map_suite_desktop_for_wpf
Map Suite Desktop for Wpf
Map Suite Desktop for Wpf takes GIS application development for the Windows desktop to a whole new level, with a .NET-native control that packs the full power of Windows Presentation Foundation (WPF). With blazing fast rendering performance, powerful mapping features and support for the most popular data formats, Map Suite Desktop for Wpf makes GIS accessible to developers of any skill.
Product Guides
Helps you get you up to speed with integrating the Map Suite Desktop for Wpf map control into your your GIS software.
Explains how to use styles in Map Suite to beautifully represent your GIS mapping data. The guide includes an overview of styles, a detailed explanation of the various styles that ship with Map Suite, as well as a step by step guide of creating your own custom styles.
Introduces the dependencies Map Suite Desktop for Wpf needs with their features, versions and source websites.
API Documentation
  • ThinkGeo.MapSuite.Wpf
    The Desktop for Wpf API documentation covers the ThinkGeo.MapSuite.Wpf namespace which resides in the ThinkGeo.MapSuite.Wpf.dll assembly. It contains all of the Desktop for Wpf specific classes such as the map control itself, Overlays, and supported map classes.
Package
Standard
Compare with Barebone
Barebone
Compare with Standard
Code Samples
In addition to the samples below, we have dozens of interactive Desktop for Wpf sample applications available.
All Samples
All samples about Map Suite Map Suite Desktop for Wpf.
Project Templates
These projects show various study cases based on Map Suite Desktop for Wpf.
Background Maps
InteractiveOverlays
Labeling
Layers & FeatureSources
Miscellaneous
Printing
Projection
Spatial Functions
Styles
Vehicle Tracking
Zooming Panning Moving
Videos
Map Suite Desktop for Wpf Sample App Walkthrough Video Series
Step through the Map Suite Desktop for Wpf sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Introduction to the Desktop for Wpf
Creating Custom Styles
Exploring Layers
Exploring Layers
FDO, OGR and GDAL Extension
Printing System Introduction
Tile Cache Generator
Topology Validation
Topology Validation
Screenshots
The Map Suite Desktop for Wpf screenshots gallery section showcases a wide range of screenshots covering various GIS features of the Map Suite Desktop for Wpf map control.
Add rich aerial imagery
Supports JPEG2000, TIFF, MrSid, ECW and more
Add rich aerial imagery Supports JPEG2000, TIFF, MrSid, ECW and more
SQL query feature layers
Get column data
Visually render SQL data
SQL query feature layers Get column data Visually render SQL data
Uses ZedGraph classes
Automatic color family generation
Group colors by hue or quality
Automatic color family generation Group colors by hue or quality
Draw or exclude features based on conditions
Render based on data points
Draw or exclude features based on conditions Render based on data points
Restrict drawing of features
Fill restricted areas with patterns or bitmaps
Restrict drawing of features Fill restricted areas with patterns or bitmaps
Plots points on your map
Point density represents numeric data
Puts you in control
Useful for points & labels
Render features specifically based on a theme
Colorize map features
Project your spatial data
Real-time rotation
Draw an image at a point
Dozens of interactive sample applications
Source code in C#
Dozens of interactive sample applications Source code in C#
Change Logs
  • API Change Log
Frequently Asked Questions
  • All Questions
    All the frequently asked questions about Map Suite Desktop for Wpf.
  • General Questions
  • Background Maps
    These frequently asked questions cover showing how to incorporate 3rd part background map with your application.
  • InteractiveOverlays
    These frequently asked questions cover various aspects of how to extend or create InteractiveOverlays. Examples of InteractiveOverlay functions are things such as drawing track shapes, shape editing and track extents.
  • Labeling
    These frequently asked questions cover various aspects of labeling features.
  • Layers & FeatureSources
    These frequently asked questions cover custom layers and feature sources from which you can get inspired to integrate your own data.
  • Miscellaneous
    These frequently asked questions cover various of other technical features of the products that are not included in other categories.
  • Projection
    These frequently asked questions cover various aspects of projection such as how to re-project your data.
  • Spatial Functions
    These frequently asked questions cover various spatial functions such as union, buffer, merging data etc.
  • Styles
    These frequently asked questions cover displaying your GIS data using various styles. Some examples of styles would include using class breaks, clustering points, heat maps, etc.
  • Vehicle Tracking
    These frequently asked questions cover various features related to vehicle and asset tracking.
  • Zooming Panning Moving
    These frequently asked questions cover various ways to move the map.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_desktop_for_wpf.1488437750.txt.gz · Last modified: 2017/03/02 06:55 by tgwikiupdate
