShape, Feature, Feature, Single, Single This method returns the number of pixels between two world points.
Public MethodStatic MemberGetScreenDistanceBetweenTwoWorldPoints RectangleShape, PointShape, PointShape, Single, Single This method returns the number of pixels between two world points.
Public MethodGetType Object
Public MethodStatic MemberGetVersion Get the current MapSuiteCore.dll file version.
Public MethodStatic MemberGetWorldDistanceBetweenTwoScreenPoints RectangleShape, ScreenPointF, ScreenPointF, Single, Single, GeographyUnit, DistanceUnit This method returns the distance in world units between two screen points.
Public MethodGetWorldDistanceBetweenTwoScreenPoints ScreenPointF, ScreenPointF, Single, Single, GeographyUnit, DistanceUnit This method returns the distance in world units between two screen points by using the CurrentExtent as a reference.
Public MethodStatic MemberGetWorldDistanceBetweenTwoScreenPoints RectangleShape, Single, Single, Single, Single, Single, Single, GeographyUnit, DistanceUnit This method returns the distance in wold units between two screen points.
Public MethodStatic MemberLoadDataTable Collection<Feature>, IEnumerable<String> This method is a static API to get information about a group of passed-in features with the specified returningColumns, in the format of a DataTable.
Public MethodOpenAllLayers This API allows you to open all of the layers (either static or dynamic).
Public MethodPan Single, Int32 This method updates the CurrentExtent by using a panning operation.
Public MethodStatic MemberPan RectangleShape, Single, Int32 This method returns a panned extent.
Public MethodStatic MemberPan RectangleShape, PanDirection, Int32 This method returns a panned extent.
Public MethodPan PanDirection, Int32 Update the CurrentExtent by using a panning operation.
Public MethodSnapToZoomLevel GeographyUnit, Single, Single, ZoomLevelSet This method updates the CurrentExtent by snapping to a zoom level in the provided zoom level set.
Public MethodStatic MemberSnapToZoomLevel RectangleShape, GeographyUnit, Single, Single, ZoomLevelSet This method returns an extent that is snapped to a zoom level in the provided zoom level set.
Public MethodToScreenCoordinate PointShape, Single, Single This method returns screen coordinates from the specified world coordinates, based on the CurrentExtent.
Public MethodToScreenCoordinate Feature, Single, Single This method returns screen coordinates from the specified world coordinate pointFeature, based on the CurrentExtent.
Public MethodToScreenCoordinate Double, Double, Single, Single This method returns screen coordinates from the specified world coordinates, based on the CurrentExtent.
Public MethodStatic MemberToScreenCoordinate RectangleShape, Double, Double, Single, Single This method returns screen coordinates from world coordinates.
Public MethodStatic MemberToScreenCoordinate RectangleShape, PointShape, Single, Single This method returns screen coordinates from world coordinates.
Public MethodStatic MemberToScreenCoordinate RectangleShape, Feature, Single, Single This method returns screen coordinates from world coordinates.
Public MethodToString Object
Public MethodToWorldCoordinate Single, Single, Single, Single This method returns world coordinates from screen coordinates, based on the CurrentExtent.
Public MethodStatic MemberToWorldCoordinate RectangleShape, Single, Single, Single, Single This method returns world coordinates from screen coordinates.
Public MethodStatic MemberToWorldCoordinate RectangleShape, ScreenPointF, Single, Single This method returns world coordinates from screen coordinates.
Public MethodToWorldCoordinate ScreenPointF, Single, Single This method returns world coordinates from screen coordinates, based on the CurrentExtent.
Public MethodStatic MemberZoomIn RectangleShape, Int32 This method returns a new extent that is zoomed in by the percentage provided.
Public MethodZoomIn Int32 This method updates the CurrentExtent that is zoomed in by the percentage provided.
Public MethodStatic MemberZoomIntoCenter RectangleShape, Int32, PointShape, Single, Single This method returns an extent that is centered and zoomed in.
Public MethodStatic MemberZoomIntoCenter RectangleShape, Int32, Feature, Single, Single This method returns a new extent that is zoomed in by the percentage provided.
Public MethodZoomIntoCenter Int32, PointShape, Single, Single This method will update the CurrentExtent by using the ZoomIntoCenter operation.
