thinkgeo.mapsuite.silverlightedition.tiledrawingeventargs
ThinkGeo.MapSuite.SilverlightEdition.TileDrawingEventArgs
<!– Class –> This is the event arguments class for the TileDrawing event on the TileHandler class. It is raised before the tile is drawn.
Public MethodTileDrawingEventArgs Initialize TileDrawingEventArgs class.
Public MethodTileDrawingEventArgs ServerLayerOverlay, RectangleShape, Bitmap Initialize TileDrawingEventArgs class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyBitmap Bitmap The property gets and sets the bitmap object which is going to draw on the tile.
Public PropertyOverlay ServerLayerOverlay The property gets and sets the overlay which is going to draw.
Public PropertyWorldExtent RectangleShape The property gets and sets the world extent which is going to draw on the tile.
TileDrawingEventArgs()
Name Type Description
Go Back
TileDrawingEventArgs(ServerLayerOverlay, RectangleShape, Bitmap)
overlay ServerLayerOverlay<!– ThinkGeo.MapSuite.SilverlightEdition.ServerLayerOverlay –> The parameter is the overlay which is going to draw.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> The parameter is the world extent which is going to draw.
bitmap Bitmap<!– System.Drawing.Bitmap –> The parameter is the bitmap which is going to draw.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Bitmap
Return Type
<!– ThinkGeo.MapSuite.SilverlightEdition.TileDrawingEventArgs –> Go Back
Overlay
Return Type
WorldExtent
Return Type
thinkgeo.mapsuite.silverlightedition.tiledrawingeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
