thinkgeo.mapsuite.wpfdesktopedition.vertexmovededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs
Provides data for the VertexMoved. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs
VertexMovedEditInteractiveOverlayEventArgs()
Constructor of VertexMovedEditInteractiveOverlayEventArgs class.
VertexMovedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • movedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex moved.
AffectedVertexFeature
Gets or sets the Feature to be used to remove vertex.
MovedVertex
Gets or sets the vertex moved.
thinkgeo.mapsuite.wpfdesktopedition.vertexmovededitinteractiveoverlayeventargs.1442546232.txt.gz · Last modified: 2015/09/18 03:17 by admin
