<!– Class –> A strongly-typed resource class, for looking up localized strings, etc.
*System.Object **ThinkGeo.MapSuite.WindowsPhoneCore.ExceptionDescription
![]() AddTransactionError | String | Looks up a localized string similar to The add transaction failed for an unknown reason.. | |
![]() BothIconFilePathAndIconImageAreInvalid | String | Looks up a localized string similar to You can provide a path and file name to an icon or an image but not both.. | |
![]() CellHeightLessThanZero | String | Looks up a localized string similar to The cellHeight needs to be greater than zero.. | |
![]() CellWidthLessThanZero | String | Looks up a localized string similar to The cellWidth needs to be greater than zero.. | |
![]() ChangeExtension | String | Looks up a localized string similar to The extension for TIFF files must be “.tif”. | |
![]() CheckIsOpenedWhenCloneDeep | String | Looks up a localized string similar to You can not CloneDeep because the object is open or drawing, please close or end drawing first.. | |
![]() CheckLayerIsOpened | String | Looks up a localized string similar to The Layer must be opened before you can perform this method.. | |
![]() CheckMapEngineCurrentExtentIsNotValid | String | Looks up a localized string similar to The current extent provided is not valid.. | |
![]() ClassBreakNumberShouldBeGreaterThanOne | String | Looks up a localized string similar to The ClassBreak Number should be greater than one.. | |
![]() ClassBreaksIsValid | String | Looks up a localized string similar to The class breaks you have provided are invalid.. | |
![]() ColorDoesNotExist | String | Looks up a localized string similar to The color you have provided does not exist.. | |
![]() ColumnNumberExceedTotalRowCount | String | Looks up a localized string similar to The parameter column exceeds the total column count.. | |
![]() CommonImageSourceIsAlreadyOpen | String | Looks up a localized string similar to The ImageSource is already open.. | |
![]() ConnectionStringCannotBeNull | String | Looks up a localized string similar to The connection string can not be null.. | |
![]() CreateShapeFileFailed | String | Looks up a localized string similar to The creation of the shape file has failed.. | |
![]() Culture | CultureInfo | Overrides the current thread's CurrentUICulture property for all resource lookups using this strongly typed resource class. | |
![]() CurrentExtentNotAssigned | String | Looks up a localized string similar to The CurrentExtent property must be set before calling this method. If you want to use a custom extent, please use the static method. | |
![]() CustomImageSizeIsNull | String | Looks up a localized string similar to You already choose resize the image by custom size, please set the custom width and height.. | |
![]() DbfColumnsIsEmpty | String | Looks up a localized string similar to The DbfColumns collection is empty, you should add at least one DbfColumn when you create a new shape file.. | |
![]() DecimalDegreeLatitudeOutOfRange | String | Looks up a localized string similar to The decimal degree latitude value you provided was out of range.. | |
![]() DecimalDegreeLongitudeOutOfRange | String | Looks up a localized string similar to The decimal degree longitude value you provided was out of range.. | |
![]() DecimalDegreeSecondsStringNull | String | Looks up a localized string similar to The degreesMinutesSeconds string may not be null or empty.. | |
![]() DecimalLengthInValidForStringColumnType | String | Looks up a localized string similar to DecimalLength is Invalid(it should be 0) for StringColumnType, it only make sense for DoubleColumnType.. | |
![]() DefaultAndCustomStyleDuplicate | String | Looks up a localized string similar to You are trying to use both a default style and the custom styles collection. You may only use one or the other.. | |
![]() DefaultAndCustomStyleDuplicateForRestrictedLayer | String | Looks up a localized string similar to You are trying to use both a default style and the custom styles collection. If you want to add custom styles, please set RestrictionStyle as RestrictionStyle.UseCustomStyles.. | |
![]() DegreesMinutesSecondsInputError | String | Looks up a localized string similar to The DegreesMinutesSeconds value is invalid.. | |
![]() DeleteTransactionError | String | Looks up a localized string similar to The delete transaction failed for an unknown reason.. | |
![]() DoubleOutOfRange | String | Looks up a localized string similar to The input double value is out of range.. | |
![]() EditingNotSupported | String | Looks up a localized string similar to You have set IsEditable to true but have not overridden the CommitTransactionCore method. Please override this the CommitTransactionCore method to prevent this exception.. | |
![]() EllipseIsNotValid | String | Looks up a localized string similar to The ellipse is not valid.. | |
