thinkgeo.mapsuite.portablecore.oraclefeaturelayer
ThinkGeo.MapSuite.Core.OracleFeatureLayer
This class represents a Layer backed by Oracle Spatial.
      • ThinkGeo.MapSuite.Core.FeatureLayer
        • ThinkGeo.MapSuite.Core.OracleFeatureLayer
OracleFeatureLayer()
OracleFeatureLayer(String,String,String)
  • connectionString
    • Description:This parameter represents the connection string that will be used to connect to the server.
  • tableName
    • Description:This parameter represents the table name being accessed.
  • featureIdColumn
    • Description:This parameter represents the name of the column that holds the unique feature Id.
OracleFeatureLayer(String,String,String,DatabaseConnectionMode)
  • connectionString
  • tableName
  • featureIdColumn
ExecuteNonQuery(String)
This method executes a query that does not return a SQL result.
This methods executes a query that has no results.
  • Description:None
  • sqlStatement
    • Description:This parameter represents the SQL statement that will be executed.
BuildIndex()
BuildIndex(BuildIndexMode)
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
1BU=(IEnumerable<String>)
  • returningColumnNames
    • Type:IEnumerable<String>
1xU=(GeoCanvas,Dictionary<String,Collection<Feature»,Collection<SimpleCandidate>,ZoomLevel,RectangleShape)
  • featuresForFilters
  • currentZoomLevel
SetupTools()
SetupToolsCore()
OpenCore()
CloseCore()
GetBoundingBoxCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
CommandTimeout
This property gets and sets the amount of time that can elapse before the command will timeout and abort.
You can use this to set a time limit for the query before it times out.
ConnectionString
This property gets and sets the connection string that will be used to connect to the server.
TableName
This property gets or sets the table name the database will use.
FeatureIdColumn
This property gets or sets the name of the column that holds the unique feature Id.
WhereClause
HasBoundingBox
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In OracleFeatureLayer, we override this API and mark it as true.
WrappingExtent
WrappingMode
EditTools
FeatureIdsToExclude
  • Type:Collection<String>
QueryTools
MaxRecordsToDraw
FeatureSource
DrawingQuality
ZoomLevelSet
DrawingMarginPercentage
DrawingMarginInPixel
  • Type:Single
GeometryValidationMode
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
yhU=
  • Type:Int64
zRU=
  • Type:Int64
0BU=
  • Type:TimeSpan
0xU=
  • Type:TimeSpan
IsOpenCore
DrawingFeatures N/A
DrawingWrappingFeatures N/A
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.portablecore.oraclefeaturelayer.txt · Last modified: 2017/03/16 21:59 (external edit)
