thinkgeo.mapsuite.core.linkexpression
ThinkGeo.MapSuite.Core.LinkExpression
article_rating
<!– Class –> (This class is not finally released, it is possible to be removed in the next public release)
Protected Method*LinkExpression String, LinkSource
Public Method*Equals Object Object
Public Method*GetFormattedExpression
Public Method*GetHashCode Object
Public Method*GetType Object
Public MethodStatic Member*Parse String, LinkSource
Public Method*ToString Object
Protected Method*Finalize Object
Protected Method*MemberwiseClone Object
Public Property*Expression String
Public Property*LeftKey String
Public Property*LeftValue String
Public Property*LinkSource LinkSource
Public Property*Operator String
Public Property*RightKey String
Public Property*RightValue String
*LinkExpression(String, LinkSource)
Name Type Description
expression String<!– System.String –>
linkSource LinkSource<!– ThinkGeo.MapSuite.Core.LinkSource –>
Go Back
*Equals(Object)
Return Type Description
Boolean<!– System.Boolean –>
*GetFormattedExpression()
<!– ThinkGeo.MapSuite.Core.LinkExpression –> Go Back
*GetHashCode()
Int32<!– System.Int32 –>
*GetType()
Type<!– System.Type –>
*Parse(String, LinkSource)
<!– static –>
LinkExpression<!– ThinkGeo.MapSuite.Core.LinkExpression –>
*ToString()
*Finalize()
Void<!– System.Void –>
*MemberwiseClone()
*Expression
Return Type
*LeftKey
Return Type
*LeftValue
Return Type
*LinkSource
Return Type
*Operator
Return Type
*RightKey
Return Type
*RightValue
Return Type
NOTOC Note: * – not public released, might be removed in the next release. MapSuiteCore ThinkGeo.MapSuite.Core UpdateDocumentation
thinkgeo.mapsuite.core.linkexpression.txt · Last modified: 2017/03/16 21:59 (external edit)
