<!– Class –> Provides data for the VertexMoving. event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs
VertexMovingEditInteractiveOverlayEventArgs | Constructor of VertexMovingEditInteractiveOverlayEventArgs class. | ||
VertexMovingEditInteractiveOverlayEventArgs | Boolean, Feature, Vertex | Constructor of VertexMovingEditInteractiveOverlayEventArgs class. | |
VertexMovingEditInteractiveOverlayEventArgs | Boolean, Feature, Vertex, PointShape | Constructor of VertexMovedEditInteractiveOverlayEventArgs class. |
AffectedVertexFeature | Feature | Gets or sets the Feature to be used to move vertex. | |
Cancel | Boolean | Gets or sets the action to be canceled or not. | |
MovingVertex | Vertex | Gets or sets the vertex to be moved. | |
TargetVertex | PointShape | Gets or sets the target vertex to be moved |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#VertexMovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#VertexMovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29</a>
| cancel | Boolean<!– System.Boolean –> | Indicates whether the operation is canceled or not. |
| affectedVertexFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | Indicates a feature which is affected. |
| movingVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | Indicates a vertex which is moving. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#VertexMovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.2C_PointShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#VertexMovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.2C_PointShape.29</a>
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
| affectedVertexFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specified the affectedVertex feature property. |
| movingVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specified the moving vertex. |
| targetVertex | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specified the target vertex. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#AffectedVertexFeature” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#AffectedVertexFeature</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Cancel” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Cancel</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#MovingVertex” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#MovingVertex</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#TargetVertex” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#TargetVertex</a>