Public MethodZoomIntoCenter Int32, Feature, Single, Single This method returns an extent that is centered and zoomed in.
Public MethodStatic MemberZoomIntoCenter RectangleShape, Int32, Single, Single, Single, Single This method returns an extent that is centered and zoomed in.
Public MethodZoomIntoCenter Int32, Single, Single, Single, Single This method updates the CurrentExtent based on a calculated rectangle that is centered and zoomed in.
Public MethodZoomOut Int32 This method will update the CurrentExtent by using the ZoomOut operation.
Public MethodStatic MemberZoomOut RectangleShape, Int32 This method returns a new extent that is zoomed out by the percentage provided.
Public MethodZoomOutToCenter Int32, Feature, Single, Single This method updates the CurrentExtent by using the ZoomOutToCenter operation.
Public MethodZoomOutToCenter Int32, PointShape, Single, Single This method updates the CurrentExtent by using the ZoomOutToCenter operation.
Public MethodZoomOutToCenter Int32, Single, Single, Single, Single This method updates the CurrentExtent by using the ZoomOutToCenter operation.
Public MethodStatic MemberZoomOutToCenter RectangleShape, Int32, Feature, Single, Single This method returns an extent that is centered and zoomed out.
Public MethodStatic MemberZoomOutToCenter RectangleShape, Int32, PointShape, Single, Single This method returns an extent that is centered and zoomed out.
Public MethodStatic MemberZoomOutToCenter RectangleShape, Int32, Single, Single, Single, Single This method returns an extent that is centered and zoomed out.
Public MethodZoomToScale Double, GeographyUnit, Single, Single This method updates the CurrentExtent by zooming to a certain scale.
Public MethodStatic MemberZoomToScale Double, RectangleShape, GeographyUnit, Single, Single This method returns a extent that has been zoomed into a certain scale.
Protected MethodOnAdornmentLayerDrawing AdornmentLayerDrawingEventArgs This event is raised before an AdornmentLayer is drawn.
Protected MethodOnAdornmentLayerDrawn AdornmentLayerDrawnEventArgs This event is raised after an AdornmentLayer is drawn.
Protected MethodOnAdornmentLayersDrawing AdornmentLayersDrawingEventArgs This event is raised before AdornmentLayers are drawn.
Protected MethodOnAdornmentLayersDrawn AdornmentLayersDrawnEventArgs This event is raised after AdornmentLayers are drawn.
Protected MethodOnLayerDrawing LayerDrawingEventArgs This event is raised before a Layer is drawn.
Protected MethodOnLayerDrawn LayerDrawnEventArgs This event is raised after a Layer is drawn.
Protected MethodOnLayersDrawing LayersDrawingEventArgs This event is raised before Layers are drawn.
Protected MethodOnLayersDrawn LayersDrawnEventArgs This event is raised after Layers are drawn.
Public PropertyAdornmentLayers GeoCollection<AdornmentLayer> This property holds a collection of AdornmentLayers to be drawn on the MapEngine.
Public PropertyBackgroundFillBrush GeoBrush Gets or sets the GeoBrush for the background of the MapEngine.
Public PropertyCanvas GeoCanvas Gets and sets the GeoCanvas used to draw the Layers.
Public PropertyCurrentExtent RectangleShape This property gets or sets the current extent of the MapEngine.
Public PropertyDynamicLayers GeoCollection<Layer> This property holds a group of Layers to be drawn on the MapEngine.
Public PropertyShowLogo Boolean This property specifies whether the logo is shown on the Map or not.
Public PropertyStaticLayers GeoCollection<Layer> This property holds a group of Layers to be drawn on the MapEngine.
Public EventAdornmentLayerDrawing AdornmentLayerDrawingEventArgs This event is raised before an AdornmentLayer is drawn.
Public EventAdornmentLayerDrawn AdornmentLayerDrawnEventArgs This event is raised after an AdornmentLayer is drawn.
Public EventAdornmentLayersDrawing AdornmentLayersDrawingEventArgs This event is raised before AdornmentLayers are drawn.
Public EventAdornmentLayersDrawn AdornmentLayersDrawnEventArgs This event is raised after AdornmentLayers are drawn.
Public EventLayerDrawing LayerDrawingEventArgs This event is raised before a Layer is drawn.
Public EventLayerDrawn LayerDrawnEventArgs This event is raised after a Layer is drawn.
