thinkgeo.mapsuite.routing.astarroutingalgorithm
ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm
This class represents a routing algorithm that is based on the A* algorithm.
The A* algorithm is one of the best graph search algorithms that finds the least-cost path from a given start point to a given end point. It uses a distance-plus-cost heuristic function to determine the order in which the search visits routeSegments in the data.
Public MethodAStarRoutingAlgorithm This is a constructor for this class.
Public MethodGetRoute RoutingSource, String, String RoutingAlgorithm This method returns a RoutingResult based on the extent you provided.
Public MethodGetType Object
Public MethodToString Object
Protected MethodGetRouteCore RoutingSource, String, String RoutingAlgorithm(overriden) This method returns a RoutingResult based on the extent you provided.
Protected MethodOnFindingRoute FindingRouteRoutingAlgorithmEventArgs RoutingAlgorithm This method allows you to raise the FindingRoute event from a derived class.
Public EventFindingRoute FindingRouteRoutingAlgorithmEventArgs RoutingAlgorithm This event is called after finding the adjacent routeSegments.
AStarRoutingAlgorithm()
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#AStarRoutingAlgorithm.28.29
Name Type Description
Go Back
For the most updated Info for this topic, please check it here: http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#Equals.28Object.29
Return Type Description
Boolean
obj Object
Go Back
For the most updated Info for this topic, please check it here: http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GetHashCode.28.29
Int32
Go Back
GetRoute(RoutingSource, String, String)
Collection<RouteSegment> Routing result that contains path information.
routingSource RoutingSource The routing source that contains the routeSegments to route on.
startFeatureId String The feature ID which represents the starting routeSegment.
endFeatureId String The feature ID which represents the ending routeSegment.
Go Back
For the most updated Info for this topic, please check it here: http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GetType.28.29
Type
Go Back
String<!– System.String –>
Void<!– System.Void –>
GetRouteCore(RoutingSource, String, String)
Collection<RouteSegment><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Routing.RouteSegment} –> Routing result that contains path information.
routingSource RoutingSource<!– ThinkGeo.MapSuite.Routing.RoutingSource –> The routing source that contains the routeSegments to route on.
startFeatureId String<!– System.String –> The feature ID which represents the starting routeSegment.
endFeatureId String<!– System.String –> The feature ID which represents the ending routeSegment.
<!– ThinkGeo.MapSuite.Routing.RoutingAlgorithm(overriden) –> Go Back
Object<!– System.Object –>
OnFindingRoute(FindingRouteRoutingAlgorithmEventArgs)
e FindingRouteRoutingAlgorithmEventArgs<!– ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs –>
AStartRouteModifier
Return Type
Single<!– System.Single –>
<!– ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm –> Go Back
DistanceUnit
Return Type
DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –>
GeographyUnit
Return Type
GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –>
FindingRoute
Event Arguments
Event Arguments
thinkgeo.mapsuite.routing.astarroutingalgorithm.1441939120.txt.gz · Last modified: 2015/09/11 02:38 by admin
