We've certified a number of popular GPS tracking devices for use with the Map Suite GPS Tracking Server. Certifying a device means that we have developed and tested a “listener” that enables Map Suite GPS Tracking Server to communicate with the device, and that you'll be able to start using these devices with no further development necessary. Please note that not all of a device's features may be supported, but at a minimum you will be able to see the location of the device on your map.
Ultraportable personal tracking device with auto reporting and monitoring via SMS or GPRS.
Supported Device Messages:
Installable device suitable for vehicles or rental devices, featuring quad-band GSM/GPRS and 48-hour battery life.
Compact vehicle tracking device that provides easy installation and reporting of OBD information.
Ultraportable personal tracking device with panic button, 2 sets of open I/O and real-time tracking capability.
Vehicle and asset tracker with built-in vibration sensor.
Ultraportable personal tracking device with panic button. Programmable auto-reporting.
Designed for permanent installation in vehicles or other high-value assets.
Installable tri-band device with multiple I/O, vehicle ignition input and peripheral device support.
Listener address: 184.73.199.2
Port: UDP 1893<br>
Debug Communications Log
Installable quad-band device in a rugged housing, ideal for industrial tracking.
Listener address: 184.73.199.2<br> Port: TCP 1899<br> Debug Communications Log
Installable device, inexpensive, versatile and features multiple I/O interfaces. Good for vehicles.
Listener address: 184.73.199.2<br> Port: UDP 1890<br> Debug Communications Log
Installable device features a complex scripting system for custom tracking applications.
Listener address: 184.73.199.2<br> Port: TCP 1896<br> Debug Communications Log
AVL GPS tracker for car and fleet management.
Installable device with multiple I/O ports designed for automotive use (fleet tracking, stolen vehicle recovery, etc.).
Listener address: 184.73.199.2<br> Port: TCP 1865<br> Debug Communications Log
Installable, waterproof device intended for vehicle, security and recovery tracking.
Port: TCP 1865
Don't See Your Device Listed? Adding New Hardware is Easy.
If you have tracking devices that aren't listed here, all is not lost. Map Suite GPS Tracking Server's versatile Device Gateway system and Device Simulator application make it easy for .NET programmers to add support for their own custom or specialty tracking devices in just a few lines of code. (Custom device integration capability on GPS Tracking Server Express Edition is limited; please contact us for details.)
If you aren't development-inclined or don't have the programming resources, ThinkGeo's professional services team can help you integrate your custom hardware into your Map Suite GPS Tracking Server solution. We'll tailor your installation to work with your devices and customize their interaction with the system to meet your specific needs. If you need professional device integration with the GPS Tracking Server, simply let us know.