Public EventLayersDrawing LayersDrawingEventArgs This event is raised before Layers are drawn.
Public EventLayersDrawn LayersDrawnEventArgs This event is raised after Layers are drawn.
MapEngine()
Name Type Description
Go Back
CenterAt(Single, Single, Single, Single)
Overloads
This overload allows you to pass in a screen point as the center.
This API will update the <strong>CurrentExtent</strong>.
Return Type Description
Void<!– System.Void –>
screenX Single<!– System.Single –> This parameter is the X coordinate on the screen to center on.
screenY Single<!– System.Single –> This parameter is the Y coordinate on the screen to center on.
screenWidth Single<!– System.Single –> This parameter is the width of the screen.
screenHeight Single<!– System.Single –> This parameter is the height of the screen.
<!– ThinkGeo.MapSuite.Core.MapEngine –> Go Back
CenterAt(Feature, Single, Single)
centerFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the world point feature you want to center on.
CenterAt(RectangleShape, Feature, Single, Single)
<!– static –> This is a static function that allows you to pass in a world rectangle, a world point to center on, and a height and width in screen units. The function will center the rectangle based on the point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
Overloads
This overload allows you to pass in a world point as the center.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns an adjusted extent centered on a point.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the current extent you want to center.
CenterAt(PointShape, Single, Single)
worldPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the world point you want to center on.
CenterAt(RectangleShape, PointShape, Single, Single)
Overloads
CenterAt(RectangleShape, Single, Single, Single, Single)
<!– static –> This is a static function that allows you to pass in a world rectangle, a point in screen coordinates to center on, and a height and width in screen units. The function will center the rectangle based on the screen point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
Overloads
screenX Single<!– System.Single –> This parameter is the X coordinate on the screen to center to.
screenY Single<!– System.Single –> This parameter is the Y coordinate on the screen to center to.
CloseAllLayers()
Draw(IEnumerable<Layer>, Bitmap, GeographyUnit)
Bitmap<!– System.Drawing.Bitmap –> The resulting bitmap after drawing the target layers on the specified “background” bitmap.
layers IEnumerable<Layer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Layer} –> This parameter specifies the target layers to be drawn.
gdiPlusBitmap Bitmap<!– System.Drawing.Bitmap –> This parameter specifies the “background” bitmap of the returning bitmap.
mapUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This parameter specifies the MapUnit used in the current map.
Draw(IEnumerable<Layer>, GeoImage, GeographyUnit)
GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> The resulting image after drawing the target layers on the specified “background” image.
image GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> This parameter specifies the “background” image of the returning image.
Draw(IEnumerable<Layer>, Int32, Int32, GeographyUnit)
GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> The resulting image after drawing the target layers based on the specified width and height.
width Int32<!– System.Int32 –> This parameter specifies the width of the returning image.
height Int32<!– System.Int32 –> This parameter specifies the height of the returning image.
DrawAdornmentLayers(GeoImage, GeographyUnit)
GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> The resulting image after drawing the group of AdornmentLayers on the specified “background” image.
DrawAdornmentLayers(Int32, Int32, GeographyUnit)
GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> The resulting image after drawing the group of AdornmentLayers based on the specified width and height.
DrawAdornmentLayers(Bitmap, GeographyUnit)
Bitmap<!– System.Drawing.Bitmap –> The resulting bitmap after drawing the group of AdornmentLayers on the specified “background” bitmap.
DrawDynamicLayers(GeoImage, GeographyUnit)
GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> The resulting image after drawing the group of dynamic layers on the specified “background” image.
DrawDynamicLayers(Bitmap, GeographyUnit)
Bitmap<!– System.Drawing.Bitmap –> The resulting bitmap after drawing the group of dynamic layers on the specified “background” bitmap.
DrawDynamicLayers(Int32, Int32, GeographyUnit)
GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> The resulting image after drawing the group of dynamic layers based on the specified width and height.
DrawStaticLayers(Int32, Int32, GeographyUnit)
GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> The resulting image after drawing the group of static layers based on the specified width and height.
DrawStaticLayers(GeoImage, GeographyUnit)
GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> The resulting image after drawing the group of static layers on the specified “background” image.
DrawStaticLayers(Bitmap, GeographyUnit)
Bitmap<!– System.Drawing.Bitmap –> The resulting bitmap after drawing the group of static layers on the specified “background” bitmap.
