This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay
![]() | Constructor of AdornmentOverlay class. |
![]() | Overlay | ||
![]() | Overlay | This method dispose unmanaged resource used in this class. | |
![]() | RectangleShape | Overlay | This method draws the overlay with the provided extent in world coordinate. |
![]() | RectangleShape, OverlayRefreshType | Overlay | This method draws the overlay with the provided extent in world coordinate. |
![]() | Object | Object | |
![]() | Overlay | This method gets a bounding box of the Overlay. | |
![]() | Object | ||
![]() | Object | ||
![]() | MapArguments | Overlay | This method initializes overlay object. |
![]() | Byte[] | Overlay | This method restore the overlay state back from the specified state. |
![]() | RectangleShape | Overlay | This method pans the overlay to the provided world extent. |
![]() | IEnumerable<RectangleShape> | Overlay | |
![]() | TimeSpan | Overlay | |
![]() | TimeSpan, RequestDrawingBufferTimeType | Overlay | |
![]() | RectangleShape, TimeSpan | Overlay | |
![]() | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Overlay | |
![]() | RectangleShape | Overlay | |
![]() | IEnumerable<RectangleShape>, TimeSpan | Overlay | |
![]() | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
![]() | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Overlay | |
![]() | Overlay | This method saves overlay state to a byte array. | |
![]() | Object |
![]() | Boolean | Overlay(overriden) | This method disposes the unmanaged resource used in this overlay. |
![]() | GeoCanvas | Overlay | |
![]() | RectangleShape, OverlayRefreshType | Overlay(overriden) | This method override the DrawCore logic of the Overlay class. |
![]() | Object(overriden) | ||
![]() | Overlay | This method returns the bounding box of the Overlay. | |
![]() | Byte[] | Overlay(overriden) | This method restore the overlay state back from the specified state. |
![]() | Object | ||
![]() | DrawingOverlayEventArgs | Overlay | This method raises before the overlay is drawing. |
![]() | DrawingAttributionOverlayEventArgs | Overlay | |
![]() | DrawnOverlayEventArgs | Overlay | This method raises after the overlay is drawn. |
![]() | DrawnAttributionOverlayEventArgs | Overlay | |
![]() | Overlay(overriden) | This method saves overlay state to a byte array. |
![]() | String | Overlay | |
![]() | Boolean | Overlay | |
![]() | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
![]() | Boolean | ||
![]() | Boolean | Overlay | Gets or sets if this overlay is visible. |
![]() | GeoCollection<AdornmentLayer> | This property gets a collection of the AdornmentLayers that are added to the AdornmentOverlay. | |
![]() | MapArguments | Overlay | Gets or sets current map information which will be used for calculating mechanism. |
![]() | String | Overlay | Gets or sets the name of this overaly. |
![]() | Canvas | Overlay | Gets or sets the actual canvas which maintains all the visual elements on the overlay. |
![]() | Boolean | This property is a easy way to add the LogoAdornmentLayer to the AdormentOverlay. |
![]() | Boolean | Overlay | Gets or sets if the overlay canvas is initialized. |
![]() | RectangleShape | Overlay | Gets or sets the previous exent of the overlay. |
![]() | DrawingOverlayEventArgs | Overlay | This event raises before the overlay is drawing. |
![]() | DrawnOverlayEventArgs | Overlay | This event raises after the overlay is drawn. |
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#AdornmentOverlay.28.29
Name | Type | Description |
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Close.28.29
Return Type | Description |
Void |
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Dispose.28.29
Void |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Draw.28RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Draw.28RectangleShape.29</a>
Void |
targetExtent | RectangleShape | This parameter indicates an extent in world coordinate for drawing the overlay. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Draw.28RectangleShape.2C_OverlayRefreshType.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Draw.28RectangleShape.2C_OverlayRefreshType.29</a>
Void |
refreshType | OverlayRefreshType | This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Equals.28Object.29</a>
Boolean |
obj | Object |
This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay.As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
RectangleShape | A RectangleShape indicating the bounding box of this overlay |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#GetHashCode.28.29</a>
Int32 |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#GetType.28.29</a>
Type |
This is a wrapper method for the virtual method InitializeCore.