![]() EnumerationOutOfRange | String | Looks up a localized string similar to The value for the enumeration is not on of the valid values.. | |
![]() EvalNotInstall | String | Looks up a localized string similar to The evaluation edition has not been installed.. | |
![]() EvaluationExpired | String | Looks up a localized string similar to The evaluation has expired. Please contact ThinkGeo for purchasing option or an extension to the trial.. | |
![]() ExceptionMessage | String | Looks up a localized string similar to Drawing error. | |
![]() ExtentNotIntersectsWithBoundingBox | String | Looks up a localized string similar to The passed extent needs to intersect with the bounding box of the gid.. | |
![]() FeatureCollectionIsEmpty | String | Looks up a localized string similar to The collection of Features may not be empty.. | |
![]() FeatureColumnValueDoesNotContainColon | String | Looks up a localized string similar to The feature column values should be entered as stringthinkgeo.mapsuite.windowsphonecore.exceptiondescription {“Key1:Value1”, “Key2:Value2”}. | |
![]() FeatureIsInvalidInThisStyle | String | Looks up a localized string similar to The feature is invalid in in this style.. | |
![]() FeatureIsNotValid | String | Looks up a localized string similar to The Feature you provided is not valid.. | |
![]() FeatureSourceCanNotExecuteSqlQuery | String | Looks up a localized string similar to Executing sql queries is not supported and the user should always check the CanExecuteSqlQueries to ensure the FeatureSource support it before calling.. | |
![]() FeatureSourceCollectionIsEmpty | String | Looks up a localized string similar to There are no FeatureSources.. | |
![]() FeatureSourceColumnCollectionIsEmpty | String | Looks up a localized string similar to The collection of FeatureSourceColumns may not be empty.. | |
![]() FeatureSourceIsAlreadyInTransaction | String | Looks up a localized string similar to The FeatureSource is already in a transaction.. | |
![]() FeatureSourceIsAlreadyOpen | String | Looks up a localized string similar to The FeatureSource is already opened.. | |
![]() FeatureSourceIsNotEditable | String | Looks up a localized string similar to The FeatureSource is not editable.. | |
![]() FeatureSourceIsNotInTransaction | String | Looks up a localized string similar to The FeatureSource is not in a transaction.. | |
![]() FeatureSourceIsNotOpen | String | Looks up a localized string similar to The FeatureSource is not open. Please call the Open method before calling this method.. | |
![]() FieldNameIsNotInFeature | String | Looks up a localized string similar to The requested column name is not in the Feature.. | |
![]() FileAccessError | String | Looks up a localized string similar to File access error, you should open the shape file with ReadWrite mode.. | |
![]() FileAlreadyExists | String | Looks up a localized string similar to The file already exists.. | |
![]() FileIsNotExist | String | Looks up a localized string similar to The file specified does not exist.. | |
![]() FileIsSupportedByCommonImageSource | String | Looks up a localized string similar to This file type is not supported.. | |
![]() FileNotSupportedForSql | String | Looks up a localized string similar to One of the fields in the database is not supported by SQL. The first character of this field name must be an alphabetic letter.. | |
![]() FirstClassBreakValueError | String | Looks up a localized string similar to The first ClassBreak value should be double.MinValue.. | |
![]() FullExpired | String | Looks up a localized string similar to The Windows Phone Edition is expired,please ask ThinkGeo for a new package. | |
![]() GdipLoadImageFromFileError | String | Looks up a localized string similar to GDI+ threw a status error code.. | |
![]() GeoCacheIsNotOpen | String | Looks up a localized string similar to The GeoCache is not open. Please call the Open method before calling this method.. | |
![]() GeoImageIsNotValid | String | Looks up a localized string similar to The input GeoImage object is not a valid GeoImage type.. | |
![]() GeocanvasIsNotInDrawing | String | Looks up a localized string similar to The GeoCanvas is currently not drawing. Please call the BeginDraw method before calling this method.. | |
![]() GeographicUnitNotValidWithGoogle | String | Looks up a localized string similar to The map unit you are using is not compatable with the GoogleLayer . Make sure you are using Meters and that your projection is 90013 to ensure compatability.. | |
![]() GeometriesInvalidExist | String | Looks up a localized string similar to We have found geometries that are invalid according to the SQL Server STIsValid() Function. To automaticly fix these you can call the MakeAllGeometriesValid method. The SQL To Determine which records are invalid:. | |
![]() GeometryCollectionIsNotSupportedNowForProjection | String | Looks up a localized string similar to GeometryCollection is not supported now for projection.. | |
