thinkgeo.mapsuite.portablecore.mapshape
ThinkGeo.MapSuite.Core.MapShape
This class represent a unit can be drawn on map. Each MapShape composes of a feature and a ZoomLevelSet to control its drawing zoomlevels.
    • ThinkGeo.MapSuite.Core.MapShape
MapShape()
  • This is the default constructor for the MapShape.
  • None
MapShape(Feature)
  • None
  • feature
    • Type:Feature
    • Description:This parameter is the feature for this MapShape.
Feature
  • This property returns the feature representing the MapShape.
  • None
ZoomLevels
  • This property returns the ZoomLevel to control the drawing of the MapShape.
  • None
thinkgeo.mapsuite.portablecore.mapshape.txt · Last modified: 2017/03/16 21:59 (external edit)