Void |
mapArguments | MapArguments | This parameter maintains current map information for calculating mechanism. |
Void |
state | Byte[]<!– System.Bytethinkgeo.mapsuite.wpfdesktopedition.adornmentoverlay –> | This parameter indicates the state for restore the overlay. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Open.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Open.28.29</a>
Void |
Some overlay doesn't need to continously drawing all the tile. For example, MarkerOverlay is formed by markers. When mouse down to pan, the markers don't need to redraw, we can only change its position. When mouse up to end panning, we can redraw the overlay for better performance.
Void |
targetExtent | RectangleShape | This parameter is the target world extent for panning. |
Void |
extentsToRefresh | IEnumerable<RectangleShape> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Refresh.28TimeSpan.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Refresh.28TimeSpan.29</a>
Void |
bufferTime | TimeSpan |
Void |
bufferTime | TimeSpan | |
bufferTimeType | RequestDrawingBufferTimeType |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Refresh.28RectangleShape.2C_TimeSpan.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Refresh.28RectangleShape.2C_TimeSpan.29</a>
Void |
extentToRefresh | RectangleShape | |
Void |
extentsToRefresh | IEnumerable<RectangleShape> | |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Refresh.28RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Refresh.28RectangleShape.29</a>
Void |
extent | RectangleShape |
Void |
Void |
Void |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#SaveState.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#SaveState.28.29</a>
Byte[]<!– System.Bytethinkgeo.mapsuite.wpfdesktopedition.adornmentoverlay –> | A byte array indicates current overlay state. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#ToString.28.29</a>
String |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#CloseCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#CloseCore.28.29</a>
Void |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Dispose.28Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Dispose.28Boolean.29</a>
Void |
disposing | Boolean |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#DrawAttributionCore.28GeoCanvas.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#DrawAttributionCore.28GeoCanvas.29</a>
Void |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#DrawCore.28RectangleShape.2C_OverlayRefreshType.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#DrawCore.28RectangleShape.2C_OverlayRefreshType.29</a>
Void |
targetExtent | RectangleShape | This parameter specifies the extent for drawing this overlay. |
overlayRefreshType | OverlayRefreshType | This parameter specifies whether this overlay need to be clear and refresh or not. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Finalize.28.29</a>
Void |
RectangleShape | This method returns the bounding box of the Overlay. |
When implementing this method, consider initializing the overlay canvas such as setting its z-index, setting current map reference to the CurrentMap property.
Void |
Void |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#MemberwiseClone.28.29</a>
Object |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OnDrawing.28DrawingOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OnDrawing.28DrawingOverlayEventArgs.29</a>
Void |
e | DrawingOverlayEventArgs | This parameter is the event argument for Drawing event. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29</a>
Void |
args | DrawingAttributionOverlayEventArgs |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OnDrawn.28DrawnOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OnDrawn.28DrawnOverlayEventArgs.29</a>
Void |
e | DrawnOverlayEventArgs | This parameter is the event argument for Drawn event. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29</a>
Void |
args | DrawnAttributionOverlayEventArgs |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OpenCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OpenCore.28.29</a>
Void |
Void |
Void |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#RefreshCore.28RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#RefreshCore.28RectangleShape.29</a>
Void |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#SaveStateCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#SaveStateCore.28.29</a>
Return Type |
String |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#AutoRefreshInterval” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#AutoRefreshInterval</a>
Return Type |
TimeSpan |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#CanRefreshRegion” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#CanRefreshRegion</a>
Return Type |
Boolean |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#DrawingExceptionMode” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#DrawingExceptionMode</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#IsBase” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#IsBase</a>
Return Type |
Boolean |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#IsEmpty” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#IsEmpty</a>
Return Type |
Boolean |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#IsVisible</a>
Return Type |
Boolean |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Layers” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Layers</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Initialize.28MapArguments.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Initialize.28MapArguments.29</a>
Return Type |
MapArguments |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#Name</a>
Return Type |
String |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OverlayCanvas” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#OverlayCanvas</a>
Return Type |
Canvas |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#ShowLogo” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#ShowLogo</a>
Return Type |
Boolean |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#IsOverlayInitialized” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#IsOverlayInitialized</a>
Return Type |
Boolean |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#PreviousExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.AdornmentOverlay#PreviousExtent</a>
Return Type |
RectangleShape |
Event Arguments |
Event Arguments |
Event Arguments |