![]() GeometrytypeIsWrong | String | Looks up a localized string similar to Geometry type not recognized. . | |
![]() GettingSridNotSupported | String | Looks up a localized string similar to The current GeoImage implementation does not support the GetSrid operation.. | |
![]() GroupLayerIsEmpty | String | Looks up a localized string similar to You must have at least one layer.. | |
![]() HtmlColorIsInvalid | String | Looks up a localized string similar to The input string HtmlColor is invalid.. | |
![]() IEnumerableIsEmptyOrNull | String | Looks up a localized string similar to The collection may not be empty or null.. | |
![]() IdColumnCannotBeNullOrEmpty | String | Looks up a localized string similar to Id column can't be null or empty.. | |
![]() ImageInPointStyleCanNotBeNull | String | Looks up a localized string similar to The image property can't be null.. | |
![]() ImageScaleShouldBiggerThanZero | String | Looks up a localized string similar to The ImageScaled property must be larger than 0.. | |
![]() ImageSourceIsAlreadyOpen | String | Looks up a localized string similar to The ImageSource is already open.. | |
![]() ImageSourceIsNotOpen | String | Looks up a localized string similar to The ImageSource is not open. Please call the Open method before calling this method.. | |
![]() IndexFileAlreadyExists | String | Looks up a localized string similar to Index File already exist, please change the BuildIndexMode if you want to rebuild this index.. | |
![]() IndexFileIsInvalid | String | Looks up a localized string similar to The format of your index file is not valid, please check. Or you can use BuildIndexFile function to build a new one.. | |
![]() IndexFileNotExisted | String | Looks up a localized string similar to You don't have the corresponding idx file for your shape file. You can use the static method ShapeFileFeatureSource.BuildIndexFile() or ShapeFileFeatureLayer.BuildIndexFile() to build an idx file for the shape file, or you can set the RequireIndex property to false.. | |
![]() InputGeometryTypeIsNotValid | String | Looks up a localized string similar to Input Geometry Type Is Not Valid. | |
![]() InvalidGeometryInMsSqlForSpatialQuery | String | Looks up a localized string similar to There're some invalid geometry instance in table not valid. About invalid geometry please have a look at http://msdn.microsoft.com/en-us/library/bb933890.aspx website. To solve this problem, we provide MakeAllGeometryValid function to make the invalid geometry to be valid, because of the function updating your data, you need to backup your data before using this function.. | |
![]() InvalidOperationExceptionError | String | Looks up a localized string similar to Invalid Operation Exception.. | |
![]() IsNotSupportedNowForProjection | String | Looks up a localized string similar to is not supported for projection now.. | |
![]() ItemNotFoundInGeoCollectionByItem | String | Looks up a localized string similar to The GeoCollection does not contain the item you specified.. | |
![]() ItemNotFoundInGeoCollectionByKey | String | Looks up a localized string similar to The GeoCollection does not contain the item you specified.. | |
![]() JpegImageCompressionShouldBeBetweenZeroAndOneHundred | String | Looks up a localized string similar to The value should be between zero and one hundred.. | |
![]() LayerDoesNotHaveBoundingBox | String | Looks up a localized string similar to This Layer doesn't have a boundingBox.. | |
![]() LayersTypeIsOutOfRange | String | Looks up a localized string similar to The layer type you have provided is not valid.. | |
![]() MapEngineCurrentExtentIsNotValid | String | Looks up a localized string similar to The current extent you have provided is not valid.. | |
![]() MapEngineCurrentExtentIsNull | String | Looks up a localized string similar to The current extent you have provided may not be null.. | |
![]() MrSidGeoImageSourceIsAlreadyOpen | String | Looks up a localized string similar to The MrSidGeoImageSource is already open.. | |
![]() MrSidGeoImageSourceIsNotOpen | String | Looks up a localized string similar to The MrSidGeoImageSource is not open. Please open it before calling this method.. | |
![]() MultiFieldNamesNotSupportedError | String | Looks up a localized string similar to The format of Multi-FieldNames isn't correct.. | |
![]() MultiLineCannotReorderForInputParams | String | Looks up a localized string similar to Can't Reorder for the multi-line because it does not satisfy the reorder condition based on the given startPoint and given tolerance.. | |
![]() MultiLineInvalidForReorder | String | Looks up a localized string similar to Can't Reorder for the multi-line because it does not satisfy the reorder condition based on the given tolerance.. | |
![]() NotAllValidLayersAreOpen | String | Looks up a localized string similar to Not all valid layers are open.. | |
