thinkgeo.mapsuite.routing.astarroutingalgorithm
ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm
This class represents a routing algorithm that is based on the A* algorithm.
The A* algorithm is one of the best graph search algorithms that finds the least-cost path from a given start point to a given end point. It uses a distance-plus-cost heuristic function to determine the order in which the search visits routeSegments in the data.
Public MethodAStarRoutingAlgorithm This is a constructor for this class.
Public MethodGetRoute RoutingSource, String, String RoutingAlgorithm This method returns a RoutingResult based on the extent you provided.
Public MethodGetType Object
Public MethodToString Object
Protected MethodGetRouteCore RoutingSource, String, String RoutingAlgorithm(overriden) This method returns a RoutingResult based on the extent you provided.
Protected MethodOnFindingRoute FindingRouteRoutingAlgorithmEventArgs RoutingAlgorithm This method allows you to raise the FindingRoute event from a derived class.
Public EventFindingRoute FindingRouteRoutingAlgorithmEventArgs RoutingAlgorithm This event is called after finding the adjacent routeSegments.
AStarRoutingAlgorithm()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetRoute(RoutingSource, String, String)
Collection<RouteSegment><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Routing.RouteSegment} –> Routing result that contains path information.
routingSource RoutingSource<!– ThinkGeo.MapSuite.Routing.RoutingSource –> The routing source that contains the routeSegments to route on.
startFeatureId String<!– System.String –> The feature ID which represents the starting routeSegment.
endFeatureId String<!– System.String –> The feature ID which represents the ending routeSegment.
Type<!– System.Type –>
Void<!– System.Void –>
GetRouteCore(RoutingSource, String, String)
<!– ThinkGeo.MapSuite.Routing.RoutingAlgorithm(overriden) –> Go Back
OnFindingRoute(FindingRouteRoutingAlgorithmEventArgs)
e FindingRouteRoutingAlgorithmEventArgs<!– ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs –>
AStartRouteModifier
Return Type
Single<!– System.Single –>
<!– ThinkGeo.MapSuite.Routing.AStarRoutingAlgorithm –> Go Back
DistanceUnit
Return Type
DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –>
GeographyUnit
Return Type
GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –>
FindingRoute
Event Arguments
Event Arguments
thinkgeo.mapsuite.routing.astarroutingalgorithm.1441938812.txt.gz · Last modified: 2015/09/11 02:33 by admin
