map_suite_webapi_printing
Map Suite WebAPI Printing
Video Overview
Overview
This project shows you how to add robust printing support to your WebAPI application. Using the code in this sample you will be able to build a print preview interface that lets your users interactively arrange items such as a map, scale line, labels, data grid, or image on a virtual page before printing the result to a printer, exporting to a PDF or to a bitmap image. Maps are printed using vector graphics so you can be sure the output will look great on anything from a PDF or even a large plotter. The printing system also includes low-level report building classes that make it easy to generate reports in a web environment.
Printer Layers
This sample shows you different APIs that allows you to build your own printing system. Some of the features include adding labels, images, scale lines, scale bars, and data grid.
Label Printer Layer
Border
Label printer layers.
The label printer layer allows you to add a label to the page. The user has full control and can customize the font and content of the label.
Image Printer Layer
Border
Image printer layers.
The image printer layer allows you to add an image to the page. You can customize the image and the image size on the page.
Scale Line Printer Layer
Border
Scale line printer layers.
The Scale Line printer layer allows you to add Scale Line to the page.
Scale Bar Printer Layer
Border
Scale Bar printer layers.
The scale bar printer layer allows you to add a scale bar to the page.
Data Grid Printer Layer
Border
The data grid printer layer shows how to add a data grid to the page. In the sample the data grid shows the columns with the countries that have population > 150 million.
Print Preview allows users to specify paper size, page orientation, and percentage.
Paper Size
Users can specify paper size to predefined sizes such as ANSI A-8.5 x 11(A4), ANSI B-11 x 17(A3), ANSI C-17 x 22(A2), ANSI D-22 x 34(A1), ANSI E-34 x 44(A0) or create custom sizing.
Orientation
Border
Portrait.
Border
Landscape.
Users can select portrait and/ or landscape for page orientation.
Export
This sample shows how you can export the page printer layer, save it as bitmap, PDF and how to print.
map_suite_webapi_printing.txt · Last modified: 2015/12/21 21:17 by mwolffer
