thinkgeo.mapsuite.silverlightedition.tiledrawneventargs
ThinkGeo.MapSuite.SilverlightEdition.TileDrawnEventArgs
<!– Class –> This is the event arguments class for the TileDrawn event on the TileHandler class. It is raised after the tile is drawn.
Public MethodTileDrawnEventArgs Initialize TileDrawnEventArgs class.
Public MethodTileDrawnEventArgs ServerLayerOverlay, RectangleShape, Bitmap Initialize TileDrawnEventArgs class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyBitmap Bitmap The property gets and sets the bitmap object which is drawn.
Public PropertyOverlay ServerLayerOverlay The property gets and sets the overlay which is drawn.
Public PropertyWorldExtent RectangleShape The property gets and sets the world extent which is drawn on the tile.
TileDrawnEventArgs()
Name Type Description
Go Back
TileDrawnEventArgs(ServerLayerOverlay, RectangleShape, Bitmap)
overlay ServerLayerOverlay<!– ThinkGeo.MapSuite.SilverlightEdition.ServerLayerOverlay –> The parameter is the overlay which is drawn.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> The parameter is the world extent which is drawn.
bitmap Bitmap<!– System.Drawing.Bitmap –> The parameter is the bitmap which is drawn.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Bitmap
Return Type
<!– ThinkGeo.MapSuite.SilverlightEdition.TileDrawnEventArgs –> Go Back
Overlay
Return Type
WorldExtent
Return Type
thinkgeo.mapsuite.silverlightedition.tiledrawneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
