The SANAV GX-101 is a device designed for vehicle installation. It allows for configuration via SMS-text messages and via SANAV's PC-based utility. Here we describe how to configure the GX-101 via SMS. This guide assumes the GX-101 is already installed in a vehicle.
Listener address: http://ct24.cygnustrack.com/default.aspx
Check the Tracking Device Connection Guide before configuring your device: Tracking Device Connection Guide
The default username is username.
The default password is 0000.
This command sets the APN to c1.korem2m.com. Replace this with your own APN value.
This commands specifies the HTTP address that the device sends its location messages to.
This command specifies that the device will only send out information using HTTP.
This command enabled Auto Track where the device will send out its location every 30 seconds.
9999 means the device will send out messages any time it is turned on.
