map_suite_webapi_edition_quick_start_guide
Map Suite WebAPI Edition Quick Start Guide
The Map Suite WebAPI Edition illustrated QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This edition of the QuickStart Guide supports Map Suite WebAPI Edition 9.0.0.0 and higher, and will show you how to create a ASP.NET WebAPI application using this product.
If you want to build a Web Forms application using the standard Map Suite Web Edition product, please see the Web Edition QuickStart Guide instead.
Welcome to Map Suite™ WebAPI Edition from ThinkGeo, a full-featured mapping control that makes it easy for any Microsoft .NET developer to add mapping functionality to a Microsoft .NET application quickly and efficiently. Using the intuitive object model, even developers inexperienced in geographic information systems (GIS) can create fully functional maps in minutes.
Before we get started, make sure you've installed the ThinkGeo Product Center and that you've either started an evaluation or activated a full license of Map Suite WebAPI Edition. By default, this will install the Map Suite WebAPI Edition 9.0 assemblies to C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite WebAPI.
Download the Sample
Setting up the Environment
Let's start by creating a new WebAPI application in Visual Studio.NET 2012 IDE named “HelloWorld” (see Figure 1). Set the Templates to “.NET Framework 4.5” for the project. In next wizard page, select the “Empty” template; this means that your sample project won't have any built-in pages or functionalities.
If you are using Visual Studio.NET 2010, you need to install VS2010 SP1, and then create an ASP.NET MVC Web Application.
This Quick Start Guide uses a WebAPI application as an example, so you will need to have the ASP.NET MVC framework installed in order to follow along. The MVC 4 framework can be downloaded from ASP.NET MVC 4 Tools Update.
Figure 1. Creating a new project in Visual Studio.NET 2012 IDE.
To take advantage of the Asp.NET WebAPI, please go to “Tools” > “Library Package Manager” > “Package Manager Console”, then input “Install-Package Microsoft.AspNet.WebApi -Pre” and press Enter to install the lasted assemblies.
Figure 2. Installing the WebAPI DLLs.
Map Suite WebAPI "Hello World" Sample
In this section, we'll use Map Suite WebAPI Edition to display a map that uses your own data.
To begin, in the Default.htm file, let's enter a few lines of code that will display a simple map. Next, we'll have a look at the data and the important objects we'll use.
Display a Simple map
The first step in creating our “Hello World” sample application is to add a html file named Default.htm and include code that similar to the example below.
Figure 3. Adding Default.htm.
<!DOCTYPE html>
<html>
<head>
    <title>Hello World</title>
    <link rel="stylesheet" href="http://cdn.leafletjs.com/leaflet-0.7.3/leaflet.css" />
</head>
<body>
    <div id="map" style="height: 800px; width: 1200px"></div>
</body>
<script src="http://cdn.leafletjs.com/leaflet-0.7.3/leaflet.js"></script>
<script>
    var map = L.map('map', { zoomAnimation: false }).setView([[39.6948,|-96.8150]], 4);
    <nowiki>//</nowiki> add thinkgeo map
    L.tileLayer.wms('http://{s}.thinkgeo.com/CachedWMSServer/WmsServer.axd', {
        subdomains: [['worldmapkit1',|'worldmapkit2', 'worldmapkit3', 'worldmapkit4', 'worldmapkit5', 'worldmapkit6']],
        layers: 'OSMWorldMapKitLayer',
        format: 'image/png',
        styles: 'WorldMapKitDefaultStyle',
        version: '1.1.1',
        attribution: '<a href="http://thinkgeo.com/map-suite-developer-gis/world-map-kit-sdk/">ThinkGeo</a> | &copy; <a href="http://osm.org/copyright">OpenStreetMap</a> contributors '
    }).addTo(map);
</script>
</html>
Now press F5 to build and run your application. It should look like this:
Figure 4. The basic map display.
Shapefiles
Map Suite WebAPI Edition supports multiple kinds of data sources including Shapefiles, TAB files, SQL Server 2008, PostgreSQL, Oracle, etc. Here we'll provide an introduction to Shapefiles, which we'll use in the next section of this Quick Start Guide.
Maps are generally made up of shapes like lines (representing roads), dots (for points of interest, such as cities and towns at small scales), and polygons (delineating parks, etc.). Shapefiles store the coordinates that are used to draw or render these shapes. Shapefiles have a .shp extension.
Shapefiles also come with two supplementary files that help Map Suite work with the data.
ShapeFileFeatureLayers
Styles
PresetZoomLevels
worldLayer.ZoomLevelSet.ZoomLevel03.DefaultAreaStyle = AreaStyles.Country1;
worldLayer.ZoomLevelSet.ZoomLevel03.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level10;
Now let's look at the code needed to bring this concept to fruition.
We need to add two Map Suite files, “WebApiEdition.dll” and “MapSuiteCore.dll”, to the reference. Right-click on “References” in Solution Explorer and select “Add Reference…”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite WebAPI\Current Version\Managed Assemblies folder, and select both “WebApiEdition.dll” and “MapSuiteCore.dll”.
