map_suite_desktop_for_wpf_quick_start_guide
Map Suite Quick Start Guide For Wpf
The purpose of this guide is to help you quickly get started building your own spatially aware applications. Like any new software, there is some learning to be done.How do we start to learn how to take advantage of the power of Map Suite? The best way is to make a sample application with it.
Download the Sample
Setting up the Environment
Let's start with a new WPF project in Microsoft Visual Studio (2015 or newer) and call it QuickstartSample (see Figure 1). We can create the project with .NET Framework 4.0 or 4.5.
The project QuickstartSample is created in a new solution called QuickstartSample. The wizard creates a single WPF Application. Next we need to install MapSuiteDesktopForWpf-Standard from nugget package server (see Figure 2-5).
Figure 2. Refer to Manage NuGet Packages.
Figure 3. Refer to MapSuiteDesktopForWpf - Standard.
Click “OK” if the message box like Figure 4 pops up.
Figure 4. Review package references.
The “NetTopologySuite” is the third part assembly, so the license acceptance is required. You can click “I Accept” to agree the license.(See Figure 5)
Adding the Map Control
Open “…/QuickstartSample/packages/MapSuiteDesktopForWpf-Standard.10.0.0/designtime” package folder and drag “ThinkGeo.MapSuite.Wpf.dll” assembly to the Toolbox of Visual Studio.
Draw the Map control on the MainWindow by clicking on the WpfMap Control object in the Toolbox and then dragging(using the left mouse button) it to the MainWindow. You can resize the map if you desire. You can leave the name of the Map control as Map1. Our map will display in this object.
The second way. You can open your .xaml file and add reference code to refer Wpf map to your application (See Figure 6)
<Window x:Class="HelloWorld.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        xmlns:local="clr-namespace:HelloWorld"
        mc:Ignorable="d"
        xmlns:uc1="clr-namespace:ThinkGeo.MapSuite.Wpf;assembly=ThinkGeo.MapSuite.Wpf"
        Title="MainWindow" Height="600" Width="800">
    <Grid>
        <uc1:WpfMap Name="Map1" Loaded="Map1_Loaded"/>
    </Grid>
</Window>
Figure 6. Add Map Control to your application.
If you have not set up a developer license, ​the Map Suite Product Center will pop up when you debug the app. You need to generate your developer license. For more details, please refer to http://wiki.thinkgeo.com/wiki/map_suite_developer_license_guide.
Once the developer license is ready, run the application. Your map should look like the one below: (see Figure 7).
Figure 7. The normal map is rendered after the developer license file has been got.
Map Suite Desktop for Wpf "QuickstartSample"
In creating our “QuickstartSample“ application, our first step is to set references to the ThinkGeo.MapSuite.Layers, ThinkGeo.MapSuite.Styles and ThinkGeo.MapSuite.Wpf workspaces at the very top of our code, as we will use many classes within them. We do this so that we do not have to use the fully qualified name of the Map Suite classes throughout our code. Setting a reference to the Map Suite workspace can be done in the “code-behind” of the form by selecting the form and hitting the F7 function key. Set the reference like this:
using ThinkGeo.MapSuite;
using ThinkGeo.MapSuite.Wpf;
* The borders of every country in the world (Countries02.shp)
Our next step is to define and add our Layers. All of the following code can be placed in the ​Map1_Loaded​ event of the form. Here is the code to use for our example.
private void Map1_Loaded(object sender, RoutedEventArgs e)
    // Set the Map Unit. The reason for setting it to DecimalDegrees is that is what the shapefile’s unit of measure is inherently in.
    ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"../../Data/Countries02.shp");
    // This setting will apply from ZoonLevel01 to ZoomLevel20, that means we can see the world the same style with ZoomLevel01 all the time no matter how far we zoom out/in.
    // Create a new Layer Overlay to hold the layer we just created
    // Add a background Layer
    layerOverlay.Layers.Add(new BackgroundLayer(new GeoSolidBrush(GeoColor.GeographicColors.ShallowOcean)));
    // Add the shapefile layer to the layer overlay
    // We need to add the layerOverlay to map.
