map_suite_desktop_for_wpf_spatial_functions_samples
Wpf Samples
Adjacent Road Search Sample for Wpf
This WPF project shows how to get a route between two adjacent roads, even if they don't intersect within an allowable tolerance.
It’s based on Map Suite Geometry Topology module and does not require the Map Suite Routing Extension.
Screenshot
View this sample on Github
Distance Query On Wrap Dateline Mode Sample for Wpf
This WPF sample shows how to take advantage of the projection class WrapDatelineProjection for doing spatial queries when on a “virtual map”. From this spatial query example, the developer should understand how the same principle using the same projection class can be applied for other operations such as Spatial Queries, Identify, etc.
Screenshot
Find Shortest Line And Splitting Lines Sample for Wpf
Screenshot
Polygon Shapes To Multipolygon Shape Sample for Wpf
Screenshot
map_suite_desktop_for_wpf_spatial_functions_samples.txt · Last modified: 2020/03/08 06:41 (external edit)