Figure 5. Adding the references.
Our next step is to add our Shapefile layers to the map. For this example, we'll use a Shapefile containing worldwide country borders. We have one such Shapefile available to us:
  • Worldwide country borders (cntry02.shp)
(NOTE: The data used in this sample can be found in the attached sample above in the “\AppData” folder.)
Let's add a controller named “HelloWorldController”, like this:
Figure 6. Adding the "HelloWorldController".
Then add the following code to HelloWorldController:
using System.Drawing;
using System.Drawing.Imaging;
using System.IO;
using System.Net;
using System.Net.Http;
using System.Net.Http.Headers;
using System.Web;
using System.Web.Http;
using ThinkGeo.MapSuite.Core;
using ThinkGeo.MapSuite.WebApiEdition;
namespace HelloWorld.Controllers
    [RoutePrefix("HelloWorld")]
    public class HelloWorldController : ApiController
        [Route("tile/{z}/{x}/{y}")]
        [HttpGet]
        public HttpResponseMessage GetTile(int z, int x, int y)
            <nowiki>//</nowiki> We create a new Layer and pass the path to a Shapefile into its constructor.
            ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(HttpContext.Current.Server.MapPath(@"~/App_Data/cntry02.shp"));
            ManagedProj4Projection proj4 = new ManagedProj4Projection();
            proj4.InternalProjectionParametersString = Proj4Projection.GetWgs84ParametersString();
            proj4.ExternalProjectionParametersString = Proj4Projection.GetSphericalMercatorParametersString();
            proj4.Open();
            worldLayer.FeatureSource.Projection = proj4;
            // Set the worldLayer to use a preset Style. Since AreaStyles.Country1 has a YellowGreen background and Black border, our worldLayer will have the same render style.
            // This setting will apply from ZoomLevel01 to ZoomLevel20, which means the map will be rendered in the same style, no matter how far we zoom in or out.
            using (Bitmap bitmap = new Bitmap(256, 256))
                GdiPlusGeoCanvas geoCanvas = new GdiPlusGeoCanvas();
                RectangleShape boundingBox = WebApiExtentHelper.GetBoundingBoxForXyz(x, y, z, GeographyUnit.Meter);
                geoCanvas.BeginDrawing(bitmap, boundingBox, GeographyUnit.Meter);
                layerOverlay.Draw(geoCanvas);
                geoCanvas.EndDrawing();
                MemoryStream ms = new MemoryStream();
                bitmap.Save(ms, ImageFormat.Png);
                HttpResponseMessage msg = new HttpResponseMessage(HttpStatusCode.OK);
                msg.Content = new ByteArrayContent(ms.ToArray());
                msg.Content.Headers.ContentType = new MediaTypeHeaderValue("image/png");
                return msg;
So what has occurred here? We've created a layer and added it to the map, and the map has rendered it according to its default style parameters. We've also used ZoomLevel to display the map the way we want.
The attributes [RoutePrefix(“HelloWorld”)] and [Route(“tile/{z}/{x}/{y}”)] are for custom route, we can easily access it by '/HelloWorld/tile/{z}/{x}/{y}'. To make it work, we need to modify the WebApiConfig.cs, like this:
public static void Register(HttpConfiguration config)
     // Web API routes
     config.MapHttpAttributeRoutes();
     config.Routes.MapHttpRoute(
        routeTemplate: "api/{controller}/{id}",
       defaults: new { id = RouteParameter.Optional }
     config.EnsureInitialized();
Now that the server side is ready, let's support it adding the following code to the client side:
L.tileLayer('/HelloWorld/Tile/{z}/{x}/{y}').addTo(map);
</source>
After adding, it will look like as following:
<code javascript>
<script>
    // add thinkgeo map
        version: '1.1.1',
    }).addTo(map);
</script>
If you compile and run what you have now, your map should look like the screenshot below. (See Figure 7).
Figure 7. A simple map of the world.
  1. World country borders (“cntry02.shp”)
  2. World capitals (“capital.shp”)
Change the code in server side to correspond with the following example. You don't need to make any changes to client side.
[HttpGet]
    proj4.Open();
    // Set the worldLayer to use a preset style. Since AreaStyles.Country1 has a YellowGreen background and Black border, our worldLayer will have the
    //same render style.
    // This setting will apply to all zoom levels from ZoomLevel01 through ZoomLevel20, so the same style will be rendered no matter how far we zoom in or out.
    // Capital layer
    ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(HttpContext.Current.Server.MapPath("~/App_Data/capital.shp"));
    capitalLayer.FeatureSource.Projection = proj4;
        return msg;
Figure 8. A basic map of the Americas with the additional borders and capitals layers displayed.
How to Use TextStyle
Figure 9. Attribute data from the .dbf file.