![]() NotSupported | String | Looks up a localized string similar to This feature is currently not supported.. | |
![]() NotSupportedFileType | String | Looks up a localized string similar to The file type you provided is currently not supported.. | |
![]() NotSupportedSqlQueryMode | String | Looks up a localized string similar to The SQL Query mode is not supported.. | |
![]() NumberShouldBeByte | String | Looks up a localized string similar to The number should be between 0 and 255. | |
![]() ParameterCanNotConvert | String | Looks up a localized string similar to We cannot get the AreaUnit from input unit.. | |
![]() ParameterIdsIsNotIntegers | String | Looks up a localized string similar to Parameter Ids should be from 1 to the record number in ShapeFileFeatureSource. | |
![]() ParameterIsEmpty | String | Looks up a localized string similar to The parameter you supplied may not be empty.. | |
![]() ParameterIsInvalid | String | Looks up a localized string similar to The shape you provided does not pass our simple validation.. | |
![]() ParameterIsNull | String | Looks up a localized string similar to The parameter you supplied may not be null.. | |
![]() ParameterIsTransparent | String | Looks up a localized string similar to The parameter is transparent.. | |
![]() ProjectionInitializationError | String | Looks up a localized string similar to Projection initialization failed.. | |
![]() ProjectionInternalGeographyIsUnknown | String | Looks up a localized string similar to Cannot get the projection’s InternalGeographyUnit, please provide it by overriding the Projection’s GetInternalGeographyUnitCore() method.. | |
![]() ProjectionIsNotOpen | String | Looks up a localized string similar to The projection is not open. Please open it before calling this method.. | |
![]() RasterLayerDoesNotHaveProjectionInformation | String | Looks up a localized string similar to This RasterLayer does not have projection information embedded in it. If you wish to avoid this exception you can first check the HasProjectionTextProperty.. | |
![]() RasterSourceNotContainsProjectionInformation | String | Looks up a localized string similar to This RasterSource does not have projection information embedded in it. If you wish to avoid this exception you can first check the HasProjectionTextProperty.. | |
![]() RebuildDbfFailed | String | Looks up a localized string similar to The rebuild of the DBF failed for an unknown reason. Please see the inner exception.. | |
![]() RebuildIdxFailed | String | Looks up a localized string similar to The spatial index generation failed for an unknown reason. Please see the inner exception.. | |
![]() RebuildShapeFileFailed | String | Looks up a localized string similar to the rebuilding of the shape file failed for an unknown reason. Please see the inner exception.. | |
![]() RecordIsInvalid | String | Looks up a localized string similar to The record is invalid, please call CheckForUnsupportedRecords method to check the the failed reason.. | |
![]() ResourceManager | ResourceManager | Returns the cached ResourceManager instance used by this class. | |
![]() ReturnTypeNotCorrect | String | Looks up a localized string similar to This operation's return type is not correct.. | |
![]() ReturnValueIsNull | String | Looks up a localized string similar to Return value is null.. | |
![]() RingShapeIsInvalidForOperationVertexCountLessThan4 | String | Looks up a localized string similar to A ring should has more than 4 vertexes.. | |
![]() RotateNotSupported | String | Looks up a localized string similar to Rotation is not supported on this class.. | |
![]() RowNumberExceedTotalRowCount | String | Looks up a localized string similar to The parameter row exceeds the total row count.. | |
![]() RtreeSpatialIndexIsNotOpen | String | Looks up a localized string similar to The RtreeSpatialIndex is not open. Please call the Open method before calling this method.. | |
![]() ShapeFileBoundingBoxIsValid | String | Looks up a localized string similar to The shape file bounding box is invalid.. | |
![]() ShapeFileNameIsInvalid | String | Looks up a localized string similar to The shape file name is invalid.. | |
![]() ShapeIsInvalidForOperation | String | Looks up a localized string similar to The shape you provided does not pass our simple validation.. | |
![]() ShapeIsInvalidForValidation | String | Looks up a localized string similar to There are no points in the shape.. | |
![]() ShapeTypeNotImplement | String | Looks up a localized string similar to This shape has not been implemented yet.. | |
![]() ShxFileIsNotOpen | String | Looks up a localized string similar to The shape file index is not open.. | |
![]() SpatialIndexIsNotRemovable | String | Looks up a localized string similar to The features in SpatialIndex are not removable.. | |
![]() SpatialIndexIsNotRemovable1 | String | Looks up a localized string similar to The features in SpatialIndex are not removable.. | |
