This class represents a routing algorithm that is based on the A* algorithm.
The A* algorithm is one of the best graph search algorithms that finds the least-cost path from a given start point to a given end point. It uses a distance-plus-cost heuristic function to determine the order in which the search visits routeSegments in the data.
AStarRoutingAlgorithm | This is a constructor for this class. |
GetRoute | RoutingSource, String, String | RoutingAlgorithm | This method returns a RoutingResult based on the extent you provided. |
GetRouteCore | RoutingSource, String, String | RoutingAlgorithm(overriden) | This method returns a RoutingResult based on the extent you provided. |
MemberwiseClone | Object | ||
OnFindingRoute | FindingRouteRoutingAlgorithmEventArgs | RoutingAlgorithm | This method allows you to raise the FindingRoute event from a derived class. |
AStartRouteModifier | Single | ||
DistanceUnit | DistanceUnit | RoutingAlgorithm | |
GeographyUnit | GeographyUnit | RoutingAlgorithm |
FindingRoute | FindingRouteRoutingAlgorithmEventArgs | RoutingAlgorithm | This event is called after finding the adjacent routeSegments. |
For the most updated Info for this topic, please check it here: “http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#AStarRoutingAlgorithm.28.29”
For the most updated Info for this topic, please check it here: http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#Equals.28Object.29
| Boolean |
| obj | Object |
For the most updated Info for this topic, please check it here: http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GetHashCode.28.29
| Int32 |
| Collection<RouteSegment><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Routing.RouteSegment} –> | Routing result that contains path information. |
| routingSource | RoutingSource<!– ThinkGeo.MapSuite.Routing.RoutingSource –> | The routing source that contains the routeSegments to route on. |
| startFeatureId | String<!– System.String –> | The feature ID which represents the starting routeSegment. |
| endFeatureId | String<!– System.String –> | The feature ID which represents the ending routeSegment. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#Finalize.28.29</a>
<!– ThinkGeo.MapSuite.Routing.RoutingAlgorithm(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#MemberwiseClone.28.29</a>
| Object<!– System.Object –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#OnFindingRoute.28FindingRouteRoutingAlgorithmEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#OnFindingRoute.28FindingRouteRoutingAlgorithmEventArgs.29</a>
| e | FindingRouteRoutingAlgorithmEventArgs<!– ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#AStartRouteModifier” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#AStartRouteModifier</a>
<!– ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#DistanceUnit” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#DistanceUnit</a>
| DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GeographyUnit” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm#GeographyUnit</a>
| Event Arguments |
