map_suite_webapi_edition_features_bug_fixes_change_log
Map Suite WebAPI Edition Features & Bug Fixes Change Log
Version 9.0.0.0
Release date: 06/24/2015
  • Added the new API SetWellKnownBinary(byte wkb) to Feature class to allow changing the WKB of the feature.
  • Improved the performance of method byte ShapeFile.ReadPolygon(byte dataBytes, int startIndex).
  • Added Leader Lines.
Version 8.0.0.150
First Release date: 07/11/2014
First Release - No Changes
map_suite_webapi_edition_features_bug_fixes_change_log.txt · Last modified: 2015/09/09 08:54 by admin