Boolean<!– System.Boolean –>
FindDynamicFeatureLayer(String)
FeatureLayer<!– ThinkGeo.MapSuite.Core.FeatureLayer –> The corresponding FeatureLayer with the specified key in the MapControl.
name String<!– System.String –> The key to find the final result feature layer.
FindDynamicRasterLayer(String)
RasterLayer<!– ThinkGeo.MapSuite.Core.RasterLayer –> The corresponding RasterLayer with the specified key in the MapControl.
name String<!– System.String –> The key to find the final result raster layer.
FindStaticFeatureLayer(String)
FindStaticRasterLayer(String)
RasterLayer<!– ThinkGeo.MapSuite.Core.RasterLayer –> The corresponding RasterLayer with the passing specified in the MapControl.
GetBoundingBoxOfItems(IEnumerable<BaseShape>)
<!– static –> This API gets the BoundingBox of a group of BaseShapes.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> The BoundingBox that contains all the shapes you passed in.
shapes IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.BaseShape} –> The target group of BaseShapes to get the BoundingBox for.
GetBoundingBoxOfItems(IEnumerable<Feature>)
<!– static –> This API gets the BoundingBox of a group of Features.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> The BoundingBox that contains all the features you passed in.
features IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> The target group of Features to get the BoundingBox for.
GetCurrentScale(RectangleShape, Single, GeographyUnit)
<!– static –> This Static API is used to calculate the scale based on the specified worldExtent and its corresponding ScreenWidth and MapUnit.
Double<!– System.Double –>
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter specifies the worldExtent used to calculate the current scale.
screenWidth Single<!– System.Single –> This parameter specifies the screenWidth corresponding to the worldExtent.
mapUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This parameter specifies the unit for the extent, the result will be different if choose DecimalDegree as Unit and Meter as Unit.
GetCurrentScale(Single, GeographyUnit)
Double<!– System.Double –> The calculated scale based on the CurrentExtent.
screenWidth Single<!– System.Single –> This parameter specifies the screen width responding to the CurrentExtent.
GetDrawingExtent(RectangleShape, Single, Single)
<!– static –> This method returns an adjusted extent based on the ratio of the screen width and height.
This function is used because the extent to draw must be the rame ratio as the screen width and height. If they are not, then the image drawn will be stretched or compressed. We always adjust the extent upwards to ensure that no matter how we adjust it, the original extent will fit within the new extent. This ensures that everything you wanted to see in the first extent is visible and maybe a bit more. This function takes a height and width in screen coordinates, then looks at a world extent passed, and returns an adjusted world rectangle so that the ratio to height and width in screen and world coordinates match.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns an adjusted extent based on the ratio of the screen width and height.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the world extent you want to adjust for drawing.
GetDrawingExtent(Single, Single)
GetScreenDistanceBetweenTwoWorldPoints(PointShape, PointShape, Single, Single)
Single<!– System.Single –> This method returns the number of pixels between two world points.
worldPoint1 PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the first point – the one you want to measure from.
worldPoint2 PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the second point – the one you want to measure to.
GetScreenDistanceBetweenTwoWorldPoints(Feature, Feature, Single, Single)
worldPointFeature1 Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the first pointFeture – the one you want to measure from.
worldPointFeature2 Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the second pointFeature – the one you want to measure to.
GetScreenDistanceBetweenTwoWorldPoints(RectangleShape, Feature, Feature, Single, Single)
<!– static –> This method returns the number of pixels between two world points.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the world extent.
worldPointFeature1 Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the first point Feature – the one you want to measure from.
worldPointFeature2 Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the second point Feature – the one you want to measure to.
GetScreenDistanceBetweenTwoWorldPoints(RectangleShape, PointShape, PointShape, Single, Single)
Type<!– System.Type –>
GetVersion()
<!– static –> Get the current MapSuiteCore.dll file version.
String<!– System.String –> A string representing the file version of MapSuiteCore.dll.
GetWorldDistanceBetweenTwoScreenPoints(RectangleShape, ScreenPointF, ScreenPointF, Single, Single, GeographyUnit, DistanceUnit)
<!– static –> This method returns the distance in world units between two screen points.
Overloads
This overload allows you to pass in ScreenPointF as the points.
