map_suite_webapi_edition
Map Suite WebAPI Edition
Map Suite WebAPI Edition allows you to easily build REST based web services to do the server side rendering, querying and geometric functions in your HTML5/Javascript application utilizing any JavaScript mapping client library (Leaflet, OpenLayers3 & KendoUI).
Learning Samples
Learn More
Browse the demo applications to see the power of Map Suite WebAPI Edition and how it can be utilized to build professional grade mapping applications using both the Leaflet and OpenLayers JavaScript mapping libraries.
Product Guides & Appendices
Helps you get started building your first application with the Map Suite WebAPI Edition.
Introduces the dependencies Map Suite Desktop Edition needs with their features, versions and source websites.
API Documentation
  • ThinkGeo.MapSuite.Core
    The Core API documentation covers the ThinkGeo.MapSuite.Core namespace which resides in the MapSuiteCore.dll assembly. It contains all of the core GIS classes that are shared between the different Map Suite edition map controls and servers. It includes such classes as Style, FeatureSource, Layer, Projection etc. This is where the bulk of the classes are for most of the Map Suite products.
  • ThinkGeo.MapSuite.WebApiEdition
    The WebAPI Edition API documentation covers the ThinkGeo.MapSuite.WebAPIEdition namespace which resides in the WebAPIEdition.dll assembly. It contains all of the WebAPI Edition specific classes such as the map control itself, Overlays, and supported map classes.
Videos
Web API Edition Sample App Walkthrough Video Series
Step through the Web API Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Screenshot
Getting Started
Screenshot
Overlays
Screenshot
Layers
Screenshot
Styles
Screenshot
Visualizing Data
Screenshot
Labeling
Screenshot
Markers & Pop Ups
Screenshot
Drawing & Editing
Screenshot
Querying
Screenshot
Projection
Screenshot
Geometric Functions
Screenshot
Project Templates
Screenshot
WebAPI Webinar November 19, 2015
Screenshot
Adornments
Screenshot
Topology
Screenshot
Printing
Creating Custom Styles
Exploring Layers
Exploring Layers
FDO, OGR and GDAL Extension
Printing System Introduction
Tile Cache Generator
Topology Validation
Topology Validation
Screenshots
Screen Shots of the Web API Edition on different types of devices.
Traditional Browsers
Getting Started with Map
Visualization
Visualization
LabelStyling
LabelStyling
GeoFunctions
GeoFunctions
DrawEditFeatures
DrawEditFeatures
SiteSelection
SiteSelection
Visualization-weather
Tablets
GettingStarted
GettingStarted
Visualization
Visualization
LabelStyling
LabelStyling
GeoFunctions
GeoFunctions
DrawEditFeatures
DrawEditFeatures
SiteSelection
SiteSelection
Phones
GettingStarted
GettingStarted
Visualization
Visualization
LabelStyling
LabelStyling
GeoFunctions
GeoFunctions
DrawEditFeatures
DrawEditFeatures
SiteSelection
SiteSelection
Change Logs
  • API Change Log
    The WebAPI Edition change log details the changes made to the product for each major release cycle.
Frequently Asked Questions
  • All Questions
    All the frequently asked questions about Map Suite Web API Edition.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_webapi_edition.txt · Last modified: 2017/03/16 09:04 by tgwikiupdate
