thinkgeo.mapsuite.routing.bidirectionalroutingalgorithm
ThinkGeo.MapSuite.Routing.BidirectionalRoutingAlgorithm
This class represents a routing algorithm that is based on the Bidirectional algorithm.
    • ThinkGeo.MapSuite.Routing.RoutingAlgorithm
      • ThinkGeo.MapSuite.Routing.BidirectionalRoutingAlgorithm
BidirectionalRoutingAlgorithm()
This is a constructor for this class.
GetRoute(RoutingSource,String,String)
  • startFeatureId
  • endFeatureId
GetRouteCore(RoutingSource,String,String)
This method returns a RoutingResult based on the extent you provided.
  • Type:Collection<RouteSegment>
  • Description:Routing result that contains path information.
  • routingSource
    • Description:The routing source that contains the routeSegments to route on.
  • startFeatureId
    • Description:The feature ID which represents the starting routeSegment.
  • endFeatureId
    • Description:The feature ID which represents the ending routeSegment.
OnFindingRoute(FindingRouteRoutingAlgorithmEventArgs)
AStartRouteModifier
  • Type:Single
GeographyUnit
DistanceUnit
FindingRoute N/A
thinkgeo.mapsuite.routing.bidirectionalroutingalgorithm.1442545574.txt.gz · Last modified: 2015/09/18 03:06 by admin
