This class displays an icon with text from the data of the feature.
If you use this, then you should set the properties manually – such as the column name, font, solid brush and the image.
This constructor allows you to pass in the path to the icon, along with the column name, font and solid brush to use. This is the most commonly used constructor. If you need to use an image from a stream, then you should use the constructor that takes a GeoImage.
IconStyle(GeoImage,String,GeoFont,GeoSolidBrush)
This constructor allows you to use a GeoImage instead of specifying a path and filename of the icon. This is commonly used if the image comes from a stream.
GetLabelingCandidateCore(Feature,GeoCanvas)
This method determines which labels will be candidates for drawing.
This overridden method is called from the concrete public method GetLabelingCandidate. In this method, we determine if the feature passed in will be a candidate for drawing. If you have the grid method enabled, then we determine this by ensuring that only one label will be eligible per grid cell. In this way, we can ensure that labels always draw in the same place at the same scale.
FilterFeaturesCore(IEnumerable<Feature>,GeoCanvas)
AbbreviateText(Feature,GeoCanvas)
AbbreviateTextCore(Feature,GeoCanvas)
GetLabelingCandidates(Feature,GeoCanvas)
CheckDuplicate(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
CheckDuplicateCore(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
CheckOverlapping(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
CheckOverlappingCore(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
lD8=(PolygonShape,String,GeoCanvas)
OnFormatting(FormattingPositionStyleEventArgs)
This property gets and sets the filename and path for the image you want to use in the style.
You can also optionally use the IconImage property if the image you want to use is derived from a stream.
You will typically want to use this property if your image is derived from a stream. Otherwise, you can use the IconFilePathName property to specify where the icon is located and we will handle the rest.
This property allows you to scale the image up and down depending on how large or small you want it. It can be changed dynamically, so you could change it at every scale level to resize the bitmap based on the current scale. A scale of 1 would be the original size, while a scale of 2 would double the size. A scale of .5 would reduce the size of the image by half, and so on.
This property gets and sets whether a partial label in the current extent will be drawn or not.
This property provides a solution to the “cut off” label issue in Map Suite Web Edition and Desktop Edition, which occurs when multiple tiles exist. When you set this property to true, any labels outside of the current extent will not be drawn.
Event Arguments:FormattedPositionStyleEventArgs
