<!– Class –> This class represents the BingsMapOverlay which requests images from image server of Bing Maps.
*System.Object ThinkGeo.MapSuite.SilverlightEdition.Overlay *ThinkGeo.MapSuite.SilverlightEdition.BingMapsOverlay
![]() | This is constructor of BingsMapOverlay class. | ||
![]() | String | This is constructor of BingsMapOverlay class. | |
![]() | String, String, BingMapsStyle | This is constructor of BingsMapOverlay class. |
![]() | RectangleShape, OverlayDrawType | Overlay(overriden) | This method draws the features in the specified extent. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Map | Overlay(overriden) | This method initializes the overlay canvas such as width, height and z-index for first time. |
![]() | Overlay | This method re-draws this overlay in current extent. | |
![]() | Point | Overlay | This method returns a screen point from a point shape in world coordinates. |
![]() | Double, Double | Overlay | This method returns a point shape in screen coordinates from the specified X, Y world coordinates. |
![]() | PointShape | Overlay | This method returns a screen point from a point shape in world coordinates. |
![]() | Object | ||
![]() | PointShape | Overlay | This method returns a point shape in world coordinates from a ScreenPointF structure. |
![]() | Double, Double | Overlay | This method returns a point shape in world coordinates from the specified X, Y screen coordinates. |
![]() | Point | Overlay | This method returns a point shape in world coordinates from a ScreenPointF structure. |
![]() | GeoCanvas | Overlay | |
![]() | RectangleShape | Overlay(overriden) | This method draws the features in the specified extent. |
![]() | Object | ||
![]() | Uri, RectangleShape, Int32, Int32, Int32, Int32, Double | This method gets tile request address from specific parameters. | |
![]() | Overlay(overriden) | This method initializes the overlay canvas such as width, height and z-index for first time. | |
![]() | Object | ||
![]() | DrawingAttributionOverlayEventArgs | Overlay | |
![]() | DrawnAttributionOverlayEventArgs | Overlay | |
![]() | Overlay | This method raised when Panning animation plays completed. | |
![]() | Overlay | This method raised when zooming animation plays completed. |
![]() | String | Overlay | |
![]() | BingMapsStyle | Gets or sets the Bing Map Type requesting from Bing Map image server. | |
![]() | Boolean | Gets or sets whether the stretch effect is disabled or not. | |
![]() | GeoImage | ||
![]() | String | Overlay | Gets or sets the name of an overlay which will display in the OverlaySwitcher. |
![]() | Double | Overlay | Gets or sets the opacity level of the overlay. |
![]() | FrameworkElement | Overlay | An FrameworkElement that contains the overlay. |
![]() | SplineDoubleKeyFrame | Overlay | Animates from the System.Double value of the previous key frame to its own System.Windows.Media.Animation.DoubleKeyFrame.Value using splined interpolation. |
![]() | Storyboard | Overlay | Gets the Storyboard object for panning. |
![]() | Storyboard | Overlay | Gets the Storyboard object for zooming. |
![]() | String | The token string for Bing Map service. | |
![]() | TransitionEffect | Overlay | Gets or Sets the transition effect to use when the map is panned or zoomed. |
![]() | Visibility | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
![]() | Int32 | Overlay | Get or set z-index of overlay, The value is bigger, and the order is higher. |
![]() | SplineDoubleKeyFrame | Overlay | Gets the SplineDoubleKeyFrame for zooming. |
![]() | Map | Overlay | Gets or sets current map information. |
![]() | ScaleTransform | Overlay | Gets the ScaleTransform object of this overlay. |
![]() | TransformGroup | Overlay | Gets the TranslateGroup object for panning and zooming. |
![]() | TranslateTransform | Overlay | Gets the TranslateTransform object of this overlay. |
This is constructor of <strong>BingsMapOverlay</strong> class.
Name | Type | Description |
name | String<!– System.String –> | A string value indicating the name of this overlay. |
token | String<!– System.String –> | The token for Bing Map service. |
bingMapType | BingMapsStyle<!– ThinkGeo.MapSuite.SilverlightEdition.BingMapsStyle –> | The Bing Map type. |
Zooms the overlay to the extent that you specify.
