thinkgeo.mapsuite.silverlightedition.tilehandler
ThinkGeo.MapSuite.SilverlightEdition.TileHandler
<!– Class –> Defines the contract that ASP.NET implements to synchronously process HTTP Web requests using custom HTTP handlers. Image tiles actually generate here.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.TileHandler” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.TileHandler</a>
Public MethodTileHandler
Public MethodGetType Object
Public MethodProcessRequest HttpContext Enables processing of HTTP Web requests by a custom HttpHandler that implements the System.Web.IHttpHandler interface.
Public MethodToString Object
Protected MethodOnTileDrawing TileDrawingEventArgs Triggers before tile drawing.
Protected MethodOnTileDrawn TileDrawnEventArgs Triggers after tile drawn.
Public PropertyIsReusable Boolean Gets a value indicating whether another request can use the System.Web.IHttpHandler instance.
Public EventTileDrawing TileDrawingEventArgs Triggers before tile is drawn.
Public EventTileDrawn TileDrawnEventArgs Triggers after tile is drawn.
TileHandler()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
ProcessRequest(HttpContext)
Void<!– System.Void –>
context HttpContext<!– System.Web.HttpContext –> An System.Web.HttpContext object that provides references to the intrinsic server objects (for example, Request, Response, Session, and Server) used to service HTTP requests.
<!– ThinkGeo.MapSuite.SilverlightEdition.TileHandler –> Go Back
String<!– System.String –>
OnTileDrawing(TileDrawingEventArgs)
e TileDrawingEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.TileDrawingEventArgs –>
OnTileDrawn(TileDrawnEventArgs)
e TileDrawnEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.TileDrawnEventArgs –>
IsReusable
Return Type
TileDrawing
Event Arguments
Event Arguments
TileDrawn
Event Arguments
Event Arguments
NOTOC SilverlightMapConnector ThinkGeo.MapSuite.SilverlightEdition UpdateDocumentation
thinkgeo.mapsuite.silverlightedition.tilehandler.txt · Last modified: 2017/03/16 21:59 (external edit)