![]() SridIsInvalid | String | Looks up a localized string similar to Input srid is not valid.. | |
![]() StringIsNotBlank | String | Looks up a localized string similar to The input string value is not blank.. | |
![]() TargetShapeIsNotValidType | String | Looks up a localized string similar to Target Shape Is Not Valid Type.. | |
![]() TheFieldTtypeShouldBeNumeric | String | Looks up a localized string similar to The field type should be numeric.. | |
![]() TheFormatOfImageIsNotSupported | String | Looks up a localized string similar to The format of the image is not supported.. | |
![]() TheValueShouldBeGreaterThanZero | String | Looks up a localized string similar to The value should be greater than zero.. | |
![]() Unlicensed | String | Looks up a localized string similar to Unlicensed.. | |
![]() UnsupportedEditingShapeType | String | Looks up a localized string similar to Currently we do not support editing this kind of shape type. Shape type:. | |
![]() UpdateTansactionError | String | Looks up a localized string similar to The update transaction failed for an unknown reason.. | |
![]() UriNotValid | String | Looks up a localized string similar to The input Uri is not valid. | |
![]() UseGeoTiffRasterInstead | String | Looks up a localized string similar to The TIFF files(.tif or .tiff) are not supported in GdiPlusRasterSource any longer, please use the GeoTiffRasterSource instead.. | |
![]() WkbIsInvalid | String | Looks up a localized string similar to The format of the well known binary is incorrect.. | |
![]() WkbIsNotValidForDrawing | String | Looks up a localized string similar to The well known binary is not valid for drawing.. | |
![]() WkbTypeError | String | Looks up a localized string similar to The well known binary type is incorrect.. | |
![]() WktFormatIsWrong | String | Looks up a localized string similar to The format of the well known text is incorrect.. | |
![]() WmsCRSNotSet | String | Looks up a localized string similar to Coordinate Reference System not set.. | |
![]() WmsCRSNotSupport | String | Looks up a localized string similar to This CRS is not supported in the Wms server: . | |
![]() WmsGetMapTimeOut | String | Looks up a localized string similar to The Wms server has timed out.. | |
![]() WmsLayerDoesNotExists | String | Looks up a localized string similar to The Wms request LAYERS parameter is missing.. | |
![]() WmsNoLayerExists | String | Looks up a localized string similar to No layers exist in the Service Description.. | |
![]() WmsRequestParaNotExists | String | Looks up a localized string similar to The requested parameter does not exists in this Service Description.. | |
![]() WmsServerNotSupportFormat | String | Looks up a localized string similar to This image format is not supported in the Wms server: . | |
![]() WmsServerNotSupportLayer | String | Looks up a localized string similar to This layer is not supported in the Wms server: . | |
![]() WmsServerNotSupportStyle | String | Looks up a localized string similar to This style is not supported in the Wms server: . | |
![]() WorldExtentIsNotValid | String | Looks up a localized string similar to The world extent is not valid.. | |
![]() WorldFileShould6Lines | String | Looks up a localized string similar to World file should has 6 lines.. | |
![]() WpfCommonGeoImageSourceIsAlreadyOpen | String | Looks up a localized string similar to The ImageSource is already open.. | |
![]() WpfCommonGeoImageSourceIsNotOpen | String | Looks up a localized string similar to The ImageSource is not opened. Please open it before calling this method.. |
<!– static –> Looks up a localized string similar to The add transaction failed for an unknown reason..
<!– ThinkGeo.MapSuite.WindowsPhoneCore.ExceptionDescription –> Go Back
<!– static –> Looks up a localized string similar to You can provide a path and file name to an icon or an image but not both..
<!– static –> Looks up a localized string similar to The cellHeight needs to be greater than zero..
<!– static –> Looks up a localized string similar to The cellWidth needs to be greater than zero..
<!– static –> Looks up a localized string similar to The extension for TIFF files must be “.tif”.
<!– static –> Looks up a localized string similar to You can not CloneDeep because the object is open or drawing, please close or end drawing first..
<!– static –> Looks up a localized string similar to The Layer must be opened before you can perform this method..
<!– static –> Looks up a localized string similar to The current extent provided is not valid..
<!– static –> Looks up a localized string similar to The ClassBreak Number should be greater than one..
<!– static –> Looks up a localized string similar to The class breaks you have provided are invalid..
<!– static –> Looks up a localized string similar to The color you have provided does not exist..
<!– static –> Looks up a localized string similar to The parameter column exceeds the total column count..
