thinkgeo.mapsuite.portablecore.rotationprojection
ThinkGeo.MapSuite.Core.RotationProjection
This projection allows you to rotate the map image base don an angle.
    • ThinkGeo.MapSuite.Core.Projection
      • ThinkGeo.MapSuite.Core.RotationProjection
RotationProjection()
  • This is the default constructor and will set the angle to 0 whick is north being up.
RotationProjection(Double)
  • This constructor allows you to pass in an angle to change the rotation of the map.
  • angle
    • Description:This parameter is the angle you want to map to rotate to.
RotationProjection(GeographyUnit)
RotationProjection(Double,GeographyUnit)
  • angle
GetUpdatedExtent(RectangleShape)
  • This method returns an adjusted extend based on the angle of rotation.
  • This method returns an adjusted extend based on the angle of rotation. It is important that you update your current extent every time you adjust the angle of the projection. This will ensure the rotaion is performed properly.
  • Description:This method returns an adjusted extend based on the angle of rotation.
  • worldExtent
    • Description:This parameter is the world extent before the rotation.
CloneDeep()
Open()
ConvertToExternalProjection(GeoImage,RectangleShape)
ConvertToExternalProjection(GeoImage,RectangleShape,RectangleShape)
Close()
ConvertToExternalProjection(Double,Double)
  • x
  • y
ConvertToExternalProjection(BaseShape)
ConvertToExternalProjection(Feature)
  • feature
ConvertToInternalProjection(Double,Double)
  • x
  • y
ConvertToInternalProjection(Feature)
  • feature
ConvertToInternalProjection(RectangleShape)
GetInternalGeographyUnit()
GetExternalGeographyUnit()
ConvertToExternalProjectionCore(Double[],Double[])
  • This method returns a projected vertices based on the coordinates passed in.
  • This method returns a projected vertex based on the coordinates passed in. You will need to override this method for the Projection class. Typically you can call the projection utility library that has interfaces for dozens of different types of projections.
  • Type:Vertex[]
  • Description:This method returns a projected vertices based on the coordinates passed in.
  • x
    • Type:Double[]
    • Description:This parameter is the X values of the points that will be projected.
  • y
    • Type:Double[]
    • Description:This parameter is the Y values of the points that will be projected.
ConvertToInternalProjectionCore(Double[],Double[])
  • This method returns a de-projected vertices based on the coordinates passed in.
  • This method returns a de-projected vertex based on the coordinates passed in. You will need to override this method for the Projection class. Typically you can call the projection utility library that has interfaces for dozens of different types of projections. The de-projection is important because inside of the FeatureSource you will in many cases to to and from various projections.
  • Type:Vertex[]
  • Description:This method returns a de-projected vertices based on the coordinates passed in.
  • x
    • Type:Double[]
    • Description:This parameter is the X values of the points that will be de-projected.
  • y
    • Type:Double[]
    • Description:This parameter is the Y values of the points that will be de-projected.
GetInternalGeographyUnitCore()
CloneDeepCore()
ConvertToExternalProjectionCore(GeoImage,RectangleShape)
ConvertToExternalProjectionCore(GeoImage,RectangleShape,RectangleShape)
OpenCore()
CloseCore()
UpdateToExternalProjection(Feature)
  • feature
UpdateToInternalProjection(Feature)
  • feature
GetExternalGeographyUnitCore()
Angle
  • This property sets the angle of rotation.
SourceUnit
PivotCenter
IsOpen
CanConvertRasterToExternalProjection
CanReproject
thinkgeo.mapsuite.portablecore.rotationprojection.txt · Last modified: 2017/03/16 21:59 (external edit)
