thinkgeo.mapsuite.silverlightedition.trackstartingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.TrackStartingTrackInteractiveOverlayEventArgs
Provides data for the TrackStarting. event.
      • ThinkGeo.MapSuite.SilverlightEdition.TrackStartingTrackInteractiveOverlayEventArgs
TrackStartingTrackInteractiveOverlayEventArgs()
TrackStartingTrackInteractiveOverlayEventArgs(Vertex,Boolean)
  • startingVertex
    • Type:Vertex
    • Description:This parameter specified the started vertex when tracking shape action is being to start.
  • cancel
Cancel
StartingVertex
This property gets or sets the started vertex when tracking shape action is being to start.
thinkgeo.mapsuite.silverlightedition.trackstartingtrackinteractiveoverlayeventargs.1442806188.txt.gz · Last modified: 2015/09/21 03:29 by admin
