thinkgeo_cloud_routing
ThinkGeo Cloud Routing
ThinkGeo Cloud Routing provides RESTful APIs to get turn-by-turn driving directions, define service areas that can be reached by car in a given time or distance, and more. Check out the online sample for a quick look.
RESTful APIs
ThinkGeo Cloud Routing provides the following Restful APIs:
Get Route
Finds the shortest route between 2-25 waypoints.
HTTP GET
https://cloud.thinkgeo.com/api/v1/route/{coordinates}
URL Parameters
  • coordinates: A semicolon-delimited list of {y},{x} coordinate pairs to travel in order.
  • srid: Optional. The SRID of the input and output feature's coordinate system. Defaults to 4326.
  • proj4String: Optional. The Proj4 string of the input and output feature's coordinate system.
  • turnByTurn: Optional. Whether to return turn-by-turn instructions or not. Defaults to false.
  • coordinateSnapRadius: Optional. The maximum distance of a coordinate can be snapped to the road network. Defaults to 5000 meters.
  • coordinateSnapRadiusUnit: Optional. The unit of the radius to snap the input coordinate to road network.
  • distanceUnit: Optional. The unit of measure in which to express the length of the route.
  • durationUnit: Optional. The unit of the time in which to express the duration of the route.
Visit the Routing API explorer page and click “Try It Out” to explore this API online.
Find Service Area
Find all the areas you can reach by car in a given time or distance.
HTTP GET
https://cloud.thinkgeo.com/api/v1/service-area/{pointY},{pointX}
URL Parameters
  • pointY: The Y coordinate of the point.
  • pointX: The X coordinate of the point.
  • serviceLimits: A comma-delimited list of integer array, which specifies the travel distances or travel times to generate for each facility. The maximum number of serviceLimits is 6.
  • contourGranularity: Optional. A float in the range of (0, 1.0) to identify how much we want to remove the contours. 0 means do not remove any contour at all, 1.0 means only return the largest contours.
  • durationUnit: Optional. The unit of the time in which to express the duration of traveling the route.
  • gridSizeInMeters: Optional. A float value in meters used as the tolerance for concave polygon. The smaller of the number is getting more accurate of the service areas but slower performance, better a value bigger than 300, but depends on the size of the result coverage. Defaults to 400.
  • serviceAreaSeparationType: Optional. Specify whether to include the region covered by the smaller service area into the region covered by the larger service area.
  • serviceAreaType: Optional. Indicates whether the result is returned as polygons enveloping the accessible roads, or as linestrings surrounding those roads.
  • serviceLimitsType: Optional. Indicates the unit of the serviceLimits.
  • travelDirection: Optional. Indecates the direction of travel to or from the coordinate.
Visit the Routing: Service Area API explorer page and click “Try It Out” to explore this API online.
Consume from Client Side
ThinkGeo Cloud Routing does not allow anonymous users to access the API. Before working with these APIs, you will need to register with ThinkGeo Cloud and create your own clients. A new account come with two clients: NativeConfidential and JavaScript. See more details at here.
SDK for .NET
API Documentation
Coming soon
SDK for JavaScript
The SDK for JavaScript enables developers to directly access ThinkGeo Cloud services from JavaScript code running in brower. This SDK can be found at thinkgeocloudclient-js. The Routing in North America and Get Service Area samples show how to work with this SDK.
Samples
Online Sample:
Desktop Sample:
Coming soon
Web Sample:
Coming soon
Mobile Sample:
Coming soon
thinkgeo_cloud_routing.1561431441.txt.gz · Last modified: 2019/06/25 02:57 by kevinwan