[HttpGet]
    proj4.Open();
    // Set the worldLayer to use a preset style. Since AreaStyles.Country1 has a YellowGreen background and Black border, our worldLayer will have the same render style.
    // Capital layer
    // Label layer
    ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(HttpContext.Current.Server.MapPath("~/App_Data/capital.shp"));
    capitalLabelLayer.FeatureSource.Projection = proj4;
    // We'll use a preset TextStyle. Here we pass in "CITY_NAME", the name of the field containing the values we want to label the map with.
    // Since the map is drawn with tiles, the label needs to draw on the margin to make sure the text is complete after joining the tiles together.
    // Change the number below (to 0, for example) to better understand how this works.
        return msg;
Figure 10. Map of the Americas with TextStyle applied.
[HttpGet]
    // Create a new Layer and pass the path to a Shapefile into its constructor.
    proj4.Open();
    // Capital layer
    // The Style we set here is applied from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, this particular style will no longer be visible.
    // The Style we set here is applied from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, this particular style will no longer be visible.
    // Label layer
    // We can customize our own TextStyle. Here we pass in the font, the size, the style and the color.
    // The TextStyle we set here is applied from ZoomLevel01 to ZoomLevel05.
    // The TextStyle we set here is applied from ZoomLevel06 to ZoomLevel20.
        return msg;
Can you imagine what the map will look like now? Figure 11 below is the result. At first it looks the same as it did in Figure 10. Now zoom in, and watch the map change to resemble Figure 12.
Figure 11. European cities with two ZoomLevels, before zooming in.
Figure 12. European cities with two ZoomLevels, after zooming in.
Perform an AJAX HTTP request to the Action of the Controller
Map Suite WebAPI Edition provides a large number of client APIs that allow us to easily operate the map on client side, just as we've done on the server side in the above sample code.
Here we'll show you how to perform an AJAX request to update the layers of the map according to the different parameters passed in from the client.
We will need to access the parameters passed from here in the action.
The code in your client side should look like this:
<!DOCTYPE html>
<html>
<head>
</head>
<body>
    <div>
        <input id="chKAddStates" name="group1" type="radio" value="Show US States" onclick="updateLayer('usstates')" />
        Show US States
    <br />
        <input id="chKAddCites" name="group1" type="radio" value="Show US Counties" onclick="updateLayer('uscities')" />
        Show US Cities
    <br />
    </div>
</body>
<script>
    // add thinkgeo map
        version: '1.1.1',
    }).addTo(map);
    var worldLayer = L.tileLayer('/HelloWorld/Tile<nowiki>//</nowiki>{z}/{x}/{y}').addTo(map);
    function updateLayer(layerId) {
        worldLayer.setUrl('/HelloWorld/Tile/' + layerId + '/{z}/{x}/{y}');
        worldLayer.redraw();
</script>
</html>
Now copy and paste the code below about the accessed action into your “HelloWorldController” page:
[Route("tile/{layerId}/{z}/{x}/{y}")]
[HttpGet]
public HttpResponseMessage GetTile(string layerId, int z, int x, int y)
    proj4.Open();
    if (layerId.ToLowerInvariant() == "usstates")
        // States layer
        ShapeFileFeatureLayer statesLayer = new ShapeFileFeatureLayer(HttpContext.Current.Server.MapPath("~/App_Data/USStates.shp"));
        statesLayer.FeatureSource.Projection = proj4;
        statesLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.State1;
        statesLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
        layerOverlay.Layers.Add(statesLayer);
    else if (layerId.ToLowerInvariant() == "uscities")
        // Cities layer
        ShapeFileFeatureLayer countyLayer = new ShapeFileFeatureLayer(HttpContext.Current.Server.MapPath("~/App_Data/cities_a.shp"));
        countyLayer.FeatureSource.Projection = proj4;
        countyLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital3;
        countyLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.Capital3("AREANAME");
        countyLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
        layerOverlay.Layers.Add(countyLayer);
        return msg;
Figure 13. Note the client side layer display control that now appears below the map.
You can click the check boxes for “Show US States” or “Show US Cities” to load different layers to the map. For example, if you check the “Show US States” box, the map should look like this:
Figure 14. Map with states layer shown.
if you check the “Show US Cities” box, the map should look like this:
Figure 15. Map with cities layer shown.
Summary
You now know the basics of using Map Suite WebAPI Edition and can start adding this functionality to your own applications. Let's recap what we've learned about the object relationships and how the pieces of Map Suite work together:
  1. It is of the utmost importance that the units (feet, meters, decimal degrees, etc.) be set properly for the Map control, based on the requirements of your data.
  3. A Layer can have one-to-many ZoomLevels. ZoomLevels help to define ranges (upper and lower scales) of when a Layer should be shown or hidden.
Download Sample Code From This Exercise (12.5 MB)
map_suite_webapi_edition_quick_start_guide.txt · Last modified: 2017/03/17 04:59 by tgwikiupdate
