thinkgeo.mapsuite.portablecore.pointbasestyle
ThinkGeo.MapSuite.Core.PointBaseStyle
PointBaseStyle()
PointBaseStyle(GeoSolidBrush,Int32)
  • symbolSize
PointBaseStyle(GeoSolidBrush,GeoPen,Int32)
  • symbolPen
  • symbolSize
CloneDeep()
  • Type:Style
  • features
    • Type:IEnumerable<Feature>
  • shapes
    • Type:IEnumerable<BaseShape>
GetRequiredColumnNames()
  • Type:Collection<String>
DrawSample(GeoCanvas)
  • This method draws a sample feature on the canvas you provided.
  • This virtual method is called from the concrete public method Draw. In this method, we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area. When implementing this virtual method, consider the canvas size and draw the sample image appropriately. You should keep in mind that the sample typically shows up on a legend.
  • Description:None
  • canvas
    • Type:GeoCanvas
CloneDeepCore()
  • Type:Style
  • features
GetRequiredColumnNamesCore()
Advanced
DrawingLevel
SymbolSolidBrush
  • This property gets and sets the SolidBrush used to color the interior of the Symbol.
  • This brush is used to draw the interior of the symbol. It is only used if the PointType is Symbol. If you need a brush other than the SolidBrush, you should look in the advanced property of the class.
SymbolPen
  • This property gets and sets the SolidBrush used to draw the oultine of the Symbol.
  • This pen is used to draw the outline of the Symbol. By default the pen draws a transparent (invisible) color, which just leaves you with a fill.
SymbolSize
  • This property gets and sets the size of the symbol if the PointType is Symbol.
  • The allows you to make the symbol larger and smaller.
  • Type:Single
RotationAngle
  • This property gets and sets the angle of rotation for the drawing of the point.
  • This property controls the rotation of the bitmap, character or symbol, depending on the PointType.
  • Type:Single
XOffsetInPixel
  • This property gets and sets the X pixel offset for drawing each feature.
  • This property allows you to specify an X offset. When combined with a Y offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
  • Type:Single
YOffsetInPixel
  • This property gets and sets the Y pixel offset for drawing each feature.
  • This property allows you to specify a Y offset. When combined with an X offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
  • Type:Single
CustomPointStyles
  • This property returns a collection of area styles allowing you to stack multiple area styles on top of each other.
  • Using this collection, you can stack multiple styles on top of each other. When we draw the feature, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
IsActive
RequiredColumnNames
Filters
FiltersCore
thinkgeo.mapsuite.portablecore.pointbasestyle.txt · Last modified: 2017/03/16 21:59 (external edit)