<!– static –> Looks up a localized string similar to The ImageSource is already open..
<!– static –> Looks up a localized string similar to The connection string can not be null..
<!– static –> Looks up a localized string similar to The creation of the shape file has failed..
<!– static –> Overrides the current thread's CurrentUICulture property for all resource lookups using this strongly typed resource class.
| CultureInfo<!– System.Globalization.CultureInfo –> |
<!– static –> Looks up a localized string similar to The CurrentExtent property must be set before calling this method. If you want to use a custom extent, please use the static method.
<!– static –> Looks up a localized string similar to You already choose resize the image by custom size, please set the custom width and height..
<!– static –> Looks up a localized string similar to The DbfColumns collection is empty, you should add at least one DbfColumn when you create a new shape file..
<!– static –> Looks up a localized string similar to The decimal degree latitude value you provided was out of range..
<!– static –> Looks up a localized string similar to The decimal degree longitude value you provided was out of range..
<!– static –> Looks up a localized string similar to The degreesMinutesSeconds string may not be null or empty..
<!– static –> Looks up a localized string similar to DecimalLength is Invalid(it should be 0) for StringColumnType, it only make sense for DoubleColumnType..
<!– static –> Looks up a localized string similar to You are trying to use both a default style and the custom styles collection. You may only use one or the other..
<!– static –> Looks up a localized string similar to You are trying to use both a default style and the custom styles collection. If you want to add custom styles, please set RestrictionStyle as RestrictionStyle.UseCustomStyles..
<!– static –> Looks up a localized string similar to The DegreesMinutesSeconds value is invalid..
<!– static –> Looks up a localized string similar to The delete transaction failed for an unknown reason..
<!– static –> Looks up a localized string similar to The input double value is out of range..
<!– static –> Looks up a localized string similar to You have set IsEditable to true but have not overridden the CommitTransactionCore method. Please override this the CommitTransactionCore method to prevent this exception..
<!– static –> Looks up a localized string similar to The ellipse is not valid..
<!– static –> Looks up a localized string similar to The value for the enumeration is not on of the valid values..
<!– static –> Looks up a localized string similar to The evaluation edition has not been installed..
<!– static –> Looks up a localized string similar to The evaluation has expired. Please contact ThinkGeo for purchasing option or an extension to the trial..
<!– static –> Looks up a localized string similar to Drawing error.
<!– static –> Looks up a localized string similar to The passed extent needs to intersect with the bounding box of the gid..
<!– static –> Looks up a localized string similar to The collection of Features may not be empty..
<!– static –> Looks up a localized string similar to The feature column values should be entered as stringthinkgeo.mapsuite.windowsphonecore.exceptiondescription {“Key1:Value1”, “Key2:Value2”}.
<!– static –> Looks up a localized string similar to The feature is invalid in in this style..
<!– static –> Looks up a localized string similar to The Feature you provided is not valid..
<!– static –> Looks up a localized string similar to Executing sql queries is not supported and the user should always check the CanExecuteSqlQueries to ensure the FeatureSource support it before calling..
<!– static –> Looks up a localized string similar to There are no FeatureSources..
<!– static –> Looks up a localized string similar to The collection of FeatureSourceColumns may not be empty..
<!– static –> Looks up a localized string similar to The FeatureSource is already in a transaction..
<!– static –> Looks up a localized string similar to The FeatureSource is already opened..
<!– static –> Looks up a localized string similar to The FeatureSource is not editable..
<!– static –> Looks up a localized string similar to The FeatureSource is not in a transaction..
<!– static –> Looks up a localized string similar to The FeatureSource is not open. Please call the Open method before calling this method..
<!– static –> Looks up a localized string similar to The requested column name is not in the Feature..
<!– static –> Looks up a localized string similar to File access error, you should open the shape file with ReadWrite mode..
<!– static –> Looks up a localized string similar to The file already exists..
<!– static –> Looks up a localized string similar to The file specified does not exist..
<!– static –> Looks up a localized string similar to This file type is not supported..
<!– static –> Looks up a localized string similar to One of the fields in the database is not supported by SQL. The first character of this field name must be an alphabetic letter..
<!– static –> Looks up a localized string similar to The first ClassBreak value should be double.MinValue..
<!– static –> Looks up a localized string similar to The Windows Phone Edition is expired,please ask ThinkGeo for a new package.
<!– static –> Looks up a localized string similar to GDI+ threw a status error code..
