If you use this constructor, you will need to set the properties of the fill brush and outline pen manually.
This constructor allows you to specify just a fill brush. In this way, the area you draw will not have an outline.
This constructor allows you to specify just an outline pen. In this way, the area you draw will have an outline, but a transparent interior (no fill).
AreaStyle(GeoPen,GeoSolidBrush)
This constructor allows you to specify a fill brush and an outline pen.
AreaStyle(GeoPen,GeoSolidBrush,PenBrushDrawingOrder)
This constructor allows you to specify a fill brush and an outline pen. It also allows you to specify which is drawn first. If the pen is drawn first, the outline will be thinner than if the pen is drawn last. The effect is subtle but noticeable.
This property allows you to specify an X offset. When combined with a Y offset, it enables you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to align it with raster satellite data.
This property allows you to specify a Y offset. When combined with an X offset, it enables you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to align it with raster satellite data.
This property gets and sets the solid brush you want to use to fill in the area features.
This solid brush is used to fill in the area features that will draw. You can also optionally specify an outline pen to give the area an outline. The default solid brush has a fill color of transparent, which means it will not draw anything.
This property returns a collection of area styles, allowing you to stack multiple area styles on top of each other.
Using this collection, you can stack multiple area styles on top of each other. When we draw the features, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
This property gets and sets the outline pen you want to use to outline the features.
This outline pen is used to outline the features that will draw. You can also optionally specify a fill brush to give the area a solid fill. The default outline pen color is transparent, which means it will not draw anything.
This property controls whether the outline pen or the fill brush is drawn first. The default is for the fill brush to be drawn first. If you have the outline pen draw first then the thickness of the pen will be smaller, creating a subtle but noticeable effect.
This property lets you access the advanced properties of the style.