Return Type | Description |
Void<!– System.Void –> |
worldExtent | RectangleShape<!– ThinkGeo.MapSuite.SilverlightCore.RectangleShape –> | The new world extent of the map. |
overlayDrawType | OverlayDrawType<!– ThinkGeo.MapSuite.SilverlightEdition.OverlayDrawType –> | The enum value indecating that the map draws features or not. |
<!– ThinkGeo.MapSuite.SilverlightEdition.Overlay(overriden) –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
currentMap | Map<!– ThinkGeo.MapSuite.SilverlightEdition.Map –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.Overlay –> Go Back
This method converts the coordinates of a point shape to a point in screen coordinates.
PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | A screen point in pixels. |
worldCoordinate | Point<!– System.Windows.Point –> | A point in world coordinates. |
This method converts X, Y world coordinates to a point in screen coordinates.
worldX | Double<!– System.Double –> | The X world coordinate. |
worldY | Double<!– System.Double –> | The Y world coordinate. |
worldCoordinate | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | A point shape in world coordinates. |
This method converts a screen point to a point in world coordinates.
screenCoordinate | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | The point (in screen coordinates) to convert to world coordinates. |
This method converts X, Y screen coordinates to a point shape in world coodinates.
screenX | Double<!– System.Double –> | The X-value in pixels referenced to the screen origin. |
screenY | Double<!– System.Double –> | The Y-value in pixels referenced to the screen origin. |
screenCoordinate | Point<!– System.Windows.Point –> | The point (in screen coordinates) to convert to world coordinates. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.SilverlightCore.GeoCanvas –> |
worldExtent | RectangleShape<!– ThinkGeo.MapSuite.SilverlightCore.RectangleShape –> | A RectangleShape value indicating the world extent need to draw. |
Uri<!– System.Uri –> | A Uri value indicating the real address for requesting the tile image. |
serverUri | Uri<!– System.Uri –> | An Uri value indicating the server which specified. |
tileExtent | RectangleShape<!– ThinkGeo.MapSuite.SilverlightCore.RectangleShape –> | A RectangleShape value indicating the world extent for requesting images. |
row | Int32<!– System.Int32 –> | An integar value indicating the row index of the tile in the whole world extent. It starts from 0. |
column | Int32<!– System.Int32 –> | An integar value indicating the column index of the tile in the whole world extent. It starts from 0. |
tileWidth | Int32<!– System.Int32 –> | A double value indicating the width in pixel of the tile. |
tileHeight | Int32<!– System.Int32 –> | A double value indicating the height in pixel of the tile. |
scale | Double<!– System.Double –> | A double value indicating current scale of current map. |
<!– ThinkGeo.MapSuite.SilverlightEdition.BingMapsOverlay –> Go Back
args | DrawingAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.DrawingAttributionOverlayEventArgs –> |
args | DrawnAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.DrawnAttributionOverlayEventArgs –> |
Return Type |
Return Type |
If the wms images are transparent background, the stretched tiles will display right below the real tiles by the default value which affects your map.
Return Type |
Return Type |
GeoImage<!– ThinkGeo.MapSuite.SilverlightCore.GeoImage –> |
Return Type |
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent(1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type |
Return Type |
FrameworkElement<!– System.Windows.FrameworkElement –> |
Return Type |
SplineDoubleKeyFrame<!– System.Windows.Media.Animation.SplineDoubleKeyFrame –> |
Return Type |
Return Type |
Storyboard<!– System.Windows.Media.Animation.Storyboard –> |
Return Type |
Return Type |
Return Type |
TransitionEffect<!– ThinkGeo.MapSuite.SilverlightEdition.TransitionEffect –> |
Return Type |
Visibility<!– System.Windows.Visibility –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
ScaleTransform<!– System.Windows.Media.ScaleTransform –> |
Return Type |
TransformGroup<!– System.Windows.Media.TransformGroup –> |
Return Type |
TranslateTransform<!– System.Windows.Media.TranslateTransform –> |
Event Arguments |
Event Arguments |
NOTOC SilverlightEdition ThinkGeo.MapSuite.SilverlightEdition UpdateDocumentation