<!– static –> Looks up a localized string similar to The GeoCache is not open. Please call the Open method before calling this method..
<!– static –> Looks up a localized string similar to The input GeoImage object is not a valid GeoImage type..
<!– static –> Looks up a localized string similar to The GeoCanvas is currently not drawing. Please call the BeginDraw method before calling this method..
<!– static –> Looks up a localized string similar to The map unit you are using is not compatable with the GoogleLayer . Make sure you are using Meters and that your projection is 90013 to ensure compatability..
<!– static –> Looks up a localized string similar to We have found geometries that are invalid according to the SQL Server STIsValid() Function. To automaticly fix these you can call the MakeAllGeometriesValid method. The SQL To Determine which records are invalid:.
<!– static –> Looks up a localized string similar to GeometryCollection is not supported now for projection..
<!– static –> Looks up a localized string similar to Geometry type not recognized. .
<!– static –> Looks up a localized string similar to The current GeoImage implementation does not support the GetSrid operation..
<!– static –> Looks up a localized string similar to You must have at least one layer..
<!– static –> Looks up a localized string similar to The input string HtmlColor is invalid..
<!– static –> Looks up a localized string similar to The collection may not be empty or null..
<!– static –> Looks up a localized string similar to Id column can't be null or empty..
<!– static –> Looks up a localized string similar to The image property can't be null..
<!– static –> Looks up a localized string similar to The ImageScaled property must be larger than 0..
<!– static –> Looks up a localized string similar to The ImageSource is not open. Please call the Open method before calling this method..
<!– static –> Looks up a localized string similar to Index File already exist, please change the BuildIndexMode if you want to rebuild this index..
<!– static –> Looks up a localized string similar to The format of your index file is not valid, please check. Or you can use BuildIndexFile function to build a new one..
<!– static –> Looks up a localized string similar to You don't have the corresponding idx file for your shape file. You can use the static method ShapeFileFeatureSource.BuildIndexFile() or ShapeFileFeatureLayer.BuildIndexFile() to build an idx file for the shape file, or you can set the RequireIndex property to false..
<!– static –> Looks up a localized string similar to Input Geometry Type Is Not Valid.
<!– static –> Looks up a localized string similar to There're some invalid geometry instance in table not valid. About invalid geometry please have a look at http://msdn.microsoft.com/en-us/library/bb933890.aspx website. To solve this problem, we provide MakeAllGeometryValid function to make the invalid geometry to be valid, because of the function updating your data, you need to backup your data before using this function..
<!– static –> Looks up a localized string similar to Invalid Operation Exception..
<!– static –> Looks up a localized string similar to is not supported for projection now..
<!– static –> Looks up a localized string similar to The GeoCollection does not contain the item you specified..
<!– static –> Looks up a localized string similar to The value should be between zero and one hundred..
<!– static –> Looks up a localized string similar to This Layer doesn't have a boundingBox..
<!– static –> Looks up a localized string similar to The layer type you have provided is not valid..
<!– static –> Looks up a localized string similar to The current extent you have provided is not valid..
<!– static –> Looks up a localized string similar to The current extent you have provided may not be null..
<!– static –> Looks up a localized string similar to The MrSidGeoImageSource is already open..
<!– static –> Looks up a localized string similar to The MrSidGeoImageSource is not open. Please open it before calling this method..
<!– static –> Looks up a localized string similar to The format of Multi-FieldNames isn't correct..
<!– static –> Looks up a localized string similar to Can't Reorder for the multi-line because it does not satisfy the reorder condition based on the given startPoint and given tolerance..
<!– static –> Looks up a localized string similar to Can't Reorder for the multi-line because it does not satisfy the reorder condition based on the given tolerance..
<!– static –> Looks up a localized string similar to Not all valid layers are open..
<!– static –> Looks up a localized string similar to This feature is currently not supported..
<!– static –> Looks up a localized string similar to The file type you provided is currently not supported..
<!– static –> Looks up a localized string similar to The SQL Query mode is not supported..
<!– static –> Looks up a localized string similar to The number should be between 0 and 255.
<!– static –> Looks up a localized string similar to We cannot get the AreaUnit from input unit..
<!– static –> Looks up a localized string similar to Parameter Ids should be from 1 to the record number in ShapeFileFeatureSource.
<!– static –> Looks up a localized string similar to The parameter you supplied may not be empty..
<!– static –> Looks up a localized string similar to The shape you provided does not pass our simple validation..
<!– static –> Looks up a localized string similar to The parameter you supplied may not be null..
