<!– Class –> Provides data for the VertexAdding. event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs
VertexAddingEditInteractiveOverlayEventArgs | Constructor of VertexAddingEditInteractiveOverlayEventArgs class. | ||
VertexAddingEditInteractiveOverlayEventArgs | Boolean, Feature, Vertex | Constructor of VertexAddingEditInteractiveOverlayEventArgs class. |
AddingVertex | Vertex | Gets or sets the vertex to be added. | |
AffectedVertexFeature | Feature | Gets or sets the Feature to be used to move vertex. | |
Cancel | Boolean | Gets or sets the action to be canceled or not. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#VertexAddingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#VertexAddingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29</a>
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
| affectedVertexFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specified the affectedVertex feature property. |
| addingVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specified the target vertex to be added. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#AddingVertex” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#AddingVertex</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#AffectedVertexFeature” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#AffectedVertexFeature</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#Cancel” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#Cancel</a>
