thinkgeo.mapsuite.portablecore.tilecache
ThinkGeo.MapSuite.PortableCore.TileCache
<!– Class –> This is the base class for TileCache system.
TileCahce system is very efficient in improving the performance of application, especially when large data or remote server images are included.
Protected MethodTileCache String, TileImageFormat, TileMatrix This is the constructor of the class.
Public MethodClearCache This method will clear all the tiles in the tileCache.
Public MethodDeleteTile Tile This method will delete the target tile passed in.
Public MethodDeleteTiles RectangleShape This method will delete the tiles within the passed in worldExtent.
Public MethodGetType Object
Public MethodSaveTile Tile This method will save the target tile passed in.
Public MethodSaveTiles GeoImage, RectangleShape This method will save the bitmap with its extent attached into tiles.
Public MethodToString Object
Protected MethodClearCacheCore This abstract method will clear all the tiles in the tileCache, for each sub TileCache class must implement this method.
Protected MethodDeleteTileCore Tile This abstract method will delete the target tile passed in, for each sub TileCache class must implement this method.
Protected MethodSaveTileCore Tile This abstract method will save the target tile passed in, for each sub TileCache class must implement this method.
Public PropertyCacheId String Gets or sets the id of the TileCache.
Public PropertyImageFormat TileImageFormat Gets or sets the tile image format.
Public PropertyJpegQuality Int16 Gets or sets the Jpeg quality , this property only take effects when setting the ImageFormat to Jpeg.
Public PropertyLoadingTileImage GeoImage This property returns back a preset image showing the Tile is loading.
Public PropertyNoDataTileImage GeoImage This property returns back a preset image showing the tile data is missing.
Public PropertyTileAccessMode TileAccessMode Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete
Public PropertyTileMatrix TileMatrix Gets or sets the TileMatrix which is used in caculation for tiles.
TileCache(String, TileImageFormat, TileMatrix)
Name Type Description
cacheId String<!– System.String –> This is the cache identifier which marks its difference with other TileCache.
imageFormat TileImageFormat<!– ThinkGeo.MapSuite.PortableCore.TileImageFormat –> This is the imageFormate showing what kind of image we are trying to save.
tileMatrix TileMatrix<!– ThinkGeo.MapSuite.PortableCore.TileMatrix –> This is the tile matrix system which is used for caculating tiles.
Go Back
ClearCache()
This method will not take effect when the ReadOnly is set to true.
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.PortableCore.TileCache –> Go Back
DeleteTile(Tile)
tile Tile<!– ThinkGeo.MapSuite.PortableCore.Tile –> The target tile to be deleted.
DeleteTiles(RectangleShape)
worldExtent RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> The target extent to delete all tiles within it.
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
SaveTile(Tile)
tile Tile<!– ThinkGeo.MapSuite.PortableCore.Tile –> The target tile to be saved.
SaveTiles(GeoImage, RectangleShape)
bitmap GeoImage<!– ThinkGeo.MapSuite.PortableCore.GeoImage –> The target bitmap to be saved into tiles.
bitmapExtent RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> The target extent for the bitmap.
ClearCacheCore()
DeleteTileCore(Tile)
SaveTileCore(Tile)
CacheId
Return Type
ImageFormat
Return Type
JpegQuality
Return Type
Int16<!– System.Int16 –>
LoadingTileImage
Return Type
NoDataTileImage
Return Type
TileAccessMode
If you want it to take effect, you need set the ReadOnly property false.
Return Type
TileAccessMode<!– ThinkGeo.MapSuite.PortableCore.TileAccessMode –>
TileMatrix
Return Type
thinkgeo.mapsuite.portablecore.tilecache.1440040133.txt.gz · Last modified: 2015/09/21 08:19 (external edit)