<!– static –> Looks up a localized string similar to The parameter is transparent..
<!– static –> Looks up a localized string similar to Projection initialization failed..
<!– static –> Looks up a localized string similar to Cannot get the projection’s InternalGeographyUnit, please provide it by overriding the Projection’s GetInternalGeographyUnitCore() method..
<!– static –> Looks up a localized string similar to The projection is not open. Please open it before calling this method..
<!– static –> Looks up a localized string similar to This RasterLayer does not have projection information embedded in it. If you wish to avoid this exception you can first check the HasProjectionTextProperty..
<!– static –> Looks up a localized string similar to This RasterSource does not have projection information embedded in it. If you wish to avoid this exception you can first check the HasProjectionTextProperty..
<!– static –> Looks up a localized string similar to The rebuild of the DBF failed for an unknown reason. Please see the inner exception..
<!– static –> Looks up a localized string similar to The spatial index generation failed for an unknown reason. Please see the inner exception..
<!– static –> Looks up a localized string similar to the rebuilding of the shape file failed for an unknown reason. Please see the inner exception..
<!– static –> Looks up a localized string similar to The record is invalid, please call CheckForUnsupportedRecords method to check the the failed reason..
<!– static –> Returns the cached ResourceManager instance used by this class.
| ResourceManager<!– System.Resources.ResourceManager –> |
<!– static –> Looks up a localized string similar to This operation's return type is not correct..
<!– static –> Looks up a localized string similar to Return value is null..
<!– static –> Looks up a localized string similar to A ring should has more than 4 vertexes..
<!– static –> Looks up a localized string similar to Rotation is not supported on this class..
<!– static –> Looks up a localized string similar to The parameter row exceeds the total row count..
<!– static –> Looks up a localized string similar to The RtreeSpatialIndex is not open. Please call the Open method before calling this method..
<!– static –> Looks up a localized string similar to The shape file bounding box is invalid..
<!– static –> Looks up a localized string similar to The shape file name is invalid..
<!– static –> Looks up a localized string similar to There are no points in the shape..
<!– static –> Looks up a localized string similar to This shape has not been implemented yet..
<!– static –> Looks up a localized string similar to The shape file index is not open..
<!– static –> Looks up a localized string similar to The features in SpatialIndex are not removable..
<!– static –> Looks up a localized string similar to Input srid is not valid..
<!– static –> Looks up a localized string similar to The input string value is not blank..
<!– static –> Looks up a localized string similar to Target Shape Is Not Valid Type..
<!– static –> Looks up a localized string similar to The field type should be numeric..
<!– static –> Looks up a localized string similar to The format of the image is not supported..
<!– static –> Looks up a localized string similar to The value should be greater than zero..
<!– static –> Looks up a localized string similar to Unlicensed..
<!– static –> Looks up a localized string similar to Currently we do not support editing this kind of shape type. Shape type:.
<!– static –> Looks up a localized string similar to The update transaction failed for an unknown reason..
<!– static –> Looks up a localized string similar to The input Uri is not valid.
<!– static –> Looks up a localized string similar to The TIFF files(.tif or .tiff) are not supported in GdiPlusRasterSource any longer, please use the GeoTiffRasterSource instead..
<!– static –> Looks up a localized string similar to The format of the well known binary is incorrect..
<!– static –> Looks up a localized string similar to The well known binary is not valid for drawing..
<!– static –> Looks up a localized string similar to The well known binary type is incorrect..
<!– static –> Looks up a localized string similar to The format of the well known text is incorrect..
<!– static –> Looks up a localized string similar to Coordinate Reference System not set..
<!– static –> Looks up a localized string similar to This CRS is not supported in the Wms server: .
<!– static –> Looks up a localized string similar to The Wms server has timed out..
<!– static –> Looks up a localized string similar to The Wms request LAYERS parameter is missing..
<!– static –> Looks up a localized string similar to No layers exist in the Service Description..
<!– static –> Looks up a localized string similar to The requested parameter does not exists in this Service Description..
<!– static –> Looks up a localized string similar to This image format is not supported in the Wms server: .
<!– static –> Looks up a localized string similar to This layer is not supported in the Wms server: .
<!– static –> Looks up a localized string similar to This style is not supported in the Wms server: .
<!– static –> Looks up a localized string similar to The world extent is not valid..
<!– static –> Looks up a localized string similar to World file should has 6 lines..
<!– static –> Looks up a localized string similar to The ImageSource is not opened. Please open it before calling this method..
