thinkgeo_desktop_for_wpf
ThinkGeo UI Desktop WPF for .NET Core
Note: This version of ThinkGeo UI Desktop WPF is based on .NET Core and is NOT compatible with .NET Framework 4 or earlier. Please use Map Suite 10 if you want to stay with .NET Framework. To upgrade a previously-built .NET Framework project to .NET Core, please refer to our guide "Updating from .NET Framework to .NET Core".
ThinkGeo UI Desktop WPF for .NET Core takes GIS application development for the Windows desktop to a whole new level, with a .NET Core-native control that packs the full power of Windows Presentation Foundation (WPF). With blazing fast rendering performance, powerful mapping features and support for the most popular data formats, ThinkGeo UI Desktop WPF for .NET Core makes GIS accessible to developers of any skill.
Getting Started
You can start developing your ThinkGeo WPF project by basing it on our samples from GitHub, or by creating a new application in Visual Studio or VS Code. Take a look at the short videos below for a step-by-step walkthrough.
ThinkGeo Desktop for Wpf Quickstart On Windows
Run GitHub Samples in Visual Studio (2:30)
ThinkGeo UI Desktop WPF Hello World
Create Hello World project in VS Code (3:09)
Helps you get you up to speed with integrating the ThinkGeo Desktop for .NET Core map control into your GIS software.
Product Guides
Walks you through installing the ThinkGeo UI control on your system and creating a simple GIS application.
Introduces what licenses are needed and how licensing works for debugging and deploying projects using ThinkGeo UI.
Introduces the dependencies required by ThinkGeo Desktop for .NET Core, along with their features, versions and source websites.
Walks you through deploying your ThinkGeo UI project to your user base.
Lists the various GIS data formats that are supported by the ThinkGeo UI map control, as well as any caveats to be aware of with certain formats.
Describes how to upgrade to ThinkGeo UI 12 from previous versions of ThinkGeo UI or ThinkGeo Map Suite.
Explains how to use ThinkGeo UI's style system to beautifully represent your GIS mapping data. The guide includes an overview of styles, a detailed explanation of the various styles that ship with ThinkGeo, as well as a step-by-step guide to creating your own custom styles.
Explains how to use our custom serialization class to render your ThinkGeo objects to XML, or other format etc. This allows your GIS application to easily save things such as Layers, Styles, or even whole maps to XML to be recalled at a later time.
Walks you through various ways you can increase performance in your .NET mapping application.
Shows which ThinkGeo UI controls run on which platforms (Windows, Linux, MacOS, etc).
Code Samples
All the samples are available on NuGet via the link below.
Package
API Documentation
  • ThinkGeo.UI.Wpf
    This document covers the ThinkGeo.UI.Wpf namespace which resides in the ThinkGeo.UI.Wpf.dll assembly. It includes the map control itself, Overlays, and supported map classes. It also covers all the types in ThinkGeo.Core which is the key dependency of ThinkGeo UI WPF.
Change Logs
Frequently Asked Questions
  • Can I use this Control in a WPF, WinForms or UWP application?
    • WPF: Yes. This control is natively written in WPF so an WPF application is best for it.
    • WinForms: Yes. Microsoft provides an easy way to use a WPF component in a WinForms application, which keeps all the features in WPF and perfectly fits in a WinForms application. Check out our how-to article for more details.
    • UWP: No, this component is not compatible with UWP applications.
  • Do I have control over how the map looks and fits into my application?
    Yes, absolutely. ThinkGeo UI Desktop WPF for .NET Core is a user control, so you can easily integrate it into your application just like any other user control from the toolbox. We expose a large amount of APIs that allow you to customize every aspect of the map and the user interface so that they fit in with the look and feel of your application.
  • What other software is required to work with ThinkGeo Desktop for .NET Core?
    You'll need either Microsoft Visual Studio 2019 or Visual Studio Code.
  • What type of map data does ThinkGeo UI Desktop for .NET Core Support?
    ThinkGeo UI Desktop WPF for .NET Core comes with native support for the most popular vector and raster file formats. Check out our Data Formats Guide for details.
  • How big of a learning curve is there to using ThinkGeo UI Desktop WPF for .NET Core?
    ThinkGeo UI controls are designed to be easy to understand and easy to use. While mapping and GIS controls typically have a larger learning curve than other, simpler controls like grids or charts, we feel ThinkGeo has taken the complexity out of mapping and allows you to develop your application in days or weeks instead of months.
  • Where do I go if I need help with ThinkGeo UI for .NET Core?
  • How do I create/update/delete features on the map?
    The ThinkGeo UI WPF control for .NET Core provides specific methods that allow you to create, update and delete map features. Just follow the processes outlined in this diagram.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
thinkgeo_desktop_for_wpf.1570226842.txt.gz · Last modified: 2019/10/04 22:07 by benbai