Double<!– System.Double –> This method returns the distance in wold units between two screen points.
screenPoint1 ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> This is the screen point you want to measure from.
screenPoint2 ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> This is the screen point you want to measure to.
worldExtentUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This is the geographic unit of the world extent rectangle.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> This is the geographic unit you want the result to show in.
GetWorldDistanceBetweenTwoScreenPoints(ScreenPointF, ScreenPointF, Single, Single, GeographyUnit, DistanceUnit)
Overloads
Double<!– System.Double –> This method returns the distance in world units between two screen points.
GetWorldDistanceBetweenTwoScreenPoints(RectangleShape, Single, Single, Single, Single, Single, Single, GeographyUnit, DistanceUnit)
<!– static –> This method returns the distance in wold units between two screen points.
Overloads
This overload allows you to pass in the X & Y for each point.
screenPoint1X Single<!– System.Single –> This parameter is the X of the point you want to measure from.
screenPoint1Y Single<!– System.Single –> This parameter is the Y of the point you want to measure from.
screenPoint2X Single<!– System.Single –> This parameter is the X of the point you want to measure to.
screenPoint2Y Single<!– System.Single –> This parameter is the Y of the point you want to measure to.
worldExtentUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This is the geographic unit of the world extent you passed in.
LoadDataTable(Collection<Feature>, IEnumerable<String>)
<!– static –> This method is a static API to get information about a group of passed-in features with the specified returningColumns, in the format of a DataTable.
DataTable<!– System.Data.DataTable –> A DateTable of information about those passed-in features and the returning columnNames.
features Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.Feature} –> This parameter specifies the target features.
returningColumnNames IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> This parameter specifies the returning columnNames for the features.
OpenAllLayers()
Pan(Single, Int32)
Overloads
This overload allows you to pass in an angle and a percentage by which you want to pan and update the CurrentExtent.
degree Single<!– System.Single –> This parameter is the angle in degrees in which you want to pan.
percentage Int32<!– System.Int32 –> This parameter is the percentage by which you want to pan.
Pan(RectangleShape, Single, Int32)
<!– static –> This method returns a panned extent.
Overloads
This overload allows you to pass in an angle and a percentage by which you want to pan.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns a panned extent.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the world extent you want to pan.
Pan(RectangleShape, PanDirection, Int32)
Overloads
This overload allows you to pass in a direction and a percentage by which you want to pan.
direction PanDirection<!– ThinkGeo.MapSuite.Core.PanDirection –> This parameter is the direction you want to pan.
Pan(PanDirection, Int32)
Overloads
panDirection PanDirection<!– ThinkGeo.MapSuite.Core.PanDirection –> This parameter is the direction you want to pan.
SnapToZoomLevel(GeographyUnit, Single, Single, ZoomLevelSet)
Void<!– System.Void –> This method updates the CurrentExtent by snapping to a zoom level in the provided zoom level set.
worldExtentUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This parameter is the geographic unit of the CurrentExtent.
screenWidth Single<!– System.Single –> This parameter is the screen width.
screenHeight Single<!– System.Single –> This parameter is the screen height.
zoomLevelSet ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> This parameter is the set of zoom levels you want to snap to.
SnapToZoomLevel(RectangleShape, GeographyUnit, Single, Single, ZoomLevelSet)
<!– static –> This method returns an extent that is snapped to a zoom level in the provided zoom level set.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns an extent that is snapped to a zoom level in the provided zoom level set.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the world extent you want snapped.
worldExtentUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This parameter is the geographic unit of the world extent parameter.
ToScreenCoordinate(PointShape, Single, Single)
ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> This method returns screen coordinates from the specified world coordinates, based on the CurrentExtent.
worldPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the world point you want converted to a screen point.
screenWidth Single<!– System.Single –> This parameter is the width of the screen for the CurrentExtent.
screenHeight Single<!– System.Single –> This parameter is the height of the screen for the CurrentExtent.
ToScreenCoordinate(Feature, Single, Single)
ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> This method returns screen coordinates from the specified world coordinate pointFeature, based on the CurrentExtent.
worldPointFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the world coordinate pointFeature you want converted to a screen point.
ToScreenCoordinate(Double, Double, Single, Single)
worldX Double<!– System.Double –> This parameter is the world point X you want converted to a screen point.
worldY Double<!– System.Double –> This parameter is the world point Y you want converted to a screen point.