    Map1.Overlays.Add(layerOverlay);
    // Set a proper extent for the Map.
    Map1.CurrentExtent = new RectangleShape(-134, 70, -56, 7);
    // We now need to call the Refresh() method of the Map control so that the Map can redraw based on the data that has been provided.
    Map1.Refresh();
You can get a normal map render (See Figure 8)
Figure 8 QuickstartSample Run Result.
So what has occurred here? We have created a layer and added it to the Map and the Map has rendered according to its default style parameters. Also, we have used ZoomLevel to display the map the way that we want.
NOTE: It is important that the “MapUnit” property of a Map object be set using the “GeographyUnit” enumeration. This is because ShapeFiles only store binary vector coordinates, which can be in DecimalDegree, feet, meters, etc., and our map has no idea about what the unit of measurement is until we set it. This information is normally found somewhere in the documentation or within the supplemental data file as discussed in the section on ShapeFiles.
  1. The borders of every country in the world (“Countries02.shp”)
  2. The capitals of the world countries (“WorldCapitals.shp”)
    ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(@"../../Data/WorldCapitals.shp");
    pointStyle.SymbolSize = 6;
    stackStyle.SymbolSize = 2;
    // This setting also applies from ZoonLevel01 to ZoomLevel20, that means we can see city symbols the same style with ZoomLevel01 all the time.
    // We need to add both of the new layers to the Layer OverLay.
    Map1.Refresh();
And the result is as follows (Figure 9):
Figure 9. Map of Europe with 2 layers.
How to Use GeoTextStyle
TextStyle
TextStyles are used to label items on the map. As every ShapeFile has a relative .dbf file that includes descriptions for every record, the most common way to use TextStyles is for labeling. For example, the WorldCapitals Shapefile's corresponding .dbf file contains the field “CITY_NAME”. We can use this field to label the cities on our map.
    ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(@"../../Data/WorldCapitals.shp");
    textStyle.XOffsetInPixel = 0;
    // We use the preset TextStyle. Here we passed in the “CITY_NAME”, which is the name of the field we want to label on map.
    // As the map is drawn by tiles, it needs to draw on the margin to make sure the text is complete after we joining the tiles together.
    // Change the number to another one (for example 0) and you can see the difference expecially when panning.
    Map1.Refresh();
Figure 10. Map of Europe with a TextStyle.
    // The Style we set here is available from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, the appearance we set here will not be visible anymore.
    // The Style we set here is available from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, the appearance we set here will not be visible any more.
    // We can customize our own TextStyle. Here we passed in the font, the size, the style and the color.
    Map1.Refresh();
Can you imagine what the map will look like now? Below is the result. At first it appears like figure 11, and the map changes to figure 12 as you zoom in.
Figure 11. Map of Europe with two ZoomLevels, before Zoom In.
Figure 12. Map of Europe with two ZoomLevels, after Zoom In.
This completes ​this scenario. The next thing you might want to do is to make it run on another machine ​that does not have a developer license. ​A runtime ​license is the one we are looking for. Here is a guide to generate a runtime license to satisfy it, please refer to (http://wiki.thinkgeo.com/wiki/map_suite_runtime_license_guide_for_desktop ) for details.
Summary
You now know the basics of using the Map Suite Map control and are able to get started adding functionality into your own applications. Let's recap what we have learned about the object relationships and how the pieces of Map Suite work together:
  1. It is of the utmost importance that the units (feet, meters, decimal degrees, etc.) be set properly for the Map control based on the data.
  3. A Map is the basic control that contains all of the other objects that are used to tell how the map is to be rendered.
  4. A Map has one-to-many Layers. A Layer correlates one-to-one with a shape file (.shp).
  5. A Layer can have one-to-many ZoomLevels. ZoomLevels help to define ranges (upper and lower) of when a Layer should be shown or hidden.
map_suite_desktop_for_wpf_quick_start_guide.txt · Last modified: 2017/03/23 07:11 by tgwikiupdate
