This class displays an icon with text from the data of the feature.
LeaderLineMinimumLengthInPixels
If you use this, then you should set the properties manually – such as the column name, font, solid brush and the image.
This constructor allows you to pass in the path to the icon, along with the column name, font and solid brush to use. This is the most commonly used constructor. If you need to use an image from a stream, then you should use the constructor that takes a GeoImage.
iconPathFilename
textFont
This constructor allows you to use a GeoImage instead of specifying a path and filename of the icon. This is commonly used if the image comes from a stream.
iconImage
textFont
features
canvas
labelsInThisLayer
labelsInAllLayers
shapes
canvas
labelsInThisLayer
labelsInAllLayers
labelingCandidate
canvas
labelsInThisLayer
labelsInAllLayers
labelingCandidate
canvas
labelsInThisLayer
labelsInAllLayers
labelingCandidate
canvas
labelsInThisLayer
labelsInAllLayers
labelingCandidate
canvas
labelsInThisLayer
labelsInAllLayers
features
canvas
labelsInThisLayer
labelsInAllLayers
This method determines which labels will be candidates for drawing.
This overridden method is called from the concrete public method GetLabelingCandidate. In this method, we determine if the feature passed in will be a candidate for drawing. If you have the grid method enabled, then we determine this by ensuring that only one label will be eligible per grid cell. In this way, we can ensure that labels always draw in the same place at the same scale.
feature
canvas
polygon
text
canvas
Return Type:Dictionary<String,String>
Return Type:TextStyleAdvanced
Return Type:Boolean
Return Type:Boolean
Return Type:Single
Return Type:Single
Return Type:String
Return Type:DrawingLevel
Return Type:LabelDuplicateRule
Return Type:Collection<String>
Return Type:Boolean
Return Type:Boolean
Return Type:Double
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Int32
This property gets and sets the filename and path for the image you want to use in the style.
You can also optionally use the IconImage property if the image you want to use is derived from a stream.
Return Type:String
This property gets and sets the GeoImage you want to use for the image.
You will typically want to use this property if your image is derived from a stream. Otherwise, you can use the IconFilePathName property to specify where the icon is located and we will handle the rest.
This property gets and sets the scale of the image you want to draw.
This property allows you to scale the image up and down depending on how large or small you want it. It can be changed dynamically, so you could change it at every scale level to resize the bitmap based on the current scale. A scale of 1 would be the original size, while a scale of 2 would double the size. A scale of .5 would reduce the size of the image by half, and so on.
Return Type:Double
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Dictionary<String,WorldLabelingCandidate>
Return Type:Single
Return Type:LabelLeaderLinesRule
Return Type:Int32
Return Type:Int32
Return Type:String
Return Type:Single
Return Type:String
Return Type:LabelOverlappingRule
Return Type:PointPlacement
Return Type:PolygonLabelingLocationMode
Return Type:Double
Return Type:SplineType
This property gets and sets whether a partial label in the current extent will be drawn or not.
This property provides a solution to the “cut off” label issue in Map Suite Web Edition and Desktop Edition, which occurs when multiple tiles exist. When you set this property to true, any labels outside of the current extent will not be drawn.
Return Type:Boolean
Return Type:String
Return Type:String
Return Type:Double
Return Type:GeoSolidBrush
Return Type:Single
Return Type:Single
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
