This class represents a routing algorithm that is based on the A* algorithm.
The A* algorithm is one of the best graph search algorithms that finds the least-cost path from a given start point to a given end point. It uses a distance-plus-cost heuristic function to determine the order in which the search visits routeSegments in the data.
![]() | This is a constructor for this class. |
![]() | Object | Object | |
![]() | Object | ||
![]() | RoutingSource, String, String | RoutingAlgorithm | This method returns a RoutingResult based on the extent you provided. |
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | RoutingSource, String, String | RoutingAlgorithm(overriden) | This method returns a RoutingResult based on the extent you provided. |
![]() | Object | ||
![]() | FindingRouteRoutingAlgorithmEventArgs | RoutingAlgorithm | This method allows you to raise the FindingRoute event from a derived class. |
![]() | Single | ||
![]() | DistanceUnit | RoutingAlgorithm | |
![]() | GeographyUnit | RoutingAlgorithm |
![]() | FindingRouteRoutingAlgorithmEventArgs | RoutingAlgorithm | This event is called after finding the adjacent routeSegments. |
For the most updated Info for this topic, please check it here: “http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#AStarRoutingAlgorithm.28.29”
Name | Type | Description |
For the most updated Info for this topic, please check it here: http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#Equals.28Object.29
Return Type | Description |
Boolean |
obj | Object |
For the most updated Info for this topic, please check it here: http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GetHashCode.28.29
Int32 |
Collection<RouteSegment> | Routing result that contains path information. |
routingSource | RoutingSource | The routing source that contains the routeSegments to route on. |
startFeatureId | String | The feature ID which represents the starting routeSegment. |
endFeatureId | String | The feature ID which represents the ending routeSegment. |
For the most updated Info for this topic, please check it here: http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GetType.28.29
Type |
For the most updated Info for this topic, please check it here: http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#ToString.28.29
String |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#Finalize.28.29</a>
Void<!– System.Void –> |
Collection<RouteSegment><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Routing.RouteSegment} –> | Routing result that contains path information. |
routingSource | RoutingSource<!– ThinkGeo.MapSuite.Routing.RoutingSource –> | The routing source that contains the routeSegments to route on. |
startFeatureId | String<!– System.String –> | The feature ID which represents the starting routeSegment. |
endFeatureId | String<!– System.String –> | The feature ID which represents the ending routeSegment. |
<!– ThinkGeo.MapSuite.Routing.RoutingAlgorithm(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#MemberwiseClone.28.29</a>
Object<!– System.Object –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#OnFindingRoute.28FindingRouteRoutingAlgorithmEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#OnFindingRoute.28FindingRouteRoutingAlgorithmEventArgs.29</a>
e | FindingRouteRoutingAlgorithmEventArgs<!– ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#AStartRouteModifier” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#AStartRouteModifier</a>
Return Type |
Single<!– System.Single –> |
<!– ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#DistanceUnit” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#DistanceUnit</a>
Return Type |
DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GeographyUnit” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GeographyUnit</a>
Return Type |
GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> |
Event Arguments |