ToScreenCoordinate(RectangleShape, Double, Double, Single, Single)
<!– static –> This method returns screen coordinates from world coordinates.
Overloads
This overload allows you to pass in world X & Y coordinates.
ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> This method returns screen coordinates from world coordinates.
worldX Double<!– System.Double –> This parameter is the world X you want converted to screen points.
worldY Double<!– System.Double –> This parameter is the world Y you want converted to screen points.
ToScreenCoordinate(RectangleShape, PointShape, Single, Single)
ToScreenCoordinate(RectangleShape, Feature, Single, Single)
worldPointFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the world point feature you want converted to a screen point.
ToWorldCoordinate(Single, Single, Single, Single)
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This method returns world coordinates from screen coordinates, based on the CurrentExtent.
screenX Single<!– System.Single –> This parameter is the X of the point you want converted to world coordinates.
screenY Single<!– System.Single –> This parameter is the Y of the point you want converted to world coordinates.
ToWorldCoordinate(RectangleShape, Single, Single, Single, Single)
<!– static –> This method returns world coordinates from screen coordinates.
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This method returns world coordinates from screen coordinates.
screenX Single<!– System.Single –> This parameter is the X coordinate of the point you want converted to world coordinates.
screenY Single<!– System.Single –> This parameter is the Y coordinate of the point you want converted to world coordinates.
ToWorldCoordinate(RectangleShape, ScreenPointF, Single, Single)
screenPoint ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> This parameter is the screen point you want converted to a world point.
ToWorldCoordinate(ScreenPointF, Single, Single)
screenPoint ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> This parameter is the point you want converted to world coordinates.
ZoomIn(RectangleShape, Int32)
<!– static –> This method returns a new extent that is zoomed in by the percentage provided.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns a new extent that is zoomed in by the percentage provided.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the world extent you want to zoom.
percentage Int32<!– System.Int32 –> This parameter is the percentage by which you want to zoom in.
ZoomIn(Int32)
Void<!– System.Void –> This method updates the CurrentExtent that is zoomed in by the percentage provided.
ZoomIntoCenter(RectangleShape, Int32, PointShape, Single, Single)
<!– static –> This method returns an extent that is centered and zoomed in.
Overloads
This overload allows you to pass in the height and width in screen coordinates, as well as a world point.
The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterwards.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns an extent that is centered and zoomed in.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the world extent that you want centered and zoomed.
worldPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the world point you want the extent to be centered on.
screenWidth Single<!– System.Single –> This parameter is the width in screen coordinates.
screenHeight Single<!– System.Single –> This parameter is the height in screen coordinates.
ZoomIntoCenter(RectangleShape, Int32, Feature, Single, Single)
centerFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the world point feature you want the extent to be centered on.
ZoomIntoCenter(Int32, PointShape, Single, Single)
Overloads
The CurrentExtent will be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterwards.
ZoomIntoCenter(Int32, Feature, Single, Single)
Overloads
Void<!– System.Void –> This method returns an extent that is centered and zoomed in.
centerFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the world point you want the extent to be centered on.
ZoomIntoCenter(RectangleShape, Int32, Single, Single, Single, Single)
Overloads
This overload allows you to pass in the height and width in screen coordinates, as well as a screen X & Y.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the world extent you want to center and zoom.
screenX Single<!– System.Single –> This parameter is the screen X you want to center on.
screenY Single<!– System.Single –> This parameter is the screen Y you want to center on.
ZoomIntoCenter(Int32, Single, Single, Single, Single)
Overloads
ZoomOut(Int32)
percentage Int32<!– System.Int32 –> This parameter is the percentage by which you want to zoom.
ZoomOut(RectangleShape, Int32)
<!– static –> This method returns a new extent that is zoomed out by the percentage provided.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns a new extent that is zoomed out by the percentage provided.
percentage Int32<!– System.Int32 –> This parameter is the percentage by which you want to zoom out.
ZoomOutToCenter(Int32, Feature, Single, Single)
Overloads
centerFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the world point Feature you want the extent to be centered on.
ZoomOutToCenter(Int32, PointShape, Single, Single)
Overloads
ZoomOutToCenter(Int32, Single, Single, Single, Single)
Overloads
This overload allows you to pass in the height and width in screen coordinates, as well as a screenX and screenY.
