<!– Class –> The ScaleLineAdornmentLayer is a concrete class inherited from AdornmentLayer. The ScaleLineAdornmentLayer class allows you show a ScaleLine graphic on the map.
The <strong>ScaleLineAdornmentLayer</strong> of the map is a quick way to implement a ScaleLine. When doing this, we also have to add a <strong>ScaleLineAdornmentLayer</strong> to the map control.
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.AdornmentLayer ThinkGeo.MapSuite.PortableCore.ScaleLineAdornmentLayer
![]() | Creates a new instance of the ScaleLineAdornmentLayer class. The default location of this ScaleLineAdornmentLayer is the lower left corner of the CurrentExtent of the map. | ||
![]() | ScreenPointF | Creates a new instance of the ScaleLineAdornmentLayer class by passing in the specified ScreenPoint, which will be the start position of this ScaleLineAdornmentLayer when it is shown on the map. | |
![]() | AdornmentLocation | Creates a new instance of the ScaleLineAdornmentLayer class by passing in the specified enumeration of the AdornmentLocation that will be used to set the start position of this ScaleLineAdornmentLayer when it is shown on the map. |
![]() | Layer | Create a copy of Layer using the deep clone process. | |
![]() | Layer | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
![]() | Object | Object | |
![]() | Layer | This method returns the bounding box of the Layer. | |
![]() | GeoCanvas, Single, Single | AdornmentLayer | This method returns the drawing location of the AdornmentLayer. |
![]() | Object | ||
![]() | Object | ||
![]() | Layer | This method opens the Layer so that it is initialized and ready to use. | |
![]() | Layer | ||
![]() | RectangleShape | Layer | |
![]() | IEnumerable<RectangleShape> | Layer | |
![]() | TimeSpan | Layer | |
![]() | RectangleShape, TimeSpan | Layer | |
![]() | IEnumerable<RectangleShape>, TimeSpan | Layer | |
![]() | Object |
![]() | Layer | Create a copy of Layer using the deep clone process. The default implemenation uses serialization. | |
![]() | GeoCanvas, String | Layer | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the Layer. |
![]() | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | Object | ||
![]() | Object | ||
![]() | DrawingAttributionLayerEventArgs | Layer | |
![]() | DrawingExceptionLayerEventArgs | Layer | |
![]() | DrawingProgressChangedEventArgs | Layer | |
![]() | DrawnAttributionLayerEventArgs | Layer | |
![]() | DrawnExceptionLayerEventArgs | Layer | |
![]() | RequestedDrawingLayerEventArgs | Layer | |
![]() | RequestingDrawingLayerEventArgs | Layer | |
![]() | String | Layer | |
![]() | AreaStyle | AdornmentLayer | |
![]() | Dictionary<String,String> | This propery is a dictionary that exposes what text will be drawn to represent the ScaleLine Unit. | |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
![]() | Single | AdornmentLayer | |
![]() | Boolean | Layer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | Layer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | AdornmentLocation | AdornmentLayer | This property gets and sets the drawing location of the AdornmentLayer. |
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | Projection | Gets or sets a Proj4 projection parameter string which shows what coordinate system the map is using. | |
![]() | TextStyle | ||
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
![]() | ScaleLineUnitSystem | Gets or sets the UnitSystem to be used for the ScaleLine. | |
![]() | Single | AdornmentLayer | This property gets and sets the X pixel offset for the AdornmentLayer. |
![]() | Single | AdornmentLayer | This property gets and sets the Y pixel offset for the AdornmentLayer. |
Name | Type | Description |
startPoint | ScreenPointF<!– ThinkGeo.MapSuite.PortableCore.ScreenPointF –> | The start position of the ScaleLineAdornmentLayer that will be shown on the Map. |
location | AdornmentLocation<!– ThinkGeo.MapSuite.PortableCore.AdornmentLocation –> | This parameter specifies the location of the start point of the ScaleLineAdornmentLayer. |
Return Type | Description |
Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
Void<!– System.Void –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
ScreenPointF<!– ThinkGeo.MapSuite.PortableCore.ScreenPointF –> | It returns the upper left screen point of where the AdornmentLayer will be drawn. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas used in drawing. |
adornmentWidth | Single<!– System.Single –> | This parameter is the width of the adornment. |
adornmentHeight | Single<!– System.Single –> | This parameter is the height of the adornment |
<!– ThinkGeo.MapSuite.PortableCore.AdornmentLayer –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> |
bufferTime | TimeSpan<!– System.TimeSpan –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
String<!– System.String –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
attribution | String<!– System.String –> |
This abstract method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
Return Type |
Return Type |
AreaStyle<!– ThinkGeo.MapSuite.PortableCore.AreaStyle –> |
We will display different letters for different units of measure; for example: “m” for meters, “ft” for feet, etc.
Return Type |
Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
<!– ThinkGeo.MapSuite.PortableCore.ScaleLineAdornmentLayer –> Go Back
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
Return Type |
The default value is false.
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Projection<!– ThinkGeo.MapSuite.PortableCore.Projection –> |
Return Type |
Return Type |
TextStyle<!– ThinkGeo.MapSuite.PortableCore.TextStyle –> |
Return Type |
By setting this property, you can set the top and button unit for the ScaleLine.
Return Type |
ScaleLineUnitSystem<!– ThinkGeo.MapSuite.PortableCore.ScaleLineUnitSystem –> |
Return Type |
This property allows you to specify an X offset. It is useful, when combined with a Y offset, to do things like modify the location of the adornment.
Return Type |
This property allows you to specify a Y offset. It is useful, when combined with an X offset, to do things like modify the location of the adornment.
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
