ThinkGeo Cloud Reverse Geocoding provides RESTful APIs to find an address from a location/location coordinates. Check out the online sample for a quick look.
ThinkGeo Cloud ReverseGeocoding provides the following Restful APIs.
Get reverse geocoding for point.
HTTP GET
https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/{pointY},{pointX}
URL Parameters
Visit GetResverseGecodingForPoint and click “Try It Out” to explore this API online.
Get reverse geocoding for points.
HTTP POST https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/multi
POST Body (Content-Type: application/json)
[ { "coord": "string", // The coordinates of the point. The format is: y,x. "srid": int, // Optional. The SRID (coordinate system) in which to express the result. Defaults to 4326. "proj4String": "string", // Optional. The Proj4String (coordinate system) in which to express the result. "lang": "string", // Optional. The language in which to express the result. "searchRadius": int, // Optional. The maximun radius around the input point to search for places. Defaults to 200. "searchRadiusUnit": "Meter", // Optional. The unit of measure in which the SearchRadius is expressed. Defaults to "Meter". "maxResults": int, // Optional. The maximum number of results to return. Defaults to 20. "locationCategories": "string", // Optional. The categories of locations to include in the result set. The default value is "Common". "locationTypes": "string", // Optional. Filters the resulting locations by type. Multiple types should be separated by a comma. Defaults to no filter. "verboseResults": bool, // Optional. Indicates whether the results should be verbose or not. When false, the results will have fewer properties. Defaults to false. "distanceFromQueryFeatureUnit": "Meter" // Optional. The unit of measure in which the distance is expressed. Defaults to "Meter". } ]
Each item in the batch can locally override a parameter specified on the request URL.
URL Parameters
Visit ReverseGeocodeByPointsBatch and click “Try It Out” to explore this API online.
Get reverse geocoding for area.
HTTP GET
https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/area?wkt={polygon}
URL Parameters
Visit GetResverseGecodingForArea and click “Try It Out” to explore this API online.
Get reverse geocoding for line.
HTTP GET
https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/line?wkt={line}
URL Parameters
Visit GetResverseGecodingForLine and click “Try It Out” to explore this API online.
Get place by Id.
HTTP GET
https://cloud.thinkgeo.com/api/v1/location/place/{placeId}
URL Parameters
Visit GetPlaceById and click “Try It Out” to explore this API online.
Get location cateogires.
HTTP GET https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/location-categories
URL Parameters
No parameters.
Visit GetLocationCateogries and click “Try It Out” to explore this API online.
Get common location cateogires.
HTTP GET https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/location-categories/common
URL Parameters
No parameters
Visit GetLocationCateogriesInCommonGroup and click “Try It Out” to explore this API online.
ThinkGeo Cloud Reverse Geocoding does not allow anonymous users to access the API. Before working with these APIs, you will need to register with ThinkGeo Cloud and create your own clients. A new account comes with two clients: NativeConfidential and JavaScript. See more details at here.
The SDK for .NET enables developers to build .NET application that uses the ThinkGeo Cloud services. The NuGet package can be found at ThinkGeo.Cloud.Client or you can install this package with PM by running the command: Install-Package ThinkGeo.Cloud.Client -Version VERSION_TO_BE_INSTALLED, here is the complete API List. Also you can check out the ThinkGeoCloudReverseGeocodingSample-ForWpf for the start.
This documentation convers the ThinkGeo.Cloud.ReverseGeocodingClient class. It contains all of the members such as Constructors, Methods, Properties and Events.
The SDK for JavaScript enables developers to directly access ThinkGeo Cloud services from JavaScript code running in brower. This SDK can be found at thinkgeocloudclient-js. The ReverseGeocoding sample shows how to work with this SDK.
Online Sample:
Desktop Sample:
Web Sample:
Coming soon
Mobile Samples:
Coming soon
