map_suite_desktop_for_wpf_zooming_panning_moving_samples
Wpf Samples
Zoom To Full Extent Wpf Sample for Wpf
This is a simple project that shows how to set the current extent based on a collection of layers. You can use this technique for the common task of having the map set to the full extent. Instead of having to manually set the full extent, you can pass all the layers you want the full extent to be based on.
Screenshot
View this sample on Github
Rotate Events Sample for Wpf
Screenshot
Touch Events Sample for Wpf
This sample shows how to take advantage of touch screen to manipulate that map using one’s fingers. Learn how the map can be panned, zoomed in and out or rotated using two fingers. On addition, markers can be added, and shapes can be added and edited by tapping the screen.
The sample code makes this straight forward to implement.
Screenshot
Centering And Rotating Sample for Wpf
Screenshot
Multiple Jpeg2000 Raster Layer Sample for Wpf
Screenshot
map_suite_desktop_for_wpf_zooming_panning_moving_samples.txt · Last modified: 2020/03/08 06:41 (external edit)