ZoomOutToCenter(RectangleShape, Int32, Feature, Single, Single)
<!– static –> This method returns an extent that is centered and zoomed out.
Overloads
This overload allows you to pass in the height and width in screen coordinates, as well as a feature.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns an extent that is centered and zoomed out.
centerFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the feature you want the extent to be centered on.
ZoomOutToCenter(RectangleShape, Int32, PointShape, Single, Single)
Overloads
ZoomOutToCenter(RectangleShape, Int32, Single, Single, Single, Single)
Overloads
ZoomToScale(Double, GeographyUnit, Single, Single)
targetScale Double<!– System.Double –> This parameter is the scale you want to zoom into.
ZoomToScale(Double, RectangleShape, GeographyUnit, Single, Single)
<!– static –> This method returns a extent that has been zoomed into a certain scale.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns a extent that has been zoomed into a certain scale.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the world extent you want zoomed into the scale.
OnAdornmentLayerDrawing(AdornmentLayerDrawingEventArgs)
e AdornmentLayerDrawingEventArgs<!– ThinkGeo.MapSuite.Core.AdornmentLayerDrawingEventArgs –> The AdornmentLayerDrawingEventArgs passed for the event raised.
OnAdornmentLayerDrawn(AdornmentLayerDrawnEventArgs)
e AdornmentLayerDrawnEventArgs<!– ThinkGeo.MapSuite.Core.AdornmentLayerDrawnEventArgs –> The AdornmentLayerDrawnEventArgs passed for the event raised.
OnAdornmentLayersDrawing(AdornmentLayersDrawingEventArgs)
e AdornmentLayersDrawingEventArgs<!– ThinkGeo.MapSuite.Core.AdornmentLayersDrawingEventArgs –> The AdornmentLayersDrawingEventArgs passed for the event raised.
OnAdornmentLayersDrawn(AdornmentLayersDrawnEventArgs)
e AdornmentLayersDrawnEventArgs<!– ThinkGeo.MapSuite.Core.AdornmentLayersDrawnEventArgs –> The AdornmentLayersDrawnEventArgs passed for the event raised.
OnLayerDrawing(LayerDrawingEventArgs)
e LayerDrawingEventArgs<!– ThinkGeo.MapSuite.Core.LayerDrawingEventArgs –> The LayerDrawingEventArgs passed for the event raised.
OnLayerDrawn(LayerDrawnEventArgs)
e LayerDrawnEventArgs<!– ThinkGeo.MapSuite.Core.LayerDrawnEventArgs –> The LayerDrawnEventArgs passed for the event raised.
OnLayersDrawing(LayersDrawingEventArgs)
e LayersDrawingEventArgs<!– ThinkGeo.MapSuite.Core.LayersDrawingEventArgs –> The LayersDrawingEventArgs passed for the event raised.
OnLayersDrawn(LayersDrawnEventArgs)
e LayersDrawnEventArgs<!– ThinkGeo.MapSuite.Core.LayersDrawnEventArgs –> The LayersDrawnEventArgs passed for the event raised.
AdornmentLayers
This collection of Layers <strong>StaticLayers</strong> will be drawn when calling the <strong>DrawAdornmentLayers</strong> API.
Return Type
GeoCollection<AdornmentLayer><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.AdornmentLayer} –>
BackgroundFillBrush
Return Type
GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –>
Canvas
Return Type
GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –>
CurrentExtent
The current extent is the rectangle that is currently being shown on the MapEngine.
Return Type
DynamicLayers
This collection of Layers <strong>StaticLayers</strong> will be drawn when calling the <strong>DrawDynamicLayers</strong> API.
Return Type
GeoCollection<Layer><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.Layer} –>
Return Type
StaticLayers
This collection of Layers <strong>StaticLayers</strong> will be drawn when calling the <strong>DrawStaticLayers</strong> API.
Return Type
Event Arguments
Event Arguments
AdornmentLayerDrawn
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
LayerDrawing
Event Arguments
Event Arguments
LayerDrawn
Event Arguments
Event Arguments
LayersDrawing
Event Arguments
Event Arguments
LayersDrawn
Event Arguments
Event Arguments
thinkgeo.mapsuite.core.mapengine.1440040129.txt.gz · Last modified: 2015/09/17 10:34 (external edit)
