<!– Enumeration –> This enumeration represents the type of graphic shape to use on both ends of each dash in a dashed line.
| Name | Summary |
| Flat | Specifies a square cap that squares off both ends of each dash. |
| Square | Specifies a circular cap that rounds off both ends of each dash. |
| Round | Specifies a circular cap that rounds off both ends of each dash. |
| Triangle | Specifies a triangular cap that points both ends of each dash. |
